How do I remove drumfrom LG WF T7014PP fuzzy logic washing machine
THE NUT ON SHAFT IS REMOVED NOW I WANT TO PLEASE KNOW HOW TO REMOVE DRUM
SOURCE: LG FUZZY LOGIC
Are you sure it is the bowl and not inside the pump with the impellar hitting it on spin cycle? I just had the same problem and had to remove a dime from inside the pump.
Posted on Oct 10, 2008
  • 410 Answers
SOURCE: I want to remove my LG Fuzzy Logic WF-T8018Tp
.I am not a repair professional. I am a 78 year old man
who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Dec 02, 2009
beltronic205
  • 1474 Answers
SOURCE: LG Washing Machine front loading, Model Fuzzy Logic 8.5KG,
If it has a belt remove this then turn drum by hand to see if noise is still present if it is then sounds like some thing caught in between drun inner and outer you may need engineer....Pull plug out 1st...
Posted on Mar 22, 2010
SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Posted on May 22, 2011
  • 5343 Answers
SOURCE: Lost manual to LG washing
I do not know this model. However, on other top load LG washers, the powdered detergent goes in a box at the back (top) of the washer, and the fabric softener when diluted gets poured into a spot near the left side of the top of the washer. (The bleach goes near the front of the washer.) For front-loading washers, the detergent and fabric softener are poured into the detergent drawer. The largest compartment is for detergent (wash cycle) and is usually on the left. The smallest compartment is for fabric softener.
Manuals for most LG appliances are available at their site. Start at http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WF-T502C&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WF-T502C&initialTab=documents&targetPage=support-product-profile . The manual is in a DjVu format.
A partial manual is also available here: http://monitor.diplo-best.com/review/LG/WF-T502C . You will need to review the washer or enter a code.
I hope this helps.
Posted on Jun 13, 2011
Can you remove the drum from lg fuzzy logic WF-T65T1 to get rid of mouldy smell
It is a big job. Why did you use vinegar and bicarbonate of soda? They cancel each other out. The drum is stainless steel, it can't smell. The smell is from mold on the rubber pipes and in particular the door gasket.
Put 2 cups of bleach in the machine and a couple of white towels or a load of white tea towels. Run the hottest wash for the longest time.
After you do a wash, dry the door seal and leave the door open for a couple of hours so everything dries out..
If it persists, get an engineer to replace the door gasket. Then keep it clean and dry.
Dec 18, 2017 | LG Washing Machines
How to remove the agitator in order to clean the bowl?
To remove agitators on these models, this fastening bolt must first be removed. To access the bolt, remove the cap at the top of the agitator - this can usually be done either by hand or by prying with a screwdriver. Take care if the cap is glued down
Jan 05, 2017 | Washing Machines
My toploader machine is not rinsing or spinning the model is a LG Fuzzy logic WF-T7014pp
if it does not rinse its a different case,,,,,nd if it does not spin is another ,,,check on the door lid,its a magnet,,,,,,,,,,,,,,,,,attached the washer pic ,,,so i can tell u what to do............
if u have a magnet tryputting it between the door and its main program board,,,centre nd try
Jan 23, 2015 | LG Washing Machines
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
Lg fuzzy logic model wf-t7014pp. seems like spinner belt is worn, loose, how do i replace it or tighten the belt
plz replace the belt if it is worn ..its better to take preventive maintenance than breakdown maintenance
Aug 18, 2011 | LG Washing Machines
My LG Fuzzy Logic WF-1011STP rotating plate has come loose!
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
Apr 07, 2010 | LG Washing Machines
Mar 22, 2010 | Washing Machines
LG FUZZY LOGIC
Sep 22, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
