My dp-2330 give me error 04-01 machine error and try to power it of for awhile then when i connect it to power its didn't start any more pleas help
SOURCE: Booklet printing
You're right, most do offer that option from the print driver. I would check Panasonic's web site to see if they offer a postscript driver, that may have booklet printing.
SOURCE: My Panasonic DP-2330 .... Is Showing Error Code E04-02
How enter to service mode in panasonic DP2330 copier.
SOURCE: How to print envelope on Panasonic DP-2330 printer
You can download a user's manual from here.
It's a pretty large file, so I'm guessing there's something there about paper feeding or envelopes that will help you.
Good luck.
SOURCE: need Panasonic WORKiO® DP-2330 driver
Hello , this is the link for the most up to date driver. Just choose your language and operating system
Thank you.
http://www.panasonic.net/pcc/support/mfp/dp-3030/gdi/download.html#01-2
SOURCE: My panasonic DP-2330 gives a
I don't have idea what you've tried and what you've not. But this likely happens after the machine is moved.
First install it on another computer and try. If the problem persists, then use another data cable. Or if there's no problem on another computer, reinstall the driver on the first computer, reconnect it and if possible switch the usb port (try it on another usb port). That should work fine.
[Don't forget to restart the computer after the driver is uninstalled and reinstalled, otherwise you hard work will not worth]
I hope you can access all the other functions like copy, scan, etc.. or scanning not possible? I wish to know more about the problem.
If the problem persists, let me know.
Good luck.
Thanks for using FixYa.
