Question about Acer Aspire 5720-6661 Notebook PC
This computer runs hot and turns off on its own frequently
  • 489 Answers
Need to clean dirty cooler system.
Posted on Jun 14, 2009
Model mmf49-1-w is freezing and thawing too frequently
Is the compressor getting hot while this is happening? Make sure all the fans are running strong check the capacitor and the start relay that may be causing this
APPLIANCE 911
Jun 04, 2016 | Refrigerators
C 320 mecedes the coolant fan keep runing without start the engine
When vehicles have electric cooling fans, the computer in the car may run the fan even when the car is off to try and help cool things. This happens frequently when parking after driving for a while when it's hot outside. It should turn off on it's own after a short period of time.
Feb 15, 2014 | 2001 - 2005 Mercedes-Benz C320 Bicycle...
Why is new ao smith pump getting hot
Most motors are warm to hot when running.
Is it getting so hot that the thermal overload is turning it off? If so the pump should restart once it cools down.
If this is a new motor on an old pump (replacement) it is likely to be:
1.) Incorrect or loose wire connections.
2.) Low voltage supply (frequently caused by undersized wire).
3.) Lack of fresh air supply to motor due to clogged vents.
4.) Incorrect amperage of replacement motor.
Jul 25, 2012 | AO Smith Pool Pump Motor Hayward Swimming...
The front of our refrigerator where the doors rest when closed is hot to the touch. Also, it seems to run more frequently. What could this mean?
the area the door rests on is normal to feel warm. it has a heater to keep it from getting condensation around the doors. Some models have a switch on the inside to turn this off. It usually says something like energy saver. As far as it running more frequently, Could be several things that would be hard to diagnose without seeing it.
Jun 18, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
1999 Hyndai Accent 1500 cc high cooling water temp.
over heating while stopped usually indicates that the radiator fan is not coming on ...when the engine is running hot you should be able to hear the fan running .. if it doesnt then suspect the thermal switch mounted on the radiator .. make sure the fan turns freely .. the fan is not needed when the car is moving so it wont heat up as long as you are driving .. but will do so when stopped if thats the trouble .. sometimes the thermal switch operates a relay that in turn operates the fan ..that could also cause the trouble ..
Jun 10, 2010 | 1999 Hyundai Accent
Very hot water then it kicks off and I have to frequently reset
Even though the water is very hot do you run out quickly? If so the problem is the 'dip tube' if not it is most likely the upper thermostat.
May 07, 2010 | RELIANCE ELECTRIC WATER HEATER
Power pack connection problem
Ok, you need to obtain another PSU, or you run the risk of ruining your laptop for good. I suspect, the cable,where it goes into, the socket, is fractured. In any event you DO need a correctly fitting adapter. Laptops can run very very hot, I personally experience that frequently. If at all worried, get a "Laptop Cooler Pad" they are an inexpensive."Tray" the laptop sits in, that has extra cooling fans to cool the entire thing down, they work very well. As for any adapter getting hot, they all do get quite hot, always ensure that a clear flow of air is all round the PSU, too.
Apr 15, 2010 | Computers & Internet
Just got a new hot water heater, the other one was 40 gal...this one is 50 gal...I got a bigger one because it seemed like I was running out of hot water...now I am still running out of hot water when only...
Typically, a timer is not used with a hot water heater unless someone planned on being away from the dwelling frequently and didn't want to run the heater.
Another possibility would be that the heater shares a circuit with something and can't be on at the same time.
Anyway, excepting the above, it's ok to not use the timer - the heater should have a thermostat to regulate the water temperature. The "normal" setting should be high enough.
Mar 14, 2010 | Intermatic Electric Water Heater Timer...
Computer is turning off frequently,automaticaly.
IF it is windows it is something to do with power management go to control panel and in power management disable the restart option and diable the hibernation mode too and in BIOS reset to default
Jul 02, 2009 | Computers & Internet
Starting problem when hot (occasinally when cold)
When this happens try opening the gas cap and retightening. Might be vapor lock.
Mar 19, 2009 | 1997 Plymouth Grand Voyager
Acer Aspire 5720-6661 Notebook PC Logo
99 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
