Question about Bosch Kitchen Appliances - Others
Why is my kettle cutting off before the water boils, this is the second bosch kettle that it has happened to.
My first Bosch kettle leaked after 3 months the store reluctantly changed it now the new kettle cuts off before it boils why.
3 Suggested Answers
  • 6771 Answers
SOURCE: I recently returned my two
No! you have clearly a manufacture defect or a design issue, I would take it back and select a different brand if possible or your money back.
Posted on Mar 19, 2011
brenda_scofi
SOURCE: Bodum kettle boils too long before automatic cut off.
Mine does the same and now the switch doesn't work at all. Bodum is replacing the whole kettle.
Posted on Nov 02, 2012
Kettle bosch twk7901gb will not switch off
Make sure the steam is allowed to warm the bi metallic switch.
Apr 10, 2016 | Bosch Kitchen Appliances - Others
How do you descale
Same as electric kettles stand overnight with lemon and water filled to just above scale. works treat on electric kettle Do not boil, just stand overnight.
Jun 28, 2014 | Bosch Tassimo TAS4511UC Coffee Maker
Hi, I have a Bosch Private Collection Kettle. It is over a year old and has until recently been working fine. However, lately I do not feel that it boils to a high enough temperature for a long enough...
Some types of kettles use a separate power base to heat up the kettle jug. If this is the case with yours, turn the jug upside down and look. Also look at the parts on the base that touch the kettle jug contacts. If you can see the electrical contacts; mine were built on spiral rings for differing temperatures; try cleaning them with Brasso and a Q-tip (cotton swab) wiping the contacts several times to remove any tarnish and then use clean swabs to remove all traces of Brasso metal cleaner. Fill the kettle jug up to the maximum fill line and put the boiler on the maximum setting... boiling water. If the water doesn't boil... you have a more serious problem. Buy a new boiler as it isn't worth having someone fix it. Mine worked like new after I cleaned the contacts. Never immerse the jug contacts in water!!!
Nov 25, 2012 | Bosch Private Collection Jug Kettle steel...
Bosch classixx dishwasher wont drain
Ive had this happen on mine too. remove the filters in the bottom. squirt washing up liquid into the space-- liberally dont be shy!
Boil pans of water, boil the kettle. pour water into the space where the filters normally are. Fill the base of the dishwasher completely. Next close the door and repeatedly use the Reset feature. Eventually the pump will clear and kick back into life. Its a build up of fats, and sludge that causes the pump to appear to seize--the washing up liquid and boiling water see to that.
Feb 05, 2012 | Bosch 24 in. SGS43C12 Classixx...
Hi, i have a Bosch TDS2551GB steam generator iron. It needs descaling but I don't know how and there does not appear to be a descaling button. How do I proceed ?
Hi, Descaling is simply a process where the limestone that is deposited in any water cooking device is removed.
Have a look inside your electric kettle to see how much of a problem ypou have in your area.
If you have a serious problem & your kettle element is totally covered up with a whitish coating, I suggest you buy a can of commercial descaling agent.
If not, or iof you prefer home remedies, get a bottle of white vinegar.
Empty your kettle & pour a bit of vinegar onto the limestone. If it boils & foams, it is being dissolved. Replace the vinegar everytime it stops or slows down. Look at the results. You can speed it up by heating the kettle. Do not boil the kettle with vinegar. (Weak acid) Rather dilute it 50-50 I then boil. Or, just boi;l some water & throw it out. Then put the acid on. once you figuted out what process is suitable for getting rid of your areas's limestne, then applie your knowledge to your Bosh.
Just let the acid stand inside it overnight, or get more drastic if neccessary.
Sep 04, 2011 | Bosch Irons
Bosch classisxx dishwasher blockage
sounds crazy but my lg was doing the same thing, i got so pissed off that i poured boiling water from the kettle into the drain and worked a treat. now whenever there is a blockage error i do this and it works everytime.
Oct 21, 2009 | Dishwashers
Electric cordless kettle
This can happen on new mettalic kettles, the aftertaste may dissapear after a while with use as it did with mine.
Oct 25, 2008 | Faberware FCP512S Cordless Electric Kettle
Fuse for dishwasher (bosch)
13a fuse is correct. have you wired the plug correctly and is the fuse you are using a good one? try substituting a known good fuse ie from your electric kettle or whatever
Oct 18, 2008 | Bosch 24 in. SGS43C12 Classixx...
Kitchen Appliances - Others Logo
112 people viewed this question
Top Bosch Kitchen Appliances - Others Experts
Martin Olney
Martin Olney
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Bosch Kitchen Appliances - Other Expert? Answer questions, earn points and help others
