Question about Emerson Cdg Karaoke Player GQ755 Audio Video
How to connect external speakers
I need to learn how to use external speakers with the machine
What do I need to connect external speakers to tv
You will need an amplifier and depending on your tv you can run either red and black RCA leads or a toss link fibre optic cable to it.Then connect speakers to the amplifier(stereo)
Aug 30, 2014 | Televison & Video
No sounds comes out in headset but external volume is ok
Try to use external speaker. connect it where you usually connect your head and check if it work . If ever the external speaker will work it only means that the problem is your headset ( defective )If in case the external speaker will not work it means the problem is the terminal ( the port where the headset or external speaker connection )
Apr 01, 2012 | Computers & Internet
How to connect external speakers to this tv. Only output jacks exist for audio.
Most of the TV's do not have a speaker output and so you will need to open the set and take the speaker connect to be meshed along with a impedance matching.
You can connect with a switch wherein the TV speakers can be switched OFF and the external speaker connected . If not the external speaker if connected in parallel must not bring down the impedance to a lower level not supported by the output IC.
The other option is to use the output AV to connect to an amplifier and speaker. ( Your Audio system)
Feb 08, 2011 | Televison & Video
I am trying to connect a speaker in a shower connected to a tv. The speaker has conventional black and red bare wire connections. How can I connect this to my tv so that I can hear sound from this speaker.
User manual:
http://download.p4c.philips.com/files/4/42pfl7403d_10/42pfl7403d_10_dfu_eng.pdf
As you can see in the user manual, this TV does not have connectors for the external speakers.
It has Headphone out (not strong enough to drive the speakers) and audio line level outputs (not for driving speakers either).
So for you to use the external speakers, you will need a small amplifier that will accept the signals from the headphone or audio line out from the TV to drive your speakers.
As you can see, it will not be easy setup if you do not like to have extra component installed.
You can look for small amp at Radio Shack.
I hope I explain it clear enough without confusing you.
Please leave rating if it helps.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 15, 2011 | Philips 42PFL7403D/27 42 in. LCD TV
Hello, I have a very old mitsubishi color tv, model cs 2657r, which I purchased in the late 1980s. The picture is still great, and I'm trying to connect two small external speakers, though the internal...
Try stripping the speaker wires and exposing it about 1 inch. Then connect the speaker wires in a way that the part that grips or holds the wires touches the metal part and not the insulation. If there's still no sound, Please check the external speakers to see if it's working by using them in another device like a home system or audio player or maybe another tv that has an external speaker port. If not, mostly likely the switches are defective and needs replacement by a qualified technician.
Hope this helps.
Oct 25, 2010 | Mitsubishi CS-13103 TV
No sound in the inter speaker! except if I connect external speaker or headphones!!!
As sound is coming to external speaker then need to check the connection or change your laptop speakers.
Aug 21, 2010 | HP Compaq 6720s Notebook
No sound does it need an external speaker
hi, it does need a set of external speakers , if you intend playing music it will sound better if you buy a 2.1 setup ( 2 small speakers and a subwoofer) you can purchase reasonable ones for around £25 , if not playing music or games with sound effects then opt for a simple 2 speaker setup , plug the mini 3.5mm jack plug from the speakers into the green jack socket .
hope this helps
Feb 22, 2010 | E-Machines eMachines Desktop PC
IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Dec 22, 2009 | IBM ThinkPad T23 2647 Notebook
External speakers for acer laptop 5220 series
Hi there
On acer laptop you have already speakers. but you want to connect external speakers then please find
that three conector in your laptop and connect you external speakers on one of them. please try each connector and you are able to connect external speaker.
Thanks
Robert
Sep 24, 2008 | Computers & Internet
Magnavox projection tv hookup to external speakers
The external (audio out) connectors are intended for use with an external amp, not direct speaker connection.
Sep 02, 2017 | Televison & Video
Emerson Cdg Karaoke Player GQ755 Audio Video Logo
64 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
