Question about Black & Decker Juicers
Relatch I dropped my juicer and it will not relatch how do I fix it
How i can cleans it
Put three drops of dish soap in it and add water .... put it on the juicer and run for 30 seconds. Empty soapy water add plain water do it again, and just for good luck.... do it one more time to get rid of all the soap.
Oct 20, 2014 | Juicers
JUICER WILL ONLY GO IN REVERSE
I talked to an Omega tech, and he walked me through a home fix. If you open the juicer and look at the switch from below there are two sets of connections. Just move the red, blue, white connections to the opposite side (make sure the unit is unplugged when doing this).
Mar 11, 2014 | Omega 8003 Nutrition Center Juicer
Not working
This juicer has a 10 year warranty and you can contact Omega directly for warranty information and servicing the juicer. The link for their website is below:
http://www.omegajuicers.com/juicers/masticating-juicers.html
Jun 02, 2013 | Omega Vert HD Machine VRT350 VRT 350...
In need of replacement part for older Champion Juicer
Fixya is unable to source parts for appliances.
Jan 22, 2018 | Juicers
I m unable to open the the juicer as need i clean it inside.
Assuming you are dropping down the metal arm, removing the plunger and the rear pulp collector: everything unscrews from there. Hope you did this immediately following the juicing as it gets sticky and can be hard to open if you waited until it dried. When you get to the screen, it opens with a red tool they provide to unscrew it. Hope this helps.
Feb 24, 2011 | Jack Lalanne Power Juicer 250 Watts
Where the blade of the juicer screws on has broken off
mcdevito75, Refer to the owners manual for return of the juicer for repair, or go online to Jack Lalanne juicer for repair/return details.
Jun 16, 2010 | Jack Lalanne Power Juicer 250 Watts
AMCE JUICER WON'T WORK
4 SCREWS HOLD THE BASE PLATE.
REMOVE IT AND HAVE A LOOK. THE
WIRING IS PRETTY SIMPLE. THIS THING
IS REALLY BUILT, SO IT MIGHT BE SIMPLE
LIKE YOU SAID. MINE IS 19 YEARS OLD
AND I HAVE PARTS FOR ANOTHER 19.
May 19, 2009 | Acme 6001 Juice Extractor
Trying to find a part for the power juicer CL-003 AP
The top white part connects to the motor. You have to buy the whole bottom part. It's not separate.
Jan 09, 2009 | Jack Lalanne Power Juicer 250 Watts
Jack lalane juicer thread goes bad killing the juicer
DO NOT BUY THIS PRODUCT!!!! unless the plastic drive srew is replaced with a metal one.
Nov 24, 2008 | Jack Lalanne Power Juicer (Stainless...
Juicers Logo
26 people viewed this question
Top Black & Decker Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Black & Decker Juicer Expert? Answer questions, earn points and help others
