Question about Heavy Duty Arrow Et501 Electric Staplenail Gun
Fires Only Once
I plug it in to use it and it will only shoot once. Then regardless of what I do it will not shoot again. Unplug it and wait a day or so and it will do the same thing again, only shoot once.
My internet not working to good goes in and shoots it self off plus I want to closes some tabs
First try to close as many apps as you can on the device and try again. When you are connected to a wifi router, it could be helpful to unplug it for 30 seconds and then plug it in again, or when you can see the reset button, press it once (short) then wait about one minute and every thing should work again.
Oct 15, 2014 | Ultimake MyPhone+
Error E000
unplug the unit for just 1 day, or you can fuse near the powersupply area if you have access into the inside parts.. but first try to unplug the unit for a day to remove the last settings you made..
let me know
Aug 08, 2008 | Canon ImageClass D880 Copier
DnS Error (80710101) means you have a faulty or wrong IP address.The problem usually lies in the router.Here is how I would go about fixing this problem.1.unplug the power to your modem2.unplug the power to your router (assuming you have router+modem setup, otherwise just unplug the modem)3.count to 40
4.plug in the modem and wait for it to completely boot back up
5.plug in the router (again assuming you have both) and wait for it to boot back up
6.try signing in again
I get this every once in a while and that is how i fix it.
Aug 14, 2012 | Sony Playstation 3 (PS3) Console
The tv quit responding to the remote
On this unit if you do a fact reset it should fix this problem steps as follows. PS you might need 2 people
1- unplug power cord from back of TV
2- on the key pad on the tv hold the input and vol dowm buttons
3- while holding the buttons plug the tv in, keep holding the buttons until the screen comes up.
4- once the screen is up there should be a white K in a blue or green box.
5- next, on the key pad on the tv press the channel and vol down buttons once.
6- a menu should pop up
7- using the sharp remote,locate the directional pad
8- press the down button once should bring you to a 2nd page
9- top should state FACT INIT press the right arrow once to turn on, next a series of back slashes come up.
10- screen goes green and says INIT Successful
11- unplug power cord from back of tv wait 10 sec then plug back in. tv should turn on by itself. should be back to as new.
Mar 19, 2009 | Sharp LC52D65U 52 in. LCD TV
Nail gun double fires
There is one main part that can be the cause of the problem.
The trigger. Check to see if there is anything out of the ordinary with this. There should be some moving components attached to the trigger itself. Is any part of the trigger touching the button in the body of the gun when safety is not depressed. If the lever on the trigger is pushing on the button, even a little bit, It will allow the gun to fire again and again.
Mar 12, 2009 | Air Tools & Compressors
All pro 115k
This sounds like you will need to replace the thermostat!
That should fix this common problem!
Dec 20, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
6 yr old mower starts, won't run
sounds like a plugged high speed jet in carb - you can attempt to prime again , push at least 7-8 times - once it fires continue to push primer to keep running - it may clear out the carb if this doesnt work the carb will need to be removed and cleaned
Sep 27, 2008 | Garden
T.V. problems
  • do not worry.
  • just put it on for the whole day till you are at home.if any moisture is there it will dry out.
  • it may give you problem two or three times but it will be ok.
  • good luck.
Oct 12, 2007 | RCA TruFlat 27F520T 27" TV
Heavy Duty Arrow Et501  Electric Staplenail Gun Logo
43 people viewed this question
Top Heavy Duty Tools & Hardware - Others Experts
yoopertech
Paul Carew
Joseph Hoffmann
Are you a Heavy Duty Tool and Hardware - Other Expert? Answer questions, earn points and help others
