Question about CellPhoneTrek.com LG 840G Van Gogh Vase with Twelve Sunflowers Case
When calls come in it says forwarding activated,
Also says call divert set
How to get diverting active off phone
This should work; Hit the 'Phone' Icon; Then hit the 'Settings' key (Lwr left) which should open a box with three options; Choose 'Call settings' which gives you the screen you need to set up diverting, blocking and forwarding of calls. 'Call forwarding' allows you to enable or disable this service, while at the top; 'Call rejection' allows you to choose whether or not to automatically block individual numbers or all unknown numbers etc.
Go into each option's menu-choices and get to know where everything is.
I hope this helps you sort things out.
Oct 13, 2015 | Samsung Cell Phones
Need instruction on how to call forward? Why charging to what is indicated as FREE?
You can now divert important calls to another mobile phone or landline if you are unable to take a call in case: you miss a call, are busy, are out of reach or phone switched of.
Activate
  • Go to the 'Call Divert' menu on your mobile phone
  • Select 'Divert if out of reach' option
  • Select 'Activate', followed by to other number option
  • Enter the number in the to other number section
  • Your Call Divert service will now be selected
Deactivate To deactivate go to 'Call Divert' menu and select deactivate / cancel option.
Also:
To forward all calls:
  • to start, enter **21*number #
  • to stop, enter ##21#
To forward calls while you´re speaking to someone else:
  • to start, enter **67*number #
  • to stop, enter ##67#
To forward calls if you don´t answer the incoming caller within 30 seconds:
  • to start, enter **61*number #
  • to stop, enter ##61#
To forward calls if your cell phone is switched off or is out of reach
  • to start, enter **62*number #
  • to stop, enter ##62#
To cancel all preset conditions:
  • enter ##002#
You will not be charged for activation or deactivation of this service. Only the call divert will be charged as a separate call.
Jul 23, 2011 | Cell Phones
Need instruction how to call forward?
Activate
Also:
  • enter ##002#
I want to dirvert calls to another handset plerase help
go to the call settings then click on the call divert option then click divert all voice calls then on that select the option as divert to another number then feed the number inside the tab now click ok check the status now if it says activate then its ok. If not activated then contact your service provider to activate the call divert for your number . because they may block divert optoin for your number
Jun 15, 2011 | Cell Phones
Samsung sch u350- how do you set up call forwarding
As your using samsung sch u350 you can forward your call by following simple step.Go to main menu select settings after that select call settings after that select call divert after that select divert all voice calls then activate you can give your another number there you can recive calls.Other wise you can forward it to voice mailbox.Your old number will recive only message .
Jun 14, 2011 | Samsung Smooth SCH-u350 Cell Phone
Call forward will not turn off, have tried *74 & *73 , have rebooted and turned off then on, call divert symbol still on and phone calls still diverted.
To set Unconditional Call Forward ON Dial "*72" for a dial tone. Dial the forwarding number followed by "#". Wait for dial tone. LCD will display "Call FWD Activated"
To Cancel Unconditional Call Forward: dial "*73" and get the dial tone, then hang up. LCD will display "Call FWD Activated
but, since you have tried those two, it could be that there might still be a different type of call forward option that is still ON, on your phone like Busy Call Forward and Delayed Call Forward 1. To Cancel Busy Call Forward: dial "*91". Wait for dial tone. Hang up.
2.To Cancel Delayed Call Forward: Dial "*93" for a dial tone, then hang up.
Let me provide you a link to the website which I used as a reference for your future reference.
http://www.grandstream.com/user_manuals/GXP_User_Manual.pdf
Apr 27, 2011 | Grandstream GXP-2000 IP Phone
How do you forward your calls to another number?
its a network service if its not work call your service provider to activate this service,for forwarding you need to divert its to another number check divert option on your phone call settings
Nov 12, 2010 | Motorola Mobility Rival A455 Cell Phone
How do i use the call forward option?
Call forward or call divert, the same features just different names in some models of phones. Only the name of the service says that it is diverting calls. There is 4 situations for activation and can be activated via the mobile device or directly by entering codes on the display phone. The function codes and their ability to use depends on the network operator.
Codes:
** 21 * number that diverts calls with code of network operator # OK, yes or call it will divert all incoming calls unconditionally
##21# ok, yes or call it will deactivate this divert.
*#21# ok, yes or call it will check status.
** 61 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when you do not want or can not answer the call
##61# ok, yes or call it will deactivate this divert.
*#61# ok, yes or call it will check status.
** 67 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when your line is busy ##67# ok, yes or call it will deactivate this divert.
*#67# ok, yes or call it will check status.
** 62 * number that diverts calls with code of network operator # OK, yes or call it will divert incoming calls when you are unavailable ##62# ok, yes or call it will deactivate this divert.
*#62# ok, yes or call it will check status.
##002# ok, yes or call it will deactivate all divert.
If the codes not working you have that option in your phone, it is in call settings. You choose option and then insert a number for diverting calls.
This service is not free, and you must contact your network operator for prices.
By!!!
Nov 03, 2009 | LG VX5400 Cellular Phone
Forwarding Calls to Outside # for Nortel T7316
You can set divert for the calls to another number. Do check for the call settings and activate the divert based on situation like.. When busy. Not reachable.
Aug 19, 2009 | Nortel Norstar 16-Line PBX Speakerphone
When calling in my phone always says your call has been forwarded to an automated messaging system
If you can make calls OK, then it's possible that you have the phone set to divert all calls - you can check this with
*#21#<send>
If it comes back with some message like "Divert active" or "Divert all calls: ON", then clear it using
##21#<send>
Jul 06, 2009 | AT&T Cell Phones
CellPhoneTrek.com LG 840G Van Gogh Vase with Twelve Sunflowers Case Logo
Top CellPhoneTrek.com Toys Experts
ray gallant
Are you a CellPhoneTrek.com Toy Expert? Answer questions, earn points and help others
