Circuit nad 6325
Tape does not play: it rattles some and then stops. Fast forward and fast backward is OK.
  • Sander Stols
    Sander Stols Mar 23, 2014
    There isn't really much to add. The unit hasn't been used for a considerable period.
  • Sander Stols
    The problem showed immediately after an attempt to use the deck again. The amplifier seems allright: an input signal causes the level indicators to flash as expected. I removed the cover to look inside and the large wheel with the rubber band around it turns for a while when I push the Play button but stops soon after.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
Replace ALL belts in the deck (there are 3) the deck is sensing that the tape reels aren't moving and protecting it. that should solve your problem. do not use elastic bands, they will foul and destroy the gear driving the capstan.
Posted on Mar 24, 2014
Testimonial: "Thanks for the advice. I can't tell yet if your solution will help."
How do I change the volume?
The button functions change according to whether you have a tape inserted.
Aug 08, 2015 | Car Audio & Video
Bush vcr 925nsil Er01
There is a cam to load the tape, and it sounds like that is shot. Probably easier to buy another VCR at a resale shop. Sorry.
Sep 07, 2014 | Televison & Video
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
May 11, 2012 | Panasonic Pv-9661 Omnivision 4-head Hi-fi...
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
Deck plays forward, fast forward and fast reverse O.K., but does not play backwards.
I don't have any quick answers as this is a newer deck than when I worked for the company- I would have to see the deck to determine the fault. Do you have the continuous reverse switch on -maybe that is it.
Oct 19, 2010 | Teac R-H300 Dual Cassette Deck
Camera plays in fast forward-like speed
Though I don't know the details of your camera and the tape you are playing, one explanation could be that the tape was recorded in "extended play" EP rather than "standard play" SP. Some VCRs and some cameras are incapable of playing back in EP, a mode where the tape moves at half speed so you can record more on the same tape. The result is that the tape playing back at regular speed appears twice as fast and fast forward will be even faster.
Unfortunately, unless your machine can be manually set to play back in EP (usually it is automatic) the solution is to play it back in a machine that can handle EP.
Dec 04, 2008 | Electronics - Others
VCR sv 670 wont play or fast forward tapes.
Open the bottom Cover, and check the belts.
Nov 29, 2008 | Samsung SV3000W VHS VCR
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Aug 28, 2006 | Quasar VV-2002 20 in. TV/VCR Combo
Can't fast forward the tape
For Models: CC6254, CC6364, CC6374, CC6384, CC6394 The Counter Memory function, which makes it easier to locate a specific tape segment, has been activated. To disable, press COUNTER R/M for less than one second until M disappears. The tape may also stop because it has reached the beginning or end of the tape, depending of course on whether you are fast-forwarding or rewinding.
Sep 06, 2005 | RCA CC-432 Camcorder
44 people viewed this question
 Grubhead
Grubhead
