Question about Samsung Cell Phones
Wi-Fi connection signal strong won't connect
    Master:
  • 397 Answers
Sometimes the type of security used by the wifi network can case these issues. Try changing the type of security used by the network.
Posted on Mar 21, 2014
SOURCE: itouch wi-fi connection problem
Try this one : http://wiredforgadgets.com/?p=743. It worked for me.
Posted on Apr 18, 2008
tinualbinale
  • 436 Answers
SOURCE: Im connecting to my home WI fi and it says authentication failed
You will be asked for a password only if you are connecting to a password protected WiFi network.You can set a password for your Home WiFi modem and after that you have to enter the password whenever you try to connect.
Posted on Sep 12, 2009
darkpain
  • 316 Answers
SOURCE: I can't connect to my wi-fi settings
Activate and connect to a WLAN
1.In range of WLAN network, access an application or menu that needs a wireless connection.
2.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
3.Press <Menu> → Turn On Wi-Fi.
The device will display available WLAN connections.
4.Select a network profile from the list.
The device will attempt to connect to the WLAN.
5.Select a network type and press <Next>.
6.Enter a pre-shared key for WLAN and press <Next> or <Finish>.
7.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type and press <Finish> (if necessary).
Create a new WLAN
1.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
2.Select New...
3.Enter a network name, configure connection settings, and press <Next>.
4.Enter network authentication settings and press <Next>.
5.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type (if necessary).
6.When you are finished, press <Finish>.
Posted on Jan 08, 2010
SOURCE: LG Renoir wi-fi connection failure
When i try to turn on my wifi my Lg Renoir restarts ! Any suggestions on how to solve this ?
John
Posted on Jul 03, 2010
gaganddun
  • 114 Answers
SOURCE: I had recently purchased Samsung
Dear Meghna you have not mentioned the wifi router make and moel
no problem
for this you have to go to your router web admin to add your device as WPS client this will solve the problem
for that all the models are differently configured so you have to try playing with the settings yourself, if you jumble up the settings of you wifi router there is a reset switch in all the routers that restors your router to factory settings.
if you find my information useful dont forget to vote me with the thumbsup thankyou and take care Gagan Gupta
Posted on Mar 15, 2011
I can't access the kindle store
Are you out of your usual wi-fi area? You may need to go back and check wi-fi settings and set up again.
From Home or any Settings screen, view the wireless indicators at the upper right corner of your Kindle. While reading, tap the top of the screen to view the wireless indicators.
Wireless Indicator Description Your Kindle is connected to 3G. This may also say EDGE or GPRS.
Note: For 3G enabled devices only Your Kindle is connected to a Wi-Fi network and has a strong signal. The Wi-Fi symbol appears when in range of a trusted Wi-Fi network.
Dec 10, 2016 | Amazon Tablets & eReaders
Tip
How to Speed Up Internet on my Touch Pro 2?
<p>The HTC Touch Pro smartphone 2 is avaialble for T-Mobile and Sprint subscribers, and uses the data network cell phone to connect to the Internet. While the Internet connection is based on a strong 3G connection for fast browsing, you can also activate the Wi-Fi device to connect to a wireless network. Available Wi-Fi networks within range of the Touch Pro will be displayed on the device are on the list of networks. Once connected, your Internet speed is capable of data based on the strength of the wireless signal to send. <br /> <p><br /> <p>1. Slide your finger on the "Home" screen to the tab "Settings" appears. Play the "Communications" button. <br /> <p><br /> <p>2. Touch "Wi-Fi" on the phone screen, then hit the wireless network is displayed in the "Discovered Networks" list. <br /> <p><br /> <p>3. Type the network security key using the onscreen keyboard, and press "Done" for the network to connect. A wireless signal appears at the top of your phone screen when connected to Wi-Fi network successfully <br /> <p>4. Touch "Back" to return to the "Communications" menu. <br /> <p><br /> <p>5. Play the "ON / OFF" in "communication" from the menu for Wi-Fi off. It is important to turn off the Wi-Fi functionality when not connected to a wireless network, because this mode the battery is not on. <br />
on Aug 09, 2011 | Apple iPod touch
I can't get get my Google account to go threw keeps connection isn't strong enough which I have max strength wifi?
can you log into your wi fi router admin account ?
Can you try changing the channel from auto to say 3 channel numbers higher than the lowest channel number available . This is in case you have neighbors with wi fi that might be interfering with your wi fi signal .
Nov 18, 2016 | Tablets & eReaders
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
Wifi will not connect
The below info is from user manual ... downloadable version @ www.pantech.com
Connectivity
This chapter introduces useful tips on how to connect to the
network available that enables applications of the phone to
run.
Using a Wi-Fi network
Connecting to a Wi-Fi network
1. Tap Settings from the applications menu.
2. Tap Wireless & networks > Wi-Fi settings.
3. Tap Wi-Fi to activate the technology.
4. Select and tap a network. You should enter the password
if the network is secured. indicates a secured Wi-Fi
network.
5. Tap Connect. Once the network is remembered, the phone
will automatically connect to it when in range.
Activating Wi-FI Connecting to a Wi-Fi
network
Note The icon next to each network indicates the strength of the
signal. For example, indicates the signal is poor while indicates
the signal is strong.
Using the Easy Setting
1. Tap on the top of the home screen and drag it down, or
press n in idle mode and tap Notifications.
2. Tap in Easy Setting. The icon turns red when the
function is on.
About network notifications
You are informed by default when a Wi-Fi network is available
around you. The message in the status bar indicates a
network is available. Tap Network notification in the Wi-Fi
settings if you do not want to be informed the availability of the
network.
Setting Wi-Fi networks
4. Tap Network notification if you want to know an open
network available.
5. Tap Automatic connection if you want the phone to
connect to Wi-Fi network automatically.
6. Tap WPS button connection if you want to establish a
new wireless connection using the Wi-Fi Protected Setup
(WPS). You should press WPS button on your Wi-Fi access
point within two minutes.
Searching for Wi-Fi networks
Jan 17, 2013 | Pantech Pocket
Wi-fi won't connect, how do I fix it
have you had a fire or burglar alarm fitted recently? the signal emitted (even when off) can scramble the wi-fi.
Aug 06, 2012 | Apple iPhone 4S
I can't get wi fi on my psp
try puting the wep code or call the router company and ask for wi fi assistance
Jun 06, 2009 | Sony PlayStation Portable (PSP) Console
Wi-fi connection
When Safari says it can not find the server it means it can not find a good or strong enough wi-fi connection. The sever is basicaly just a wi-fi connection that you connect to. You need to find a good connection in order to get on wi-fi.
May 21, 2008 | Apple iPod touch
Cell Phones Logo
14 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
