Question about Superex Electronics - Others
Superex 2500 watt power inverter manual
I brought a 2004 5th wheel with a Superex 2500w inverter and would like to obtain a manual for it. Is there any website where I can download one?
4 Suggested Answers
  • 3382 Answers
SOURCE: 2500 watt inverter 6 months old is starting to
It sounds like the fan is failing.
Good Luck,
Gilshultz
Posted on Dec 03, 2009
  • 4 Answers
SOURCE: power inverter
There are 8 40A fuses inside this unit. In the following pics you will see a bank of 4 and another bank with 3 of the 4 removed. I'm currently working on mine as it will cost me more to ship and have Cobra repair than I paid for the unit ($133 to repair). Good luck with your problem
Posted on Aug 24, 2010
  • 41 Answers
SOURCE: 2500 superex hooked up to 12v ,has a squeal when I turn a hair dryer, and the volt meader drops from 12v down alot
Is the unit hooked up in a vehicle? If it is, try increasing the engine rpm a little bit to bring the voltage back up. Sounds like the hair dryer is overloading the inverter.
Posted on Jan 02, 2014
I have a Superex 100W power inverter. I want to see if I can plug into cig lighter then a standard extension cord and lamp into it
In order to produce 100 watts at 120 volts, the current will be 1.2 amps. But if you are producing that power from 12 volts input, the current will be at least 10 times the output current, and that would be at 100% efficiency, which is impossible to achieve, The efficiency could be assumed to be around 70% though, meaning that the current input required to produce 100 watts at the output would be somewhere around 13 amps. That's a lot of continuous power drawn from a cig. lighter, and the load might blow the fuse or breaker for that circuit.
Dec 29, 2016 | Superex Electronics - Others
How to recharge superex jumpstart/compressor
Plug in the cord with the switch off. If the battery is still good in the unit then it will take a full day to charge. If you charge it for a full day and you still have nothing the battery is bad. If this is a new unit, check to see if it is under warranty.
Sep 06, 2014 | Superex Canada Ltd Emergency Jumpstart...
Jan 02, 2014 | Superex 50-373 2500 Watt 12 Volt to 110...
What is the size of the glass fuse for the 59-204 400W power inverter ?
Hi
If it is the secondary fuse it would be 3.15amp or 4amp
Regards
Jan 31, 2011 | Superex #59-204 400W DC Power Inverter
Whatwire size shoulds I use on my 2500 watt inverter
I would use a minimum of #4 copper. I would get this as a welding cable type because of its flexibility. #2 size is a better choice if you plan on using the inverter for long periods of time.
joe
Jan 26, 2011 | Cobra 2500w Power Inverter
Can a 2500 watt inverter run a 5000 btu air condition?
5000 btu consumes about 500 - 700 W in cooling and obviously it should be running from 2500 W inverter.
It is obviously, but the conditioner has a compressor which needs some more (about 2, 3 times the rated) starting power, which is in it's bigger part reactive power which is not produced by the inverter and depends on the output condensers of the inverter.
It should be tested, and if the start is difficult some more condensers may be added.
Jul 17, 2010 | Cobra 2500w Power Inverter
Have several non working inverters
I have had this happen a few times.
Sadly replacement is the Best option.
Repairs can be %75 the cost of a new one.
The best invert we have been using is a Pure Sine 1500 watt inverter.
Sad news but hope this tip helps.
R/
David
Jan 09, 2010 | RoadPro RPPI-2500W Inverter
I just bought a RoadPro 2500 and i want to buy like a dorm fridge how many watts or volts size would work??
If you are referring to the RoadPro RPPI-250
  • 2000 Watts Continuous Power
  • 2500 Watts Power Output @ 10 Minutes
  • 5000 Watts Peak Power Output.
  • A small fridge will use about 500 -700 watts, with startup wattage at around 2000watts.
  • So, a dorm fridge will work fine.
  • the RoadPro converts DC to AC voltage, so a regular 120 volt dorm fridge will work.
  • Jul 05, 2009 | RoadPro RPPI-2500W Inverter
    Power inverter
    Jun 18, 2009 | Cobra 2500w Power Inverter
    Electronics - Others Logo
    Top Superex Electronics - Others Experts
    Are you a Superex Electronics - Other Expert? Answer questions, earn points and help others
