Question about Timex 1440 Nylon watch
Need strap for TIME FORCE 3004M
YELLOU
My diesel DZ1131 watch's strap has broken for the second time ina row..i wou like to replace it with metal starp....would it be possible///
Unless the watch has a unique design on lugs for the strap, you should be able buy a strap that is interchangeable with the existing one form most watch shops.
They will usually fit it for you for nothing.
Mar 06, 2011 | Diesel Strap DZ1131 WW Watch for Men
The battery was flat. renewed it and all working EXCEPT it no longer can pick up heart rate from monitor (tried it with another monitor and still will not pick up heart beat) Help Please...about...
i guess stopped of use your strap for a long period of time. so you need to nicely clean the strap and try a lot of times until it work again.
I happend to me before and the strap worked only after the 10th session on the treadmill
Feb 11, 2011 | Polar FT60 Heart Rate Monitor (Purple)...
Its too big to fit my hand good but also i cannot shorten it enouph so it can fit me without being extremely tight. Is there an alternate way to shorten it. I noticed 4 holes where the clasp is and was...
Some clasps have holes in them to allow you to adjust the straps in smaller steps than removing links.
It sounds as though yours in one of these.
The pins are spring loaded just like the ones used to fasten the strap to the lugs of the watch, so you can apply a probe to one end of the pin with one hand, while applying a gentle force in the direction you wish the strap to go with the other hand.
Then do the same with the other side and repeat as needed.
Jan 05, 2011 | Breitling Bentley 6.75 A4436212.G573.970A...
How do I shorten my Ice watch strap?
mcdevito75 here, I imagine you mean a Band (metal) they can be shortened by removeing links from the band itself, you"ll need a specific tool called a link remover tool. they are available on ebay. However by the time you get the tool and the time to do the work, and if you don"t do any work on watches, the best bet is to look for a small watch repair shop in your area to remove these links. Hold onto the removed links for later replacement. If it"s a Strap (material) on your watch, say, leather, rubber etc. simply cut the excess strap at an angle with scissors.
Jul 17, 2010 | Watches
Need a replacement strap. cannot use a traditional strap and cannot find a replacement. need help
If it doesn't take a traditional strap you will probably have to contact Fossil. They like very much to make different looking watches and alot of the times part, if available , will only come from them. Their number is 1-800-449-3056
Jul 19, 2009 | Fossil ES9720 Wrist Watch
How to change battery in Casio wave ceptor4305
If there is no any screws holding that 'metal strap' then carefully check both ends of it. You will notice that the ends (or one end) are snaped over the little plastic hooks. Take pointed tweezers and push that end outwards (away from battery) and the contact (metal strap) will pop out.
After battery replacement, just push the contact back into place till it fixes.
If there are screws holding the contact, just undo them.
Be quick when replacing battery- you have 2 or 3 minutes to do that, otherwise all data will be lost and you will need to reset watch completely.
Dec 19, 2008 | Casio PRG-40T-7 Pathfinder
Timex 1440 Sport watch needs a new strap
Hi I have a 1440 sport watch , somehow I got it into 24 hr mode vs regular time. Can't seem to figure outhow to get it out of this.....HELP :)
Mar 22, 2008 | Timex 1440 Nylon watch
Watch strap
Please call this number 1-718-7298600 x 272, order a strap for kc1232, usually it takes you 7 days to receive this strap, and there will be four new screws comes with your order, I believe it cost you $18.00 to have new strap.
Tsai
Jan 19, 2008 | Kenneth Cole KC1232 Wrist Watch
Strap
If you ever need a watch band for a casio watch just call their parts department and they should be able to send out one for whatever model of watch you have. Their number is 800-223-2001
Oct 06, 2006 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Timex 1440 Nylon watch Logo
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
