Question about Exercise & Fitness
Image pro11 asi650 e1 code
I have an Image Pro11 ASI650 treadmill that shows E! error code the motor and the MCB have been checked and are ok. When switched on the incline motor attempts to operate and then returns to the start position and the E1 code is displayed. The wiring harness has been checked and is also ok could the fault be the senor on the incline motor if so how is it checked and fixed?
    Scholar:
  • 190 Answers
If you know where the sensor is then spray all around that area with a can of dust buster, the air spray used to blow out dirt on pc key boards. Check for loose wires on the sensor and for maybe any kinks in the wire from the sensor up to the screen.
Posted on Mar 21, 2014
2 Suggested Answers
  • 6 Answers
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Posted on Mar 25, 2010
Merit 725 T plus reading E1
If you wish to get some details about treadmill error codes and repair; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 28, 2016 | Exercise & Fitness
How long does it take for someone to help me, on this site.
How fast you get answers depends on many factors. I just picked up your question but have spent time finding and reading the manual. I am by no means a treadmill expert, but my first thought was treadmill belt tension was too loose to keep the movement sensor happy.
Moving the belt manually would be irrelevant as the electronics would not be monitoring to throw up the E1 Error..
The manual tells you to check all these things.
E1
Loss of Feedback Speed Sensor disconnected Check Speed Sensor
Connection
Speed Sensor Misaligned Check Sensor position
Faulty Speed Sensor Replace Speed Sensor
Loose Display Connection Check Display Cable
Connection
Faulty MCB (D2 LED on) Replace MCB
Faulty Drive Motor Replace Drive Motor
If BH Fitness are being no help, I would be asking them to take the machine away or get it fixed on-site.
So does the belt turn when you switch it on? Is the belt centrally aligned when it spins?
Page 35 shows belt adjustment and I would guess tension although not specifically mentioned.
http://www.bhfitnessusa.com/manuals/final/ts2.pdf
Jan 05, 2016 | Bh Fitness TS2 Folding Treadmill
Why my treadmils start working and and stops
Hi There, sorry to hear of your troubles. Could you mention what brand and model of treadmill? If this is a Horizon treadmill with E1 error, like models T101 and others from the years 2011-2013, there is one thing you can try. Unplug the treadmill and remove the motor cover to get to the Motor Control Board, or MCB. Be certain the treadmill is unplugged from the wall! Now, look on the MCB on the right side there may be ONE small blue "block" with a tiny screwdriver slot in the center, this is called a potentiometer, and if there is Only One, and a Horizon MCB, you can turn this pot to the right, clockwise, gently until it stops, and then back it off just a hair, reassemble unit, and try treadmill. If this doesn't help, the MCB most likely needs servicing due to failing storage capacitors which get quite hot while in use and can degrade over a few years of service. You can find some help by looking up jatinah electronics, who repairs these modules. Good Luck! ;o)
Jan 26, 2015 | Exercise & Fitness
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 28, 2012 | Kettler treadmill Pacer
Hello, I am trying to find the file PRO11.MSI in my computer. What do i do to fix the problem i am uable to use excel.
The PRO11.MSI File will be on the CD that you used to install Office.
Hope that helps, pls rate the solution
Nov 11, 2010 | Microsoft Office 2003 Pro (269-07387) for...
My microsoft office 2003 requested for a file named pro11.msi. now i want to download it.
You cant download PRO11.MSI. PRO11.MSI is a file that come with your Office 2003 installer. So try to look it on your CD or on your harddrive.
for more information regarding how to download pro11.msi refer the below website
http://office.microsoft.com/en-us/help/locate-missing-msi-files-HA001118572.aspx
Nov 06, 2010 | Microsoft Office 2003 Pro (269-07387) for...
THEREIS A FAULT CODE L5 COMING UP ON MYT102HERRITAGE TREADMILL CAN YOU HELP
L5 or LS is short for Low Speed error. It basically means that the speed sensor is not picking up a signal. Unfortunately its a pretty vague error code and can be caused by several different problems. First you have to determine whether or not you have belt movement. If you have a LS with belt movement you know that it is related to the speed sensor itself (or the MCB motor control board - the part of the MCB that handles speed sensing function). If you are getting an LS without belt movement you have to check to see if you have power output from the MCB. If you have no power output, check fuses, if fuses are good, you will need the MCB replaced. If you have sufficient output its drive motor related. Aside from a problem with the drive motor, it is possible that another factor is stopping the motor from turning (ie locked up roller bearing, foreign debris, etc.) If it is a case of
faulty electronics the next question is, is to figure out what caused it to fail. Most MCBs don't fail on their own, something else usually causes them to fail. The bottom line: The LS error can be
complicated and should really be inspected by a professional to full assess the issue. What I am saying is call the manufacturer and if it is under warranty send the treadmill back.
Jun 06, 2010 | York Exercise & Fitness
My tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
May 16, 2010 | Exercise & Fitness
Asi image pro 2 treadmill error code 2
Loss signal or No Speed: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt2_bing.gif now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
May 11, 2010 | Exercise & Fitness
E1 error code
Your problem might be that the sensor magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jun 20, 2009 | Exercise & Fitness
Exercise & Fitness Logo
64 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
