Question about Garden
What is the gas/oil mixture on a pioneer 1074 made in 1978
Gas /oil mixture on a pioneer 1074 chain saw made in 1978
    Guru:
  • 145 Answers
NOBODY will stick their neck out on this one. The original manual probably said 32:1, however the way I think about it is (most) two cycle engines haven't changed in 50 years. Only the oil has. I will leave it up to you to figure out. GOOD LUCK
Posted on Apr 13, 2014
Loringh
  • 185 Answers
SOURCE: Chain saw starts with starting fluid only but will not run.
Hi lwhssh:
Suggest you drain the fresh gas/oil and add a fresh batch but first add a gas stabilizer to your batch of gas/oil in the storage container. You will probably still need to use starting fluid for a few times When 2 cycle engines sit for a long period of time, the gas/oil mixture undergoes a change and tends to leave a residue on the delicate parts of the carb. The gas stabilizer will help that.
I always do the following for 2 cycle engines when I put them up for the winter. Empty the gas container on the device and then start it to use up any gas left in the fuel lines and carb. this keeps any residue from forming.
Hope this helps Good luck Loringh PS please leave a rating if appropriate. Thanks
Posted on Nov 29, 2008
highspeedsan
  • 61 Answers
SOURCE: What kind of oil do I use in the oil reservoir of my chain saw?
I believe the reservoir you are talking about is for the bar chain oil. You can get it most anywhere. As for mixing the gas and oil mixture, you will need 2 cycle oil. It is available most everywhere also. Most modern chain saws use a 50:1 mixing ratio which means 2 1/2 ounces of oil to 1 gallon of gas. Hope this helps.
Posted on Apr 26, 2009
SOURCE: Trying to determine gas-to-oil ratio on a chain saw.
Confirmation to #1: Recommended for all McCulloch chain saws at 40 to 1 ratio. 3 oz. per U.S. gal.
Posted on Jul 17, 2009
  • 583 Answers
SOURCE: Homelite Textron chain saw UT 10403A ...need
25to 1 and .025 thou
Posted on Aug 06, 2009
SOURCE: what is the gas/oil mixture for poulan wild thing chain saw?
I have a manual for that saw that says the mix is 40:1- 3.2 oz. of oil to 1 gal of gas .
Posted on Dec 10, 2009
Oil mixture wild thing
The oil mixture is 50-1 or 2.8 ounces per gallon of gas...
heatman101
Sep 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Every chain saw uses as fuel a mixture of oil and gasoline. What is the correct mixture for a textron gasoline powered saw?
25:1 to 32:1
Start at 25:1. If it smokes too much or fouls a plug, go to 32:1 using a good grade 2-cycle oil.
Sep 27, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Fuel mixture for MAC 3200 CHAIN SAW
Mix the oil to gas at a ratio of 50:1.The oil bottle will tell you how much oil and gas you need to get to that mixture.
May 11, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What is the gas/oil mixture for poulan wild thing chain saw? Thank You Roger
Dec 09, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
2.0 Cubic Inch Montgomery Ward gas chain saw, 10 inch cutting bar
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Lou
Oct 26, 2009 | Garden
What is the gas to oil ratio for the Ryobi 10532 18 inch chain saw?
Fuel/Oil Mixture
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 18, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Fuel Mixture Husqvarna 455 Rancher Chain Saw
Page 17 of your Operator's Manual says 50:1.
Fuel/Oil Mixture
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 25, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
What is the fuel mixture for a McCulloch Wild Cat 18 inch chain saw?
Fuel/Oil Mixture
  2. Today most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 25, 2009 | Garden
Apr 26, 2009 | Remington 16" Electric Chain Saw
Garden Logo
108 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
