Question about Montgomery Ward SP402TO Sewing Machine
It will not make a stitch
When sewing thin material it will not make a stitch it just goes in and out of fabric
    Champion:
    Habit-Forming:
  • 201 Answers
Hai, Please put the needle properly and choose the correct size needle.
Posted on Mar 22, 2014
My new machine sewed fine in cotton material, but I am having trouble sewing on a silky top.
Machine settings usually need to be re-adjusted when the project materials change, ie the needle size & type, the type/weight of thread, the presser foot pressure, the thread tension, the stitch length, etc. Sewing woven cotton is very different from sewing silk or chiffon. Test on scraps of the fabric before actually sewing on the garment. Even adding tissue paper to the stitching will help prevent fabric puckering.
Top 10 Tips for Sewing With Silk
How To Sew With Silk And Silklike Fabrics
Jul 05, 2017 | Sewing Machines
How do I set my Bernette 334D to overlock thin T-shirt material?
Thin, light-weight fabrics present some issues with sergers, ie the fabric tunnels with the stitching. Usually, it is better to use a narrow seam. Also, a stabilizer (wash-away) or even adding a strip of thin paper (toilet tissue, adding machine tape, etc) to the seam will help the fabric hold its shape when stitching. I have also sprayed & ironed heavy starch on thin fabrics to help stabilize.
sewing patternreview com
Serging Chiffon and Other Slippery Fabrics
Make It Handmade Understanding Your Serger Features
30 Best Tips for Sewing Knits with Serger Sewing Machine Serger Pepper
Jul 02, 2016 | Sewing Machines
Janome 7061NX pulls fabric into bobbin at beginning
I use a piece of tissue or thin paper to start the seam/zigzag. I've always thought the problem occurred most when I used llight weight or 'ravel prone' fabrics. I also took extra time to cut, not tear, the tissue off because the strenght of the tissue on delicate or fraying fabrics will literally pull the threads and fabric apart--a big problelm.
Sometimes I just got lazy and straight stitched a 1/2 inch until the fabric's vulnerable corner was firmly over the base plate. Then I changed to zigzag.
Apr 01, 2013 | Sewing Machines
Singer ce100 is skipping stitches when needle is in center position
You don't say what you are sewing so I'm going to give you general answers in hopes it helps.
1. Needles: There is no such thing as a universal needle. Make sure you are using the proper needle for your fabric. This goes for thread too... make sure it's sized for the needle.
2. Make sure the bobbin is threaded correctly (poorly wound bobbins will cause problems too)
3 Improperly threaded machine. Make sure you area threading it correctly with the foot in the UP position.
4. If you are a material puller... shop it. It is never good to pull your fabric through the machine as you sew.
5. Stitch length. simple rule: Fat fabric.. long stitch, fine/thin fabric short stitch.
I'm not familiar with your futura abut I've noticed new home machines take a way presser foot pressure adjustments... which can cause issues too.
Mar 13, 2013 | Singer CE-100 Futura Computerized Sewing...
Skipped stitches. Also, won't transition
have you checked the needle to make sure it's in correctly--flat side of needle goes to the back of the machine
correct needle insertion is mandatory for the proper use in your sewing machine. Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
place the new needle in the needle clamp with the flat side of the needle facing the back (or if using a round needle the groove in the needle should be facing away from the shaft.
push the needle all the way up to the stop, or as far as it will go, then tighten the needle clamp screw.
how to decide which needle is correct to sew with, it depends on the fabric & thread being used for the project.
like for example, I've been sewing for over 30 years, I'm sewing a stretchy fabric & regular needles won't work because they skip stitches & will pull the fabric thus damaging the fabric, the needle I have to use is a singer universal ball point needles, & I have no problem with the stitches they come out fine.
Sep 10, 2011 | Brother XL-2600
My zig zag stitch is puckering fabric. I even went to the multiple zig zag, same problem. I decreased tension. What should I have double. Note: this was on single layer, along edge of fabric so I could...
Check the bobbin tension too. It could be too tight. Make sure you are using the right size needle for the material as well. Sheer, thin fabric needs a smaller needle, thicker material requires bigger needles. Bobbin tension is the typical problem as most think to adjust the top tension but don't check the bobbin tension.
Is your quilt peices cotton? Cotton shouldn't cause as much trouble sewing along the edge but don't use too long of a stitch length else it will seem to gather up. Puckering side to side however is a tension problem usually. With sheerer fabrics that cause a problem sometimes you can put thin paper underneath, sew through both and then pull the paper off after sewing. (thin like the iron on type interfacing type fabric but like paper).
Mar 25, 2011 | Janome Sewing Machines
When attempting to sew rather thin material the main presser foot has not enough downward pressure to keep the material from sliding around. This is on a Singer 111W. Works fine on leather etc. I thought...
This machine was not designed to sew THIN material. It is an upholstery machine and it will never sew thin fabric very well. You can try a smaller needle(size 16 or less) and shorter stitches. There is also an adjustment to raise and lower the walking foot located on the backside of the machine. It can be recognized by the wing nut holding it in place and that it slides up and down when it is loose.
sewman7
Jul 14, 2008 | Singer 7462 Mechanical Sewing Machine
Montgomery Ward SP402TO Sewing Machine Logo
Top Montgomery Ward Sewing Machines Experts
D. E. Hev
DavidinClt
Level 1 Expert
Are you a Montgomery Ward Sewing Machine Expert? Answer questions, earn points and help others
