Question about Whirlpool GZ25FSRXYY
Finding location for water filter for this model
Cannot find where the water filter is located
5 Suggested Answers
the dr
  • 447 Answers
SOURCE: Water Filter Location
Its in the bottom grill. Look for a round cap. Twist 1/4 turn and remove.
Posted on Dec 01, 2007
  • 116 Answers
SOURCE: water filter
If you look on the toekick on the lower left hand side you should see a circular tab that is about 2 inches in diameter. This is your filter cover if you turn it 90 degrees counter clockwise your filter will release(if there is one installed)
Posted on Aug 06, 2008
Maytag317
  • 1136 Answers
SOURCE: location ofwater filter(s) whirlpool modeled22dq
Hi, The filter is located behind the kickplate. You can see the handle for the filter in the kick plate. I believe you turn the filter handle Counter clock wise to remove it. It will tke a little bit of force. Yes this filters the water in the door.
Let me know If I canassist you further. Thanks
Vic
Posted on May 17, 2009
  • 5 Answers
SOURCE: Where is the water filter
Depending on the model, it is inside the fridge.
Some other models the filter is on the bottom grille, twist kind.
Look for your manual or look for those clues
Posted on Feb 19, 2010
I have a Kenmore side-by-side ultrafresh refrigerator model # 5255210, serial# SM0649567. I cannot find the water filter. Where is the water filter located on this refrigerator ?
Owning 1 of these refrigerators will require you to replace the water filter from time to time, in order to keep the water fresh and the refrigerator running efficiently. Kenmore refrigerators are made by Amana, Frigidaire, GE, LG, and Whirlpool, so it is important to find out which manufacturer made your Kenmore refrigerator, in order to make sure you order the right part. Kenmore refrigerators use filters that are located in the bottom, front panel of the refrigerator. Details can be found on WiKi how to change a water filter on a Kenmore Refrigerator.
May 24, 2016 | Kenmore Refrigerators
Where is water filter located on kenmore coldspot model #52212100
contact sears parts to get a owner manual but filters are usually locate in line before the unit.
www.searspartsdirect.com
Sep 14, 2014 | Kenmore Refrigerators
I own a fridgidaire side by side. the model number is FRS26W2AW9. WE CAN NOT FIND WHERE THE WATER FILTER IS ON THIS UNIT. DO YOU KNOW.
Removing and replacing a water filter - upper right hand corner inside location
Filters situated up front in the refrigerator compartment of Frigidaire-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Open the door of the refrigerator compartment of your Frigidaire brand side-by-side refrigerator. The filter is located in the upper right hand corner. It has a push button for quick release just to the right of the filter.
  2. Locate the icemaker On/Off power switch and place it in the OFF (o) position.
  3. Push in on the filter release button and pull the filter all the way out to remove it. Remove new filter from its packaging and remove the protective plastic caps. Insert the new filter in the same manner it was removed. Make sure to push in firmly on the filter until you hear the filter cartridge click in place.
  4. Return the icemaker's power switch to the On (l) position.
  5. Condition the filter by running water through the dispenser for about three minutes. This will flush the filter of all fine carbon particles.
  6. In some models, you will have to reset the filter status light. It is located on the ice and water dispenser control panel. Push in on it for ten to fifteen seconds until the green, red, and amber lights flash. If your refrigerator model does not have a filter status light, you should make a note on a calendar, or place a month sticker on your filter to remind you to replace the filter again in six month's time.
Sep 04, 2011 | Refrigerators
I have a GD22DQ model side by side whirlpool gold refrigerator. we have looked through the manual and we cannot find were to put the water filter. the manual shows a dial at the bottom of the fridge but...
Hello Dollar1392,
I understand that you can not locate the water filter for your unit. If you have a water filter in your unit it will be located in one of two locations at the bottom of the unit in the grille or in the top of the refrigerator section on the right side in the rear corner. If the filter is not located at one of these locations then there is no filter on your unit. You will need to put an in-line filter in your water supply line.
Thank you for choosing FixYa.com if you have any further questions please post back to the thread.
Justin
Apr 23, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Where is the water filter located? can't find it.
Some are behind the kick panel on the front. Post your model number for more info.
Jun 05, 2010 | Kenmore 52512 / 52514
Trying to located the filter because the water in the door has a nasty taste. The model number is RS22AOXMQ00
I could not find your model # but did find This one
RS22AQXMQ00. you might have made a mistake.
If your refrigerator is this model #. I don't belive this model has a filter in the refrigerator. you might have one from the water supply to the refrigerator.
If you don't find one you might want to check the water reservior located in the fresh food side, behind the crispers at the bottom. It should be a coiled water tube. If it looks green inside or nasty then that is your problem.
Jan 13, 2010 | Refrigerators
Location of water filter on maytag model msd2351hew
Hi.The water filter is located in the upper right-hand corner of the fresh food compartment. You will need to turn the filter, counterclockwise, to release it form the housing.
Dec 04, 2009 | Maytag Refrigerators
Can't locate the water filter. water has a bad taste
The base grille water filter is located below the freezer
compartment door. Depending on your model, you may have a filter that is installed behind the base grille or a filter that is installed through the base grille.
May 23, 2009 | Kenmore Refrigerators
WATER FILTER
All of the cabinets I have worked on have had external water filters, so unless yours is really special you will normally find the water filter located behind the fridge freezer in the incoming water supply line (typically 4 - 6 inches long 2 inches diameter). Some cabinets now have a timer to indicate a long duration, none that i have come across monitor water quality. Hope this helps.
Mar 09, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Refrigerator Model FR23W3aw0 Frigidaire
cant bring up that model # there in the refrigertor side top right... in rouund like the fliter, plastic case most filters usually just turn counter clockwise to come off
Sep 03, 2007 | Sub-Zero 680 / S
Whirlpool GZ25FSRXYY Logo
19 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
