Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
No water coming out of my upholstery attatchment
How do i unclog it
Replace the sprayer and that will fix the problem this can be bought at guarantee vacuum and sewing center
Posted on Mar 21, 2014
Cleaning solution does not come out
When you are using upholstery hose the water/solution does not go through the heater so see if water sprays out of upholstery attachment (this may take a little while for water to travel the distance). If it does than you know your pump is good. If water does spray out of hose but not out of bottom of unit it will more than likely be a clogged heater unit caused by water calcification or detergents. This can be cleaned out however it is not an easy job. And, if the heat insolators are not placed exactly in place, it can lead to plastic melting.
Feb 04, 2016 | Bissell 9500 ProHeat 2X CleanShot Upright...
I do not know how to use the upholstery part to work
hi,
the owners manual is here at this link,
http://www.hoover.com/pdfs/manuals/F5807.pdf
I believe for you to work the upholstery tool the suction tank lid must come off, and the center channel there has to come out for the hose to go into, and then replace the suction tank lid again.
there should also be a second water hose to connect midway down the left side of the unit there little square push/pop out lever. the water hose will connect there and you should be good to go from there. Refer to the manual for the exact directions tho.
Nov 04, 2010 | Hoover SteamVac F5914-900 SpinScrub...
No suction?
-Check to make sure the dirt cup is empty.
-Check the filters, If your filters are dirty they can restrict airflow.
The black filters only may be hand washed in cold water with mild detergent, re-install filters when they are completely dry.
-Check for good suction at the end of the upholstery hose. If there is limited suction from the upholstery hose detach the hose from the machine. Insert a broomstick into the hose to push any obstruction through to the opposite end.
-Check the lower hose for clogs. Remove the screw from the left side of the lower hose on the back of the unit and straighten this section of hose by pulling it down or lay unit out flat (the detent will need to be pushed twice) and roll unit on its side with the lower hose towards the top side. Look through the hose for obstructions. Push a broomstick through this lower hose to unclog.
-Check brush belt and replace if broken.
Aug 03, 2010 | Bissell 6594 PowerForce Bagless Upright...
How to hook up tool to clean upholstery
Keep your upholstered furniture looking fresh by vacuuming it regularly with the upholstery tool attached to your vacuum's hose. Prevent the fabric from fading (or at least delay this) by keeping your furniture out of direct sunlight -- close blinds, shades or curtains when the sun shines most directly through windows closest to the upholstery. And remove stains by blotting them with a dry cleaning solvent. Before steam cleaning your upholstered furniture, read the piece's cleaning code label to determine whether or not it is safe to do so. Then rent or buy a steam cleaner (also called an extractor) and follow the directions below.
  1. Rent a steam cleaner or purchase one; buy steam cleaner solution.
  2. Step 2 Vacuum the upholstery on the furniture you wish to steam clean; use the upholstery attachment to most effectively **** up loose debris.
  3. Step 3 Test the steam-cleaner solution on the upholstery in an inconspicuous place to ensure the color won't be steamed out or drastically altered.
  4. Step 4 Attempt to remove any stains with a stain removal or dry cleaning solution. Follow the directions that come with the product you choose for the best results, and allow the stain remover to dry before you begin steam cleaning.
  5. Step 5 Remove cushions and, if necessary, arm covers.
  6. Step 6 Gently apply the steaming water and cleaning solution in straight lines across the upholstery one section at a time.
  7. Step 7 Use the cleaning extension on the steam cleaner to **** up as much water as possible. The dirt will come out with the water.
  8. Step 8 Clean one side each cushion (then allow it to dry) before cleaning the other side. If the cushions are permanently attached to the furniture, clean them last.
  9. Step 9 Allow the furniture to dry completely before repeating the steam-cleaning process or replacing the cushions.
Jun 19, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
No water sprays when I press lever on handle
proheat 9300
assuming the water works for the tools
Remove the water tank. You will see 2 red tabbed plastic spray tubes.(where the spray comes out if not clogged) Pinch the clips to remove from the machine. Then you will need to pinch the hose clips to remove the red tabs from the hose. Clean out those red spray nozzles. Next step: have a towel ready and fill the solution tank with water. Put the solution (not water) tank on to where the water tank would go. Place the machine selection knob to rinse/wet only. Now with towel under the hoses that you removed the red tabs. Turn on the machine and pull the trigger to activate the water. You should see water flow out of the hoses that had the red tabs on them. If not, release and pull again the trigger several times. If only 1 hose has water coming out of it then block the one that works and try the process above again to de clog the one that isn't working. Good luck.
Apr 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do i attatch the upholstery cleaner for the hoover f5835 900
The instructions for the cleaning tools are included in the User Manual. Please download or read it from:
http://www.hoover.com/pdfs/manuals/F5835900.pdf
The Upholstery Cleaner requires the hose be connected to the recovery tank, and the tool be slid onto the hose end.
Oct 12, 2009 | Hoover F5835900 Upright Steam Vacuum
Water leaks out under the unit when using the upholstery attachment?
You may wish to check and see if the leak is where the small water supply hose is plugged in to the cleaner base. That connecction supplies water from the product, to the spray end on the upholstery hose.
Sep 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hose that releases the water and cleaner on my Hoover is clogged
Your right the hose is clogged.. Use a portable vacuum to blow the dirt inside the hose.
Jul 24, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
How to unclog i guess
If this has a foam filter on the bottom side of the recovery tank lid, make sure there is at least a 1/4 in. gap from the top. Also check the filter from the bottom, it has a red frame, clean it off it covered over. The other thing that will cause this is that the lid for the recovery tank is not locked down all of the way around.
Jun 21, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
How do you apply attatchment for upholstery cleaner
If can only go on one way so it will lock. If it doesn't, then something is broken either the attachment or the hose end where it hooks to.
May 18, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
27 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
