Question about Samsung Ml-2160 Mono Laser Printer
During installation doesn't find printer
Although the printer is attached, the software doesn't find the printer during installation
    Master:
  • 397 Answers
Often printers need to be left unplugged from the USB port and not plugged in until the driver installation process requests you to do so.
I would also double check you have powered the printer on, without power the system will not be able to detect it.
Posted on Mar 21, 2014
Why wont printer start up ?
It could be a number of reasons:
1. a simple solution is to initiate what is called, 'power recycling' (although this is assuming that the printer did already work at some prior point); this is where you turn off the printer for about 5 minutes, then turn on, which usually allows the system to reengage itself.
2. did you install the software for the printer? If you did not then your PC might not know the printer is attached. Is the software installed properly?; meaning you must unplug the printer from the PC, then install the software, then connect the printer to the PC after the software is completely installed. If you did it in reverse, then you need to uninstall the software, then start over by doing what I just mentioned.
3. the USB port you have the printer cord inserted into could be bad on your PC.
4. the printer itself has an internal problem and needs to be repaired, or if the warranty is still in place, have it replaced with another new unit.
Jul 27, 2014 | Kodak Esp 1.2 All-In-One Printer
My dell 160l does'nt have video card.how can i install?
A Dell 160I is a printer, as far as I know. They don't come with video cards, although many modern printers have a small LCD display.
Apparently yours doesn't have this.
If you don't have it, then you're stuck with what you have.
Mar 30, 2012 | Computers & Internet
Install printer
Although more information would be appreciated, the rules for this are simple.
1. Install the Software (Drivers) that came with the Printer: If you don't have the original CD for the printer, go to the manufacturer's website and the support section and search for it by model number, download and install. Sometime during the install process, you will probably be prompted to connect and power on your printer. When you see that message or if the software finishes installing without the prompt then...
2. Connect your printer to the computer via USB cable and power it on.
You're finished!
Apr 24, 2011 | Computers & Internet
How i can stall hp printer d2460 driver
Please Always remember that first you should install its software and then attach the hardware or if the software require attach the device with computer during installation, then you should attach. If you follow my instruction, you will get succeed in installation of any hardware and also in this case.
First insert the CD in CD Rom and install the software and after installation or during installation where the Computer Require attach the printer and it will work 100% guaranteed.
Good Luck
Feb 13, 2011 | HP Office Equipment & Supplies
How to install HP LaserJet P2015dn Printer ?
>> First of all install its software without attach printer
>> After installing it, attach printer or attach if software required during installation.
>> After attaching the printer it will detect its driver automatically.
>> When installation will complete you should must a reboot and then you can use it.
<<< Good Luck >>>
May 19, 2010 | HP LaserJet P2015dn Printer
My hp lj 1020 printer is not being installed on winxp
My dear, First install the software of your HP laser jet 1020 only without attaching the printer and then attach printer when it will require otherwise if it will not require during installation. You should take a reboot and then attach it and computer installed its driver automatically starting to end of installation CD should be remain inside the CD-Rom. After the complete installation once again take a reboot and now after the hook up your computer, your printer work properly.
Good Luck
Mar 22, 2010 | HP LaserJet 1020 Printer
How can i install hp inkjet f2180 printer without disc drive? am completely computer illiterate! please help, thanx
hi
unplug the printer from the computer usb port.
you can download the software for it from here http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=vn&product=3177562&lang=en& just click on the long link.
Select if you have Vista or XP (take the Xp or vista, or older, not the x64 verions)
download the full feature software and driver. which will include everything the cd would.
install the software and plug in the printer when it asks you.
Sep 11, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Lexmark 1300 printer won't work.
Solution#1- If your printer does not show in your hardware list its means that problem belongs to data cable. Kindly check your printer's data cable and plug it properly.
Solution#2- Uninstall printer's software take a reboot and then reinstall its software and then attach your printer or during installation if installation requires.
Good Luck
Sep 03, 2009 | Lexmark C772dn Laser Printer
During installation, printer can not find drivers, although installed. Can't even find drivers on the disk
Uninstall printer and disconnect it, take this link to Canon, choose your operating system and download and install the software. Connect when instructed or when install is complete.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=17406
Jul 07, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Not insatalling drivers
Is this during the installation? If so, unplug the printer, remove any driver/software you've installed (or partially installed) for it then re-boot the machine. Once the machine is restarted, plug in the printer first and allow Windows to detect it. Once it detects it, it will ask for the drivers, DO NOT run the setup for it. Instead, point it directly to the .INF file on your installation CD, and allow Windows to install it itself (you can then proceed to install the software from it (via the CD) once the printer is correctly installed). If you continue to have problems, you may want to consider downloading a new copy of the drivers to rule out corruption or a problem with the connection between your drive and the computer; http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1138373&lc=en&cc=lamerica_nsc_carib&dlc=es&submit.y=0&submit.x=5&lang=en&cc=lamerica_nsc_carib
Apr 17, 2008 | HP Officejet 4355 All-In-One InkJet...
Samsung Ml-2160 Mono Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
