Question about Tablets & eReaders
Proscan error symbols
What does the battery with the caution sign mean?
What does a battery symbol with a red line mean. Won't turn on.
More than likely it means a dead battery. If it does not recharge, you will have to replace the battery with a new one.
Aug 14, 2015 | Amazon Kindle Fire HD 8.9"
What does the lightning bolt inside the battery symbol mean on the screen of the digiland tablet dl700. It wont charge
That symbol means that the tablet battery is plugged in and is supposed to be receiving charging voltage. If the battery is bad, it may not charge but the tablet will still work with the charger plugged in.
Feb 04, 2015 | Tablets & eReaders
My proscan tablet is saying battery with
meaning the battery is deffective....it cannot be charged..i suggest use a power bank...if you do not want to open your tablet and replace the battery...use powerbank instead. it is quite bulky and heavy, but it is worth using...when buying powerbanks, look for the highest mAh rating..Mah means miliampere hour...or the discharge value...the higher the value, the longer the time the battery is discharged
Oct 15, 2014 | Tablets & eReaders
Why does the battery level icon show only a "lightning strike" symbol?
Lightning Strike Symbol means that the battery is charging.
If it is shown even when it is not charging then your charging circuit needs to repaired. Just replace the charging IC not a very high cost. Might cost around 5-10USD.
May 24, 2014 | Amazon Kindle Paperwhite
My proscan tablet plt 8031 was picking up my wifi and now it isn't
Go to the wi fi screen.
Access the network.
Use the forget and then sign in again with your password and connect.
Feb 22, 2014 | Proscan Recertified - PLT7035 4GB NAND...
Help how do hard reset my proscan tablet plt7035 i for got my pattern to unlock it
1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5. Navigate to Erase content.
All info on tablet will be deleted but not the info in the SD card
The tablet will complete the hard reset process and reboot into a factory default state.
Oct 19, 2013 | Proscan Recertified - PLT7035 4GB NAND...
My Samsung galaxy tablet 7.0 died out while im playing a game, when I tried to recharge it a battery icon with caution sign show up. It does not recharge anymore. Tried another charger of my other Samsung...
Connection on tablet from charger to battery is not being made and that is why it is not charging in one unit but charging in other. Till problem is resolved charge battery in other working unit.
Aug 28, 2017 | Tablets & eReaders
Our motorolaom is set to chinesewe cannot unerstand the options needed to change it to enish?
mine was like this.
Switch on
At top right hand corner there is a + sign. The chinese next to it means apps. Press
This should bring up the page with symbols. Rond symbol with blue ring inside is settings possibly 3 line 6th symbol along. press
4th line up from bottom has a "a" press. This is language. should give you the english option. Good luck
Sep 29, 2011 | Motorola Mobility XOOM Android Tablet
Tablets & eReaders Logo
19 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
