Question about Kubota Garden
Kubota tracter i changed oil and forgot to put desiel in and now wont start any solutions
Changed oil now wont start
  • 1,383 Answers
Bleed injectors
Posted on Mar 21, 2014
Kubota smokes blue then nocks when idled down no power lose only 200 hrs this started after oil change used all kubota parts and oil
The only time I've seen something like this is when somebody forgot to empty the old oil out before adding new oil. Have you checked the oil level?
Feb 27, 2016 | Cars & Trucks
Kubota m110 runs rough don't start
If it runs rough, it must start.
I'd be doing basic but complete maintenance.
- Oil change
- air filter service
- spark plug replace
- drain and flush carb
Jan 06, 2016 | Kubota Garden
L2050 kubota tractor after engine gets hot if i shutdown it will not crank over after cool down starts back up.
Nest time it is hot and does not start, check for spark. U could have a thermal issue where the ignition coil gets hot and stops working till it cools down.
U mentioned glow plugs - is this a diesel powered unit? Check for proper oil level in unit? Oil pump? Poor lubrication will cause an engine to expand when hot and not restart till it cools down.
Oct 13, 2015 | Kubota Garden
Change seal for PTO kubota f3680
Remove the PTO shaft extension from the shaft put a drain pan under to catch the oil Tap a chisel or other tapered tool in behind the seal flange and work the seal out install a new seal an re-install oil up to full level
Jun 13, 2015 | Kubota Garden
What would be wrong if it runs and fills the oil up with desiel ?
No idea of what your saying
If you put the wrong product in the motors
crankcase,drain it out & add the correct oil
If you put diesel fuel fuel in a gas tank,then you
have a big problem & will have to remove the
tank & clean it & change the fuel filter
Diesel Fuel in the motor oil will ruin the motor
after about 20 miles on the road from lack of
lubrication
I would guess you know all that I said before you came here
Sep 28, 2014 | Cars & Trucks
Kubota troubleshooting
2012 kobota tracter change my oil anut filter on and didn't put dieseal my filter and now it wont start any stions
Jan 01, 2014 | Motorcycles
The best oil for sport utility desiel 2.5 engine
It depends on the user w/c oil u prefer. If u are just ordinary guy that always forgot the maintenance period of change oil, use a full synthetic lubricant, very long life, viscosity is good, and very expensive!
If u are a very sensitive and got no amnesia, use the full high grade 2W/50. Price is reasonable, got 3 months/5K kilometer life.
So its up to u, the maintenance of ur engine depends on the user!
Hope that clears everything
Jun 16, 2011 | Mitsubishi Montero Cars & Trucks
I have a small kubota tractor -L1800DT -deisel motor. It starts but stops a rter a fer seconds running, . When it does go, it slowly fades in power and stops. I have replaced the fuel filter which was...
Andy, a couple of ideas for you: first, check to see if there are two fuel filters. Some Kubotas have one filter in the engine compartment, but another one under the chassis. If you only changed one, you could have another one still plugged up. The other problem that would cause the engine to lose power shortly after starting would be a dirty air filter, so check that too. Good luck! Please rate my solution if helpful, thanks.
Aug 09, 2010 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
Why is my engine very smoky when accelerating . I have just bought this car and can anyone recommend the best solution. Is there any chance it could be the injectors needing attention-can they be cleaned....
if its black smoke I would suspect a fuel issue. several things will cause this... need diagnosing. If its white smoke you could havea severe issue and it needs to be diagnosed. If its grey smoke you may have oil entering the cylinders and need it to be looked at. If the car is not in your name yet and you need a smog test its the previous owners responsibliity by law to fix this. You cant change ownership till it passes smog.
Nov 23, 2009 | 2003 Nissan Pathfinder
Engine wont start
Is it desiel,if so are the glow plugs working
Sep 12, 2008 | 2006 Ford F-250 Super Duty
Garden Logo
105 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
