Question about Vacuums
Sem cambridge s360
Dear Sirs, I suspect the ion pump is not working properly. I may be wrong. The microscope was working fine before I vented the chamber. Prior to that, I have closed the isolation valve between the chamber and column. The chamber is working fine (10-6), but the column and gun vacuum weren't. When I open the isolation valves between column/chamber and column/gun, the pressure in the chamber was ok (not fluctuating). Does it means the ion pump is not working and did not pump the gun column to 10-7. I have waited for several hours with both isolation valves closed. Thank you. - Nikki-
SOURCE: Hoover model 6024-900 SteamVac
I replaced the water control solenoid and it cured the problem.
Posted on Jan 06, 2008
chrispurs1
  • 372 Answers
SOURCE: pressure relief valve opens
Hi.
If the hose works ok then you have A blockage in the section of the machine that goes from the brush roller to the wastebin.
Just remove the soleplate under the machine & check all the airways working back to the wastebin. definately check removeable inspection ports you will probably find omething in them blocking the airway.
http://dysonmanuals.llc.nu/
Posted on Jun 29, 2008
jackiaria
  • 350 Answers
SOURCE: Dyson Animal, lost suction and bypass valve seems to be loose
Dear terrygivens, 2-17-2009 4:12am EST (USA)
Most suction problems are caused by a clog from picking up something you probably didn't see or if you have pets an accumulation of pet hairs!
To clear it out take a metal coat hanger and unbend it til it's straight, then bend the end and tape it so when you push it through to unclog your vac it doesn't rip the hose.
Push the coat hanger in from the bottom brush area through the opening where the suction is. Also push it in and out anywhere else you can......You'll probably find something clogged....keep working it til it loosens and intermittently turn on the suction.
If you have a second vac with a hose, use that hose for suction on the clogged vac!
This should do it!
jack
Posted on Feb 17, 2009
  • 52 Answers
SOURCE: No suction from vacuum.
Blow out the filter with an air compressor if available. this is causing your problem. its usually a foam filter
Posted on Mar 26, 2009
  • 3 Answers
SOURCE: System will spray soap, but no water is mixed.
I had the same problem. After 3 weeks of seals belts pump etc. I was ready to give up.
The problem with mine as I suspect with others is the seal on the water tank.
The bottom plastic connector is not high enough to allow the water to flow to the pump.
My solution was to raise the bottom connector 3/16 of an inch.
I did this with a piece of plastic cut like a flat washer or auto gasket material could be used.
The connector must be removed from the bottom by pressing on the tabs. Hope this helps.
Posted on Apr 20, 2009
My dyson DC 59 Motorhead works fine for a period of time then just quits. The run time seems unusually short and does not slowly lose power but stops abruptly. What is the problem?
Modern lithium Ion rechargeable batteries don't slow down as they discharge, they run full appliance and then just boom they are dead. You need a new battery
Nov 30, 2016 | Dyson DC59 Motorhead Bagless Cordless...
I have a rug doctor blue machine. It will not spray anymore. Great suction. It is connected properly. Any suggestions?
Only two things can be wrong here, either the solution hose is plugged, kinked or undone from it's source, or the pump motor is not working. I'd try the hose first, if you can, take it off at the pump and then turn the machine on. If you get solution pumping out of the unit, then it's not the little pump motor and your problem is in the hose.
Oct 22, 2013 | Rug Doctor Mighty Pro X-3 Ready Pack...
Hello, I have a VZ-702M Lithium-Ion battery kit
Friend Dean,
A quick anonymous search of all the Web via the search terms [ buy VZ-702M battery] and the mighty mighty http://ixquick.com Privacy-Enforcing Meta-Search Engine from Heaven reveals on the first pass that URL
http://www.amazon.com/VariZoom-VZ-702M-Rechargeable-Lithium-Ion-Mounting/dp/B0010CDOV4
provides the item you seek @ $35.90 USD - with free shipping included - at least to US customers. Three in stock at lookup-time fwiw. YMMV re Amazon service due to your own location, of course - but I for one do tend to think Ixquick will doubtless prove productive for you too if so.
Good luck! (FINE monitor, btw.) And that is all. 0{;-)o[
Aug 16, 2013 | Vacuums
Electrolux d/w esl 6115,drains then fills and pumps straight and 50 degree light flashes all the time
NCORRECT PRODUCT CATEGORY
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category
Jun 29, 2012 | Vacuums
After a brief power outage my Marantec 4700 garage door opener has problems opening/closing. When opening it stops at the fully open position and the lights blink, when closing it automatically reverses...
This is not a sensor issue, I have a similar problem, sensors work fine, garage door is still fully functional, all operations, including safety sensors work properly, just the overhead lights flash. I suspect there was damage to the power board due to a power surge, going to order a replacement to see if it works, will let you know how it goes.
May 14, 2011 | Vacuums
Bissel pro heat wont dispense any water
these pumps always fail. try to replace the pump. also check for clogs in the spray nozzles and tubes
Feb 26, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissel proheat won't spray from bottom or attachment
Jan 27, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1770 Quicksteamer ii
Is the front nozzle fitted correctly, Is the tank seated correctly,
On the dirty water tank there is a sponge filter make sure this is clesn,
Nov 19, 2007 | Bissell 1770 Quicksteamer II Upright...
Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Oct 15, 2006 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
55 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
