I have an Acer Aspire 5741G and for some reason my right arrow key is nor responding. I had this problem a few days ago and the next day the key was working again. I tried restarting the laptop if that would have helped but it did not. Can you help me with a possible solution that would not include going to a service provider?
SOURCE: laptop wont turn on (acer aspire 5002wlmi)
Sounds like it's hitting a dead cell in the battery. If you are a very skilled electrician or computer tech you can find and replace dead cells in the battery by taking it apart. Otherwise your safest and easiest solution would be the purchase a replacement battery. Check on ebay, usually you can find them for a fraction of regular cost. Peter [email protected] 561-537-3208
SOURCE: Not working right click of touch pad of Acer Aspire 4710z
Hey!
What operating system are you running? All I could find was a manual for your model: http://tinyurl.com/6gc7pl
If you are using Windows XP, you might try going to Control Panel -> Mouse -> On the first tab (Buttons) check "Switch primary and secondary buttons." then hit "Apply".
Try left-clicking (currently assigned to be the right-click) on your Start button and see if the menu with "Explore All Users" on the very bottom opens. If it does, then your touchpad is most likely defective and would have to be fixed (www.fixmyacer.com). If the menu doesn't come up, then it is a software issue and is 100% fixable.
Matt Newelski
www.newelski.com
SOURCE: Acer Aspire 9304 lan connection problem
is your operating system vista? update your operating system in the internet / microsoft so that it will download all the patches it needs to make your computer works better
SOURCE: Aspire 9300 (LX.AWR0X.053) PC Notebook: I recently moved to Europe, my Acer laptop suddenl...
If your computer is in unclean place (dusty) its fan night not be able to work good and dust can get it stuck. Its not reccomended to clean laptops at home but best bring it to proffesionals.
SOURCE: Some of my keys do
you need to reconfigure your whole system.... That is: you must backup all your personal data and softwares, then you must have a window cd (xp,7,vista). it must be bootable.. You insert it and press any key when you start your laptop then you will get a boot screen which will intruct you what to do next. Then all that you will have to do is to format your laptop with NTFS... contact me if you are getting more problems and dont forget to rate me
