Question about Konica Minolta Office Equipment & Supplies
Machine trouble displayed call service? - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
Model number??????????????????
Posted on Jan 14, 2016
3 Suggested Answers
firecontrol7
  • 6161 Answers
SOURCE: Machine trouble
Sir,
To clear the fuser error code, perform the following:
1. Power the machine OFF.
2. Press and hold the STOP key.
3. Power the machine ON. Release STOP after 5 seconds.
Posted on Jul 19, 2009
SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Posted on Oct 10, 2009
Tech kimbo322
Bring it to a Pfaff certified service center. Might be a circuit board or transformer. Nothing you can fix yourself.
Apr 07, 2014 | Janome Sewist 525S Mechanical Sewing...
Machine trouble Service call(c3451)
Sir/Mam,
On the right side of the machine just below the scanner section (The part with the big glass) is a cover next to where you connect the Ethernet cable. Remove the cover, with the machine on use a small screw driver and gently depress the small black switch. The machine is going to go thru some screens when you see the screen with the copiers on it to the left on the screen in the middle you will see a "." when that is displayed press 3. The code will come back but now press the Utility/Counter button, you should see a button that says Maintenance Mode press that, see Trouble Reset press that and the machine will again will go thru warm up procedure, you will see the "." DO Nothing! The machine should go to "Ready to Copy" if the code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
Feb 01, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Konica machine trouble service c0500 reset
On the right side of display located a display contrast key and a little hole.Under little hole is a reset switch,press the reset switch and wait to apeir * and press 3.
Jan 11, 2014 | Minolta DiALTA Di250 All-In-One Laser...
Trouble code c-0214
Enter into service mode then prees machine then trouble the machine will display error code chat select C0214 and press C. Is should sort out your problem.
Bwalya
Jul 06, 2011 | Konica Minolta Bizhub c203 Copier
My canon photocopy machine displays an error code presenting as (E 000602 - 0003)Please help me solve this problem.
Hi these means that you have HDD trouble, and it needs to be changed and upload the system on it - CALL SERVICE.
Aug 19, 2010 | Canon Office Equipment & Supplies
Machine trouble call service c0500
Sep 13, 2009 | Konica Minolta bizhub 180 All-In-One...
E000000-0001
Okay, to be of real help you have to reset the error in service mode as the officetech1 said. To do this you need to press the head key (the head with the star inside) then 2+8 together and then the head key again. This will get you into service mode. Then select 'COPIER' then 'FUNCTION' then 'CLEAR' then select 'ERROR' or 'ERR' press 'OK' then switch the machine off and on again. This may get it working for a while or a long time. But if not, you will need a fixing film unit to remedy the problem.
Mar 10, 2009 | Canon imageRUNNER 4570 Copier
Help! i get the "Machine Trouble" error
are you sure thats the right trouble code? reboot machine holding down the STOP button. this may reset this error
Dec 04, 2007 | Konica Minolta Di1610 Copier
Error message C4551 anyone? pretty please.
C3451: Heat. Heater Trouble
You have to check machine fuser unit .
May be paper on the fuser unit. Check fuser unit rollers.
After check fuser unit you have to ececute a "trouble reset".
Turn on your machine by press and hold "utility counter" botton, after some seconds press to display "TROUBLE RESET" and turn off and on machine.
C4551: Cyan laser Malfunction
Check cyan laser connection and execute trouble reset.
Bye.
Oct 03, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
26 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
