Won't drain (or spin)
Kenmore model 119.92962101 - I understand it won't spin till drained, agitator works on wash so drive is probably OK, but what should I look for when I get the back open, drain valve solenoid or pump? I thought it might be the timer but I changed it and no joy there. The timer doesn't seem to advance past wash. Is that caused by the failure to drain? If I manually advance it I hear nothing, 1 click but no humming from the pump at all.
    Problem Solver:
  • 6 Answers
It may be as simple as a clogged drain pipe. The sludge from the solid waste grinders in a lot of the new washers will coat and clog the tube.
Posted on Mar 21, 2014
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
I have a kenmore model 20422991 washing machine it wont agitate spin or drain but i can here the motor running
Thanks for choosing FixYa and welcome. Your drive motor controls the spinning, agitation, and draining. Even though it is running, the transmission may be bad. Replace the motor drive if this is the case.
Apr 02, 2011 | Kenmore 22422 Top Load Washer
End of wash cycle, no draining or spinning, but can move to rinse cycle and it agitates again, no spinning after rinse either
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The drain and spin functions are started when the timer advances to the spin mode.
The motor is reversible. When agitating, the motor spins one way, when going to the drain / spin mode it reverses.
Since the machine agitates, the problem points to the timer.
Sep 04, 2009 | Kenmore Washing Machines
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 24732 will fill and drain but will not agitate or spin
HI, Even tho it drains ok, does it spin? If it doesn't spin or agitate, it could be the coupler that attachec the transmission to the motor.The agitator is ok, it is designed to work that way. Please let me know if I can assist you further.
Thanks
Vic
May 17, 2009 | Kenmore 24732 Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
2,342 people viewed this question
Top Washing Machines Experts
