Free tv repair advice
Philips LCD went bang, 3a fuse in plug also blew. Blue disc capacitor on power supply board exploded. Can this capacitor just be replaced and tv used again?
TV tuning problem China kit 14 inch tv
Posted on Jan 02, 2016
  • ayazjan Jan 02, 2016
    plz halpp anybody
    Master:
  • 397 Answers
Potentially so, however I would get the TV fully checked over by a professional if it has been subject to a surge. If a component further down the line caused the initial surge replacing the blown cap will only result in another bang as soon as you plug it in.
Posted on Mar 21, 2014
  • Greg Buckley
    Greg Buckley Mar 21, 2014
    Thing is that when it exploded it took most of the rating info with it, all I can gather really is that it's 10kv. And the rating above that starts with 10. Tried Maplin but they've only 100 volt, I've added some images
  • Greg Buckley
    Greg Buckley Mar 24, 2014
    any ideas?
  • 16 Answers
SOURCE: Sylvania lcd color tv
if you have replaced the fuse already then you know how to open the back of the set . The problem is more than likely one of the diodes in the rectifer circuit . They will be the four large black components The bad one will have to be desoldered and a new one soldered in its place . It will take a small amount of technicial ability but can be done easily at home.
Posted on Oct 25, 2008
  • 718 Answers
SOURCE: OK,I've replaced the Power Control Board and the
Polaroid TLA-04011C
You can get a service manual from;
http://www.polaroidsupport.com/polaroid/docs/TLA-04011C_TLXB-4011_TLXB-4241_ServiceManual_20070613.pdf
This will give more diagnostic flowcharts etc. Could be useful in the future also.
Posted on May 07, 2009
a1electronic
  • 30 Answers
SOURCE: power supply is bad on philips plasma 50 inch tv, it just clicks
nice job... thats the most common problem with all LCD tv's now
Posted on Jul 21, 2009
  • 157 Answers
SOURCE: Philips LCD TV 37PF5520D/10. TV will not switch on.
philips has a problem with bad caps(swollen)in power supply-try shopjimmys.com enter model number-scroll down til you find power supply-order it simple to put in.if they do not have it write down part number then google it to find one--you also can change the bad caps yuorself if you are handy with a soldering iron
Posted on Sep 11, 2009
SOURCE: I Have a Philips LCD TV model#30PF9946D/37.
Oh yeah, you can most certainly change the power supply by yourself.
It's easy to locate - just follow the power cable - and easy to replace.
Only make sure to let it discharge before you operate it. 10-15 minutes disconnected from power should do.
However, there's no guarantee that the problem is in the power board.
There is a very good chance it is, in fact, not there.
There's another board which commonly fails on many plasma TVs and the effect is exactly as you describe. It's called Y-Sustain board and you can tell which one it is by looking at the side of your TV and seeing which large board has manny plastic connections that enter the display on the side.
That board often has one or two fuses on it - I'd check those first.
Posted on Nov 03, 2009
I have just got a 42'' philips lcd cineos model
You could have shorted out the mainboard from the power surge. If this is the case, you may only need to replace some capacitors if you are handy with a soldering iron.
If you don't have soldering experience, I would recommend replacing the whole board. Search around online for the schematics, or replacement board for sale
Oct 18, 2012 | Televison & Video
Philips 47PFL3603D LCD TV bue led flashing no power
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Jan 05, 2012 | Philips 47PFL3603D LCD TV
My samsung ln52a650 blew a fuse during normal operation. one second it worked the next... nothing. popped her open and couldn't find any damage/arc/flash.... exploded parts. i hear this is a common...
U have all the tools and understanding basic electronic and also can do basic soldering?Yes.The tv power supply board,that the board,where the power a/c cord plug into it.Check the whole tv power supply board carefully for dying capacitors components parts.It is usally have bulges or puffing up capacitors parts indication of components capacitors parts are dying and needed replacement.Replacement for those new capacitors component parts with the same Micro ferit and the voltages of those new components capacitors parts in a higher voltages like 5 or 10 voltages higher than the old components capacitors parts u are replacing for a better heat resistance for the tv operation of the tv power supply board for later on tv use.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 08, 2011 | Samsung LN52A650A LCD TV
My phillips 42 inch lcd tv just went pop / bang and the picture disappeared - its now dead with no light - checked and replaced fuse
The power supply board is dead.That the board,where the power a/c cord plug in to it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 14, 2010 | Philips 42PFL5332D 42 in. LCD Television
The red light in the bottom left corner keeps blinking and it wont turn on. Yet when i unplug the tv and plug it back in the blue light comes on but then turns into red light blinking again and it wont...
Ur tv power supply board have dead componnents call capacitors.These capacitors are leaking gas,and it bulges up on it top or puff up on it top.These capacitors parts are dead,they must be replaced.U know basic electronic's and soldering?Take ur tv aparts,the board where the power cord plug into it.That ur power supply board,searches all around for these dead gas leakage capacitors,replaced them.Ur tv power LED light will be stable and the tv power will work again.Or tries websites like Shopjimmy.com,ebay.com to buy a whole reburbish power supply board for the replacement.
May 24, 2010 | Philips 42PFL5603D - 42 IN. LCD HDTV
Turned TV on with remote, circular indicator went
Please call Memorex customer service at 800-919-3647.
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If the TV is less than one year from the date of purchase, it is still under warranty. Call the number above so that you can have the unit repaired.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 17, 2009 | Memorex MLTD2622 26 in. LCD TV
My wharfedale lcd42f1080p just went bang when plugging it in!!
Sounds like something else in the power supply. The surge inrush current could have blown the bridge rectifier. (device which changes AC to a pulsating DC for the power supply). You may need to have the power supply serviced or replaced.
Apr 15, 2009 | Televison & Video
Please help my Polaroid 37" lcd
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 08, 2017 | Polaroid FLM-3732 Television
No picture
unfortunitly sound is one circuit ,,while all the rest makes a picture. hearing a bang could mean a capacitor exploded, your fly blew up..or even you lost a tube. you need a tech. good luck
Aug 15, 2007 | Philips 60PW9363 60" Rear Projection...
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
