Question about Tablets & eReaders
Proscan 7044K-C tablet won't charge
Plug charger in will not charge
    Master:
  • 397 Answers
Test your charger with a multi-meter, does it output the correct supply? If not you need a new charger.
If your charger is ok, take a look at the charging socket, is it damaged in any way? Does the charger feel loose when it's plugged into the socket? If so you may need to have your charging socket repaired/replaced.
After checking all this the next thing I would try is a new battery. However, most tablets will at least work from main supply, even if the battery is faulty.
Posted on Mar 21, 2014
3 Suggested Answers
  • 4961 Answers
SOURCE: My acer charger got wet, I thought I dryed it off
You could go to the place you bought it or another tech store and see if they have another tablet like yours lying around so you could test out and see if it is just your power cord that needs to be replaced. Because most likely it's time to buy a new power cord. Hopefully you didn't fry the tablet's motherboard also that's why you should test out the power cord first.
Posted on May 29, 2012
jasonnashjlu
SOURCE: Both Charger Ports Wont Take Charges
i can suggest you get a Duracell wireless charger which you just place your tablet on and it charges?
Posted on Nov 09, 2013
My son has a proscan tablet PLT7810K the power button slowly became pushed in & Maybe something wrong with charge port it will not turn on at all it will not charge when put on the charger plz help me
Proscan is classified as a bargain tablet in the low end range.so you should expect any kind od issues related to it. like that of power button.
Obviosly you have a problem with your battery, though no way to tell "from distance" if it's prperly the battery or the charger... or both You haven't commented in your post if it works with the power adapter. Chargers can be easily diagnosed by measuring output with an electronic tester. Once you have a good charger, you should test if you can charge your battery.
I understand that Proscan batteries are "lifetime", so it's not easy to replace them.
You should evaluate it it's worth to buy new charrger and replace the battery or maybe buy another device. Probably you need some technical assitance for diagnosis.
Take note that you can get a used tablet from Amazon from about 465 USD in good conditions, without the need of spending on repairs
Amazon com Customer Reviews Proscan 7 Inch Android Internet Tablet...
Proscan 7 Inch Android Internet Tablet Capacitive Touch Screen Android 4 1...
Oct 07, 2015 | Tablets & eReaders
What are some reasons my tablet wont turn on?
switch broken
motherboard faulty
batteries not charging
charger faulty
power socket used to charge faulty
faulty fuse in power plug
faulty processor
faulty ram
Jul 18, 2015 | Proscan 7-Inch Android Internet Tablet,...
Why won't my new Proscan tablet charge properly?
The battery can't hold the charge. Defective.
Or the charger is defective and not outputting enough voltage.
This can be tested with a voltage tester. The charger should be outputting 5 volts.
A good purchase is an inexpensive voltage tester. Can be used for so many things.
Oct 11, 2014 | Proscan 10.1-Inch Internet Tablet,...
Proscan tablet support
Hello, Have your tryed another cord and charger? If so then you will have too take the tablet too a repair shop or return it back too manufacturer. Call Cust. Support with make and model first and talk to them.
May 31, 2014 | Tablets & eReaders
Why won't my tablet charge
It could be either the charger, the cord or the tablet. Do you have another charger to test with?
May 06, 2014 | Proscan Recertified - PLT7035 4GB NAND...
Proscan tablet won't turn on
Try this. Plug your charger in. Then press the power button repeatedly until the screen comes up with a charge icon showing.
Hold the power button down until the blue screen comes up. Then if it boots up just leave the tablet alone and give it some time. You should see an android come up and then a scan of the android words start . This takes time. Don't be impatient . It may boot into a factory reset mode. Just start again with the factory screen.
You can try repeating the process if it doesn't work the first time.
Mar 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
Proscan tablet turns on but turns back off
Sounds like the battery is dead. Does the charge light come on when you connect it to the charger? If not, the port on the tablet or the charger may be bad.
Feb 13, 2014 | Tablets & eReaders
The charger is broken and i need another charger also the pieces of the charger is stuck where you are suppose to put the charger
You can charge your tablet through the USB port on your desktop computer. Just plug it in with the USB cable that came with your unit. It's slower charging but who cares?
Those pins are delicate. Be careful when inserting and removing.
The USB is designed to power on first and then the data is transferred.
Forget about taking it to a repair shop. The charges will be more than the tablet is worth and it's not likely they will have the part.
Dec 30, 2013 | Proscan 10.1-Inch Internet Tablet,...
7" touch andoid tablet won't charge
It may be the charger has a loose wire. In that case a new charger would fix the problem. Mine has a problem with the charging port itself. I am fortunatly that my tablet is under warrenty they are going to replace the tablet for me.
Dec 27, 2012 | Nextbook Premium 7 Capacitive Touch...
Tablets & eReaders Logo
61 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
