Question about Remote Start System
Remotes do not work
Neither remote works engine will not start and doors do not lock or unlock is there a battery in the reciever
  • Devin Brenneman
    Devin Brenneman Apr 19, 2014
    Hi michael grant, I want to help you with your problem, but I need more information from you. Can you please add details of the model number on the remote, or what kind of system you have?
    Thank you
  • 22 Answers
SOURCE: the battery was taken out
Put the key in the ignition turn in two clicks. Take the key out hold down the program/valet button on the remote start then hit the unlock button on the remote.
Posted on Dec 04, 2008
  • 5 Answers
SOURCE: i have a viper alarm with remote start the remote
the alarm is in valet mode .open a door press lock unlock lock on the remote and it should take it out of valet mode
Posted on Oct 09, 2009
  • 33 Answers
SOURCE: battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Posted on Oct 23, 2009
SOURCE: Keyless Entry doesn't unlock my doors anymore
Did you get help? My problem is similar but not as bad. My viper550ESP no longer remotely unlocks the doors (well very, very occasionally it does). That is the only problem.
Posted on Nov 25, 2009
SOURCE: SKODA FABIA REMOTE KEY PROBLEM
my skoda remote does not function, i have change the remote battry , yet the same. how do i go about it.
Posted on Sep 09, 2010
I have a 2007 Chevy Suburban. My remote door locks only work briefly when I exit my car. If I return to open the door locks shortly there after, they will not unlock the doors!! I changed the battery...
Do you have a phone charger plugged into the power socket? New cell phone? Laptop in the vehicle or any new camera, radar detector? Anything electronic can interfere with remote entry system
Nov 18, 2017 | Chevrolet Suburban 1500 Cars & Trucks
2002 VW Cabrio alarm problem: alarm will not un-set. Door will not lock using the key OR the remote. Hitting "alarm off" button on remote, it unsets, then arms again immediately. With engine...
i have a 2002 vw cabrio and won't start after i took out the battery everbody is telling me that anti-theft is lock mode how do i rest it so i can start my car
Nov 08, 2010 | 2000 Volkswagen Cabrio
I changed battery and now it dosnt work
You lost your program of the key module follow these instructions.
To Program a Remote for a VW
Put your good key in the ignition and turn to "ON", do not start the engine. Make sure all the remotes you want to use are present because they have to be programmed at the same time.
- Close the door and insert key #2 into the driver's side lock. Lock the door.
-Within 5 seconds of locking the door, press unlock 2 times on the new remote, key #2.
-(if this is remote #3, press unlock 3 times. if this is remote #4, press unlock 4 times).
-If there's a chirp or beep do not press it again. This means that the car has recognized the new keyless entry remote.
- Repeat with other remote or unlock the car and turn off - done.
Mar 23, 2010 | 1996 Jaguar Vanden Plas
Key remote wont work even with new batteries
The remote likely needs to be reprogramed. If you have both remotes you will need to take these to the dealer and have them reprogramed.
Jan 25, 2010 | 2000 Volkswagen Beetle
Need to reset the key fob after replacing the battery
You should not have to reset the key fob after a battery replacement. The signal from the key fob stays the same and is programed to the reciever.
If the key fob needs to be reprogrammed then follow these steps.
1. Have all key fobs with you during programming.
2. Sit in the vehicle with all doors closed.
3. Lock all doors using the Lock/Unlock switch on the door.
4. Insert and withdraw the ignition key 7 to 9 times within 10 seconds (do not turn the key, just insert and withdraw).
5. The 4 way flasher indicator on the dash should flash once or twice.
6. Insert the ignition key and turn it on (key on, engine off).
7. Press any button on one remote and the 4 way flasher indicator on the dash should flash once.
8. If you have more key fobs to program use the Lock/Unlock button on the door to unlock the doors and then lock the doors.
9. Press any button on the next key fob and the 4 way flasher indicator on the dash should flash once.
10. Repeat if you have more key fobs. Only 5 can be programmed.
11. To exit, simply turn of the igniton and remove the ignition key.
12. Unlock the doors using the Lock/Unlock switch on the door and exit the vehicle.
13. Make sure the window is down when testing remotes in case you leave the keys inside.
14. Close all doors and test all remotes that were programmed.
Do not skip any steps or the process will not work.
If the 4 way flasher indicator does not work when inserting the key, you will need to start the process from the begining. If it still does not work the receiver may be your problem.
If the 4 way flasher indicator does not flash when pressing any button on the key fob then the key fob is the problem (dead battery or defective remote)
Dec 18, 2009 | 2002 Nissan Xterra
Central Locking does not work
You must reset your remote control in order for the lock/unlock to work properly.
To reset remote you would:
1)Insert Key in Ignition Turn to Position 1(Don't Start the Engine) for about 5 seconds
2)Turn Key Off and HOLD the LOCK button on Remote while pressing the UNLOCK 3 TIMES
3)Release both lock and unlock buttons you are holding
4)All doors should automatically unlock
And exit the door and lock with the Remote.
Sep 19, 2009 | 2000 BMW 3 Series
Passlock
turn key all the way on (not to start) let set for 1 hur cycle key and try it.
Jul 20, 2009 | 1999 GMC Jimmy
Remote starter does not work but will unlock and lock doors.
depending on your alarm which it sounds like a viper model maybe? on my 02 you have to incorporate a factory alarm bypass module in order to be able to start the truck, they run about 100.00 bucks and have to be profssionally installed. The truck wont start because the computer isnt recieving the proper starting sequence due to the factory alarm
Jan 11, 2009 | 2003 GMC Sierra 1500
I have a 2003 sierra and my remote starter would not work, it would lock and unlock only, checked out this site found the solution, tried it and in two seconds i solved the problem, Just press the lock button and the start button and viola it works again, thanks for all your help , GGGreat site glad i found it John
Dec 08, 2008 | 2005 Pontiac G6
Remote Start System  Logo
43 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
