Indoor unit and out door unit not start
E6 error
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
E6 usually means that there is a communication problem between the indoor unit and the outdoor unit. This could be due to a wiring problem or maybe you had a momentary drop in the voltage. Find the circuit breaker in the circuit breaker panel for your home/office that is connected to the A/C unit. Turn it off and back on and try using the A/C again. Sometimes the indoor unit is connected to one circuit breaker and the outdoor unit is connected to another one. Make sure you have disconnected and reconnected both before running your unit. If that does not solve the problem you may need to have some cable replaced between both units.
Posted on Mar 21, 2014
5 Suggested Answers
  • 5 Answers
SOURCE: Hitachi ras-5h gse
first: The compressor is deffective
second: Fan capacitor is deffective
3rd: Running capacitor is deffective
Posted on Jan 26, 2009
greenspan
  • 1734 Answers
SOURCE: LG split (3 indoor) LMU360CE
The LED #2 is only flashing while in disconnection or short in Thermistor (3 sec off / 0.5 sec on). If you want to change it, note: this is not an easy job to do! You will need to remove the top panel, then remove the control paneland then the front panel to gain access to the thermistor. The part isnot available to the public and requires an authorized service techfrom LG to take care of this problem. You will need a special tool toremove the front door seal spring clamp.
But you can call customer service @ 800 243 000 and see if theycan transfer you over to parts. Just give them the model and serial #and see if they would be willing to sell you the thermistor part. Youwill also need the door seal spring clamp removal tool to make the jobeasier.
Posted on Aug 02, 2009
heatman101
  • 43501 Answers
SOURCE: how to fix a pioneer a/c unit,indoor unit start
Here is a tip that will help you to troubleshoot your A/C unit..
Air Conditioner2_bing.gif Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Apr 15, 2010
  • 12 Answers
SOURCE: eo error code
You need a professional here. Once this has been repaired, I would suggest running the wiring to the outdoor unit inside some sort of piping to protect it.
Posted on Jul 21, 2010
Error code is e6
Typically (not in every single case) this can be a communication error between the indoor and out door units...Check all wiring and circuit boards for proper and tight connections, also look for burnt spots on the front and back of circuit boards....please make sure you turn off all electrical power before servicing your units, electric can kill you if you are not careful.
Jul 11, 2016 | Heating & Cooling
Voltas verticool showing e6 unit not working !! What happend?
From search I found that on a Mitsubishi it said e6 and e7 that is an indoor/outdoor communication error. I had that happen once when I installed one of these split units, got e6 and realized I forgot to connect the wire on the indoor part, that triggers the outside to go on when thermostat inside starts the cooling cycle. Maybe a wire pulled loose. There was terminal blocks on each unit on one I hooked up, check breakers too.
May 03, 2016 | Heating & Cooling
Meaning of e6 arrear Videocon split ac
Communication error between indoor to out door, Check the wiring from indoor to outdoor, if good, your PCB is faulty. Repair it.
Sep 12, 2015 | Heating & Cooling
Blue star inverter ac e6 error
e6 is comunication error. check indoor to out door connection cablr . no joint.
Oct 25, 2014 | Heating & Cooling
E6 error in split a.c
The problem failure is between indoor unit and outdoor unit
Make sure everything is connecting properly them restart the unit.
To help you further the equipment information is necessary in every question as every a.c. or product are made differently.
Thanks!!
Sep 03, 2014 | Heating & Cooling
Flashing light the at says e6
Usually Indoor Unit Anti-freezing protection (Cooling
Mode) or Over-heating Protection (Heating Mode)
for Evaporator
A) Indoor room
temperature too low
under cooling mode,
Too high under
heating mode
B) Indoor unit filter or
evaporator too dirty
C) Indoor unit fan motor
blocked
D) Insufficient refrigerant
under cooling mode
E) Indoor unit evaporator
sensor wrong
connection or failure
Jul 28, 2014 | Samsung AQV12VBE Vivace Wall Heat Pump Air...
What does error code E6 mean?
Apr 30, 2014 | Gree 18000 Btu 20 Seer Ductless Mini Split...
Display error code E6
E6 is a comms error try turning the power off at the isolator and reset everything. if it comes back you might have a lose interconnecting wire between the indoor unit and outdoor unit
Apr 15, 2014 | Mitsubishi Heating & Cooling
What does e6 error code on aux unit
Mar 19, 2014 | Heating & Cooling
What does error code E6 mean? On a Mitsubishi Mr. Slim A/C
Code E6
Error detail Indoor/outdoor unit transmission error (signal receiving error).
Inspected unit Indoor.
Air Conditioning Fault Codes
Aug 01, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
