Hp 4700 printer used to be hooked up w3ireles , it worked good then . now withe a new gateway it is direct wired and won'[t work
    Master:
  • 397 Answers
Did you ensure the drivers were installed first of all? If so, just try removing and re-installing them as the first port of call.
Posted on Mar 21, 2014
What to do now hp 4700 13.xx.xx jams all different types.
With all you have done already I'm sure you have cleaned or replaced the pickup roller as this is the most likely cause.
This is a difficult printer to work on and parts are hard to come by so I would get an opinion from a local HP expert.
If the printer works okay with single-side jobs, you could just manually duplex your jobs.
Jul 01, 2014 | HP LaserJet 4700 Printer
Hp Color Laserjet 4700 Printer Shows Processing
Either the job you are sending over is very large and the printer does not have enough memory to accommodate the print job or you are not using the correct driver. If you will go to the printer under "devices an Printer" and right click on the printer icon, select "printer Properties", and navigate to the advanced tab, you will see which driver your computer is using. The three most common drivers are PCL5, PCL6, and Post Script (PS). try using a different flavor as some printers like some better than others.
Each type of software installed in your system has to coincide with other softwares. A driver is a type of software that allows the hardware connected to your PC to communicate with the system. A sudo language so to speak. If the hardware is having a tough time with the communication you can try a new dialect and see if it improves.
Here is a link where you can download the various drivers for your system based on your flavor of OS for the printer you specified Drivers Software Firmware for HP Color LaserJet 4700 Printer series
Apr 17, 2014 | HP LaserJet 4700 Printer
Hp 4700 won't print pdf
For QuickBooks Pro, Premier, and Enterprise Solutions working on the Windows XP platform:
  1. Choose Windows Start button and open the Printers and Faxes window.
  2. Right-click the QuickBooks PDF Converter icon and choose Properties.
  3. Click the Ports tab. Click the Add Port button.
  4. Select Local Port. Click the New Port button.
  5. For the new port name, enter PDF1. Click OK.
  6. Close the Printer Ports window.
  7. Select the PDF1 checkbox, if it is not already.
  8. Click the Advanced tab.
  9. Select Spool print documents option.
  10. Clear the Enable advanced printing features checkbox.
  11. Select the Print directly to printer option.
  12. Click the Apply button. Click OK.
  13. Choose Windows Start and choose Run.
  14. In the Open field, enter %windir%. Click OK.
  15. Right-click the System32 folder and choose Properties.
  16. In the Properties window, click the Security tab.
  17. In the Group or user names list, select Users. In the Permissions for Users list in the Allow column, select Read, if not already selected, and select Write.
  18. Click the Apply button. To save the changes, click OK.
  19. Restart your computer.
  20. Note: For the changes to take effect, you must restart your computer.
For QuickBooks Pro, Premier, and Enterprise Solutions working on the Windows Vista platform:
  1. Make sure that you are logged in as Windows Admin.
  2. Choose Windows Start > Printers.
  3. Right-click the QuickBooks PDF Converter icon and choose Properties.
  4. Click the Ports tab. Click the Add Port button.
  5. Select Local Port. Click the New Port button.
  6. For the new port name, enter PDF1. Click OK.
  7. Close the Printer Ports window.
  8. Select the PDF1 port checkbox, if it is not already.
  9. Click the Advanced tab.
  10. Select the Spool print documents option.
  11. Clear the Enable advanced printing features checkbox.
  12. Select the Print directly to printer option.
  13. Click the Apply button. Click OK.
  14. Restart your computer.
    • Note: For the changes to take effect, you must restart your computer.
  15. From QuickBooks, print, email, or create a PDF document.
For QuickBooks Pro, Premier, and Enterprise Solutions working on the Windows 7 platform:
  2. Choose Windows Start > Devices and Printers.
  3. Right-click the QuickBooks PDF Converter icon and choose Printer Properties.
Hope that it will work for you,
Thanks,
She Morillo
Dec 04, 2012 | HP LaserJet 4700 Printer
HP 4700 not printing cyan
If your printer is missing a color it could be caused by (off the top of my head) 3 possibilities.
1. High voltage board
2. laser/scanner assembly for that color
3. DC controller might need a firmware upgrade, www.hp.com
Run the PQ diagnostics, check the cyan color
Run the Cartridge Disable diagnostic. Remove all cartridges and take the black cartridge and insert it where the cyan normally is. If the black prints in the cyan slot, your cyan cartridges are bad. If the black doesn't work then go to #3 above. It won't cost any money to upgrade the firmware. If it still doesn't work call in a printer tech.
At this point you may need a printer tech.
Nov 01, 2011 | HP LaserJet 4700 Printer
I have a brand new hp colour laserjet 4700 never used displaying error 59.co.how can i rectify the problem
Call HP or a printer tech.
Could be one of two problems. Both require a tech to check it out.
1)could be a bad disengaging motor
2)Or the alienation(SCIP) cams may be catching on the sheet metal inside the printer.
Sep 16, 2011 | HP LaserJet 4700 Printer
I have a Sansui G-4700 Pure Power DC Stereo Receiver. We were happy with it for many years. Five years ago, we moved from a house to a condo, and it has been in storage since the move. I am thinking of...
Of course it will work with any standard stereo RCA source (which just about everything STILL has) but it won't work directly with any digital sources. It has NO digital interfaces.
Jun 22, 2011 | Sansui Audio Players & Recorders
I have a problem in my hp4700 printer.everyday morning i need to shake the tonner for getting good quality print.Iam using hp genuine tonner catridges.I changed all toners with new HP genuine.still printer...
Normally that works when toner is real low. But if you are doing that with good toner levels then it may be humidity in the room making the toner powder clump or stick.
Have you performed a clean cycle/test. You may have problems with a fuse roller but that would be a longshot thing to check for.
Mar 23, 2010 | HP LaserJet 4700 Printer
How to replace image fuser kit for hp laserjet 4700n
turn off the machine. open upper front cover. remove the old fuser and insert the new one. turn on the machine and enjoy your printer with new fuser kit.
Jan 20, 2010 | HP LaserJet 4700 Printer
HP 4700
Try this
Remove all EIO devices and memory Dimm's execpt the firmware dimm.
Start the printer. If the error is gone then place the dimm's / EIO devices one by one.
(Don't forget to switch off the printer.)
If the error is still there then you might have a faulty firmware dimm.
Oct 23, 2008 | HP LaserJet 4700 Printer
14 people viewed this question
jasbo
jasbo
