Question about Shoprider Dasher 4 Adult Scooter
Slow speed slows down then back to normal for no reason, changed speed control pot, no difference.
  • Shoprider Master
  • 1,263 Answers
Hi what happening to the battery power indicator while this happens ?
if you are sure the batteries are okay , look at the connections to the rear axle, making sure they are a good clean connection, you be amazed the problems with those connectors...
1. Motor breaking down.. ( Resistance changing ), Brush less motor otherwise check the brushes...
2.Brake coming on so slowing the scooter down.
3.The output stage of the controller is breaking down....
Regards
Rob
www.gewizrepairs.co.uk
Posted on Mar 21, 2014
Why did the oval black insert pot of my everstar slow cooker lose the entire bottom of the pot while cooking?
no reasonable explanation as it is very unusual
could have been cracked or a fault in manufacture
check for warranty and if covered take it back
if not buy a different brand
Jul 31, 2016 | Crock Pots & Slow Cookers
I have a pride classic xl8 i will be go along at top speed and then for no apparent reason it starts to go slow then quick then slow
This could be something to do with the HI-LOW speed switch or the connections on it or back to the control unit. Check for loose connections first. If you have a meter, check the resistance across the Hi-LOW switch.
Nov 13, 2014 | Health & Beauty
Invacare meteor, keeps slowing down, then speeds up again, can you help.
usual cause of this is the throttle (wig-wag ) controll potentiometer has worn out.to test put the scooter against a wall and get a freind to lift up the rear of the scooter and put 2 large blocks of wood underneath it so the back wheels can rotate
carefully advance the throttle 1/2 way then with wheels turning.keep in same position and gently move the throttle lever up and down .if there is a lot of play and the speed varies drasticaly then pot replacement reqd .you can get a dealer to order the correct one or get one off the internett but when fittinf if thr pot is not set to exact center with multimeter scooter will not move and produce off center error code
Sep 27, 2014 | Invacare Health & Beauty
PRIDE CELEBRITY DX RUNNING SLOW
Hi
Please Check your Potientiometer also known as a Pot, This is your Speed Control and it may be on the way out after 4 Years ,
My Own Pot Packed up after 11 Months, Try to get a Second hand one as they are Expensive to buy,
Good Luck, Gerry.
Jul 19, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
I HAVE A CELEBRITY DX SCOOTER, IT IS 4 YEARS OLD. I HAVE HAD NEW BATTERIES FITTED, BUT THIS LAST 3 MONTHS THE SCOOTER RUNS FROM NORMAL SPEED TO SLOW AND SLUGGISH THEN BACK TO NORMAL EVERY FEW MINUTES.CAN...
Hi John.
The problem could be a worn throttle pot ( wig wag ). Next time you are driving the scooter, try moving the ends of the speed lever slowly up and down, instead of in or out as you normally use it. If the throttle pot is worn, moving the lever this way will make the machine speed up or slow down.
Another cause might be a faulty battery lead connector or a faulty motor connector.
Good luck. Neil.
Jul 05, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
New battery. hooked up correctly. But, scooter will still barely go in reverse super slow. forward speed slow .can throttle cable be problem/ when I push inside of speed lever it moves faster. pushing ends...
Hi. Did the machine used to operate properly in the past? Sometimes previous owners or technicians have changed the programme for owners for different uses. What you describe sounds like a faulty throttle pot ( Wig Wag ). I have changed many throttle pots for this reason.
Also check battery and motor connectors.
Do you have another switch on the machine for controlling the speed, such as an indoor/outdoor switch? Good luck. Neil.
May 12, 2010 | Activeforever Lynx L4 Portable Mobility 4...
My shoprider cobra loses speed when I am on top speed.
Hi. Does the machine do this more soon after removing the machine off the charger? When a mobility scooter is going down hill, the controller feeds the voltage generated by the motor back into the batteries. When I an testing machines here at the workshop, I have seen cases where 10 to 12 amps is going back into the batteries on a down hill run. If the batteries are fully charged or unable to take much current, the controller slows the scooter right down to limit the higher voltage generated.
It might pay to check the battery leads and connectors as well, and get the batteries tested.
While you are driving along, try moving the speed lever slowly up and down, not in and out as you normally use it. Sometimes a faulty speed pot ( wig wag ) will cause the speed to change.
Good luck. Neil.
Feb 14, 2010 | Shoprider Sprinter Jumbo 3
I have a Pride Legnd..the scooter started loseing speed, I would adj the speed pot and the unit would stop, adjust back down and unit would run, but slow. I left the speed speed controller alone and unit...
hi, first you need to check the connections to the batteries then to the motor controller, and don't dismiss the speed pot, disconnect the speed pot and try a normal 5K pot inplace of it, if the scooters responds you find the problem just a case of getting the right speed pot. Check the freewheel switch, normally it located on the motor side.
Regards
GeWiz.
Dec 15, 2009 | Pride Mobility Victory 3 Wheel Electric...
Power problem
throttle pot or loose hex nut that holds the actual forward and reverse paddle, may be slipping
Dec 20, 2008 | Pride New Mobility Rally 4 Wheel Scooter
Wiper Speed changes from slow to fast then back to slow without moving switch!
the reason for your wiper speed change is due to the rain sensor which controls the speed of your wipers,determined by how much rain is comming down.the rain sensor is located behind your rear view mirror.
Sep 27, 2008 | 1997 Buick Park Avenue
Shoprider Dasher 4 Adult Scooter Logo
149 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
