Philips 21pt1654 58
I need some problem with my Philips tv and I dont now how to resolve the problem,I need help Problem is the tv change the chanell at once alone,and I dont now is the problem the TV or controler,can you help me please? Thx a lot
    Master:
  • 397 Answers
Hi, are you sitting on the remote? does the TV have analogue/manual control buttons on itself, are they jammed in or damaged in any way? Are any of the buttons on the remote damaged in any way?
To rule out the remote, remove the batteries, if the problem still occurs it's the TVs problem, if it doesn't it's the remote.
Posted on Mar 21, 2014
SOURCE: ilo-32hd tv only 1 chanel
dude it just happened to mine it sucks!
Posted on Sep 29, 2008
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Posted on Mar 13, 2009
SOURCE: I Have a Philips LCD TV model#30PF9946D/37.
Oh yeah, you can most certainly change the power supply by yourself.
It's easy to locate - just follow the power cable - and easy to replace.
Only make sure to let it discharge before you operate it. 10-15 minutes disconnected from power should do.
However, there's no guarantee that the problem is in the power board.
There is a very good chance it is, in fact, not there.
There's another board which commonly fails on many plasma TVs and the effect is exactly as you describe. It's called Y-Sustain board and you can tell which one it is by looking at the side of your TV and seeing which large board has manny plastic connections that enter the display on the side.
That board often has one or two fuses on it - I'd check those first.
Posted on Nov 03, 2009
SOURCE: TV PHILIPS 32PFL3403 LOCKED AND REMOTE CONTROL
TV PHILIPS 32PFL3403 LOCKED AND REMOTE CONTROL DONT WORK
Posted on Dec 29, 2009
SOURCE: screen frozen
I've had this same problem and we only bought this TV back in July. It seems to be getting worse. Anyone have any answers?
Posted on Feb 25, 2010
Cannot change the picture format on Philips widescreen flat TV 32TA1000 32" LCD HD
Dear Dale,
We regret the inconvenience faced.
We would request you to share your contact details with us in order to get this issue resolved for you.
Thanks for your patience.
Regards
Philips Consumer Care
1800 102 2929
1860 180 1111
Jan 04, 2011 | Philips 32PFL3403D/27 32 in. LCD TV
Philips remote codes
Dear Sir,
Go to the following link to find the manual specific to your Universal remote control model.
http://www.urc.philips.com/
Alternatively you can download following:
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
or
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM725.pdf
or
http://www.tritronicsinc.com/remote_controls/downloads/rem250-eng.pdf
http://www.remotecodelist.com/remotes/philips/philips_pmdvd6.html
or
go to follwoing link:
http://www.xdiv.com/remotes/
or
http://www.universal-remote.net/philipsmagnavox.html
Hope this helps you my friend..
Aug 06, 2008 | Jensen JER-321 Remote Control
I have a Philips Magnavox tp3273c101 with a blue screen and a message in spanish, but i dont speak spanish. help
U talking about the tv nenu in spanish?Just pick the english one and push enter ur menu will change it back into english.
May 10, 2010 | Philips Magnavox 32PS55S 32" TV
Tv philips 20mf605t no power
write down the number of the micon if that is the component that you are suspecting and go online checking for company from who you can purchase the micon.one such company is dalbani.com and mcmelectronics.com
Aug 29, 2008 | Philips 20MF605T Television
Phillps tv problem
42" Plasma Flat screen TV - recently problem started with a solid black background over top half of screen during viewing (comes & goes). A few days ago, when TV was turned on, green light came on then changed to flashing red light in 4 signal flashing pattern, but no audio or video. Phoned Philps Cust Serv and was told to download system upgrade on USB but it did not work. Philips referred us to Service Repairs who charged $85 for coming to home and without even opening the TV, said it will cost approx $1000 for "boards" plus his service, and he could not guarantee the TV would work.
Aug 07, 2008 | Philips Televison & Video
Need Drivers!!!!
i can give you a place to try dont hold it agist me if ya dont find one http://list.driverguide.com/list/index.html
Jan 21, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Philips universal codes
If you dont have the codes for a philips universal remote you have to press code search and TV at the same time till the led light stays on. Then press the power button a few times untill the power turns your TV off, then press the OK button. After that the code should be in the remote.
Dec 07, 2007 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
