Question about Hoover Vacuums
Whirlpool owners manual
I dont know how to get my hose off my upright hoover to use it,it was given to us after a friend passed away but there is no manual,thank you. model no:wh52101 001 serial no:39100272 1212 0363
It seems from the ones that I have worked on it should just twist or there will be a buton if it is twist you simply twist it until you hear it pop and it should pull out
Posted on Mar 21, 2014
  • Anonymous Mar 21, 2014
    you may have to pry it out with a flat head screw driver that is very common
  • Cheryl Thurston
    Cheryl Thurston Mar 21, 2014
    Thank you my boyfriend figured it out in the end,thank you for answering my question
Agent Don
  • 310 Answers
SOURCE: Tear in Eureka Upright "The Boss" 4870
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=652524
Posted by kdunnett on Jun 07, 2008
I have a tear in the hose of an upright Eureka "The Boss" 4870 vacuum. I cannot find how to release the parts I need to get the hose out and put in a new hose (which I already have) I've searched the Eureka site and the owner's manual - nothing about how to replace the hose itself. Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. In answer to your question, the owner’s manual may or may not give an example to install the hose only, but on most vacuums the hose sometimes will screw in to the hose cuff on both ends unless if it is a hose assm then it will then twist and turn. Check with the
Eureka website and have them send out a schematic and owner’s manual for you so that you can install your hose properly. Sometimes you have to place hose glue on the end of each side in order for the hose to screw in properly. the website address will be listed below and they certainly should supply you with the owners’ manual and maybe a schematic of the parts breakdown that also may help. If not; check with your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 10, 2008
  • 389 Answers
SOURCE: can't get bottom plate off hoover model
Am a bit confused because I can't find the model number you give on the Hoover website, so am not sure exactly which machine we're dealing with. However, the procedure for removing the bottom plate is common to most self-propelled upright wind-tunnel models, and it's simply a matter of laying the machine flat, turning it over and removing the four recessed screws that hold it in place. It can then just be lifted off. If this doesn't work for you, perhaps you could confirm the model number and I'll try again. It will also help if you say what country you're in. Good luck!
Posted on Feb 28, 2009
SOURCE: hoover u5209-906 upright
1. You have to lay it on its front so you can unscrew the two screws in the underside (these are on the plastic panel covering the brush). There are also two holes for you to use a screwdriver in right next to each screwhole. Lever the plastic tabs in the direction indicated next to the holes (I think it is towards the motor). This case should then click up and away N.B. There are 3 tabs fixed into the cover on the front edge of the vacuum head. Be sure you don't snap these off.
2. You then need to use the foot pedal at the back of the vacuum to lay it flat and using a flat bladed screwdriver lever the top cover of the head away from the frame on the two back side corners and across the front of the head. The top case should now be able to come off.
3. The belt should now be able to slip off the motor spindle and off the brush.
Repeat the procedure in reverse once the new belt is on.
Cheers.
Posted on Apr 11, 2009
CorvetteKing
  • 108 Answers
SOURCE: lost manual for hoover steam vac
You can find that manual on hoovers website (hoover.com) it is under customer service/parts.
Best of Luck
Posted on Jun 14, 2009
  • 190 Answers
SOURCE: user/owner manual for Hoover F5887-900
This is not the exact manual, but should help you out on nearly all questions:
http://www.hoover.com/pdfs/manuals/F5857955.pdf
Posted on Jan 02, 2010
I do not know how to use the upholstery part to work
hi,
the owners manual is here at this link,
http://www.hoover.com/pdfs/manuals/F5807.pdf
I believe for you to work the upholstery tool the suction tank lid must come off, and the center channel there has to come out for the hose to go into, and then replace the suction tank lid again.
there should also be a second water hose to connect midway down the left side of the unit there little square push/pop out lever. the water hose will connect there and you should be good to go from there. Refer to the manual for the exact directions tho.
Nov 04, 2010 | Hoover SteamVac F5914-900 SpinScrub...
How to remove attachment hose to unplug
The vacuum to the dirt cup, whether from the floor, or from the tools comes solely thru the hose. You need to check the hose for internal obstructions/blockage, from the open end all the way to the entry to the dirt cup. Here is the link to the Product Manual: http://www.hoover.com/pdfs/manuals/U5172900.pdf
I recall the hose connects to the back of the unit with a 1/4 turn lock. so try to turn the hose collar at that connection 1/4 turn counterclockwise, then pull it off. If any other qustions, let me know.
Oct 16, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
How to attach the stair scrubber attachment?
The following Owners Manual shows the use of the product and acceessories:
http://www.hoover.com/pdfs/manuals/F5914900.pdf
The accessory just slides on to the end of the hose.
Sep 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Lost manual for hoover steam vac
Best of Luck
Jun 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Need to replace belt
Please go to this link on my business web site for instructions on changing your belt: http://www.sewvac1.com/Hoover_U5162_900.pdf
May 07, 2009 | Hoover Fold Away U5162-900 Bagless Upright...
Internal flex suction hose is leaking
The hose where it hooks to the motor unit usually splits there, if this what you are talking about, then you can replace the hose asm. Part # H-90001336
You can go to http://vacuumsuperstore.com/
and order it thru them, or call a local service shop.
$36.00 tableWorkaround2(1)
May 26, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Water Uptake Hose Split
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=602269
Posted by jre8655 on May 16, 2008
How do you remove and replace the Water Uptake Hose Assembly?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website www.hoover.com . I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 16, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Vacuums Logo
23 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
