Question about Combi Ovens
RATIONAL CPC GAS
OVEN KEEPS COMING UP RESET WHEN ON STEAM
    Problem Solver:
  • 7 Answers
Hi, does the oven work okay on hot air? Steam function uses the steam burner and hot air burner so there is alot of possible causes.
Posted on Jul 13, 2014
2 Suggested Answers
SOURCE: rational combi oven service manual
Alarm beeping control board not working
Posted on Feb 18, 2011
Rational combi master is not steaming showing "rES" on display.
This rES is a asking for you to Reset the gas. Check gas that it is on. If it keeps coming back, then you have a gas ignition problem.
Jan 09, 2016 | Combi Ovens
Oven doesn't give steam but it does reach the temp.how can i fix that?
First locate the water solenoid valve. Disconnect the water line to the inlet side of the valve to make sure water is getting to the valve. Once that's verified, disconnect the outlet side of the valve. Activate the steam and verify that the valve opens and there's a good amount of water coming out of the valve. If no water comes out. Verify that the coil is getting energized with the correct voltage. If the correct voltage is present and you have no water coming out. Replace the solenoid. If everything is working then remove the left panel inside the oven to check for blockage in the steam manifold. The manifold consists of a pipe with several spray nozzles that spray water on rebar. Remove all the nozzles and activate the steam. Do this several times to purge any rust or debri. Clean the nozzles and replace them. You should be good to go.
Aug 25, 2015 | Baxter OV310G Mini Rotating Rack Gas Oven
LOOKING TO BUY A SECOND HAND RATIONAL OVEN CPC 61, BUT WANT TO KNOW HOW OLD IT IS. ANY IDEAS OF WHERE TO FIND THIS INFORMATION? I HAVE THE SERIAL NUMBER: E61CD0208107
E for electric
61 for model/size
CD ummm, control type?
02/08 I think is feb 08, but I would like someone else to confirm that please?
Also, what is service history, did it have a good water filter? was the tank flushed daily and descaled annually?
Oct 17, 2013 | Ovens
My rational combi oven keepwanting a gas reset when not in use why is it happening all the time
It looks like one or both (62G) or the three (201G) gas burners fail to light. You may want to check you have gas supply at the correct pressure. If you do, next is to check the gas valves, the ignition electrodes, the gas blowers, and the flame sensors.
Mar 06, 2012 | Ovens
Rational combi oven service manual
Apr 28, 2010 | Ovens
Rational combitherm electric service codes
service 3, you have a cpc type oven yeah? if so then service means your meat probe needs replacing
Mar 13, 2009 | Ovens
Ovens Logo
291 people viewed this question
Top Combi Ovens Experts
ray gallant
billconfused
JonSnell Electronic
JonSnell Electronic
Are you a Combi Oven Expert? Answer questions, earn points and help others
