Question about Chicago Pneumatic Air Tools & Compressors
Working temprature of compressure is increasing in short time and comoressure get stopped.
Within 10minutes temprature of comp goes 85 to 105 and get stopped, what are the possible reasons while new set of filter is mounted.
  • Joe Garcia
    Joe Garcia Mar 23, 2014
    Hi shree prakash kaushik, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?Is this a rotary screw air compressor??
    President:
  • Chicago Pneu... Master
  • 1,388 Answers
It is normal for the air to heat up as pressure increases. The temp can easily increase to 200 degrees depending on pressure. Most likely problem causing your motor to stop is the capacitor (should test to within 10 percent of rating) or using too long /thin extension cord. If capacitor is good and low power is not problem, then make sure that the check valve (non-return valve) is not leaking pressure back to the pump causing motor to overload. Good luck
Posted on Mar 24, 2014
My siren under the hood got wet...if I fan dry it over night will it work, I caught it within 10minutes
it depends if water bridged any contacts and shorted them out only tearing apart unit and going over it with an ohms meter //so as to your answer it depends you may get lucky and when it dries out it works
Aug 12, 2015 | Cars & Trucks
How water temprature not going above 55.
Unknown what product you have.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
Add a comment and describe product in detail
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 07, 2013 | Water Heaters
Why won't my compressure stay on when its being
if the level goes to low on the freon the a/c comp. will shut down, if you fill it and it dont main tain oresure then you have a leak somewhere in th system
Aug 07, 2011 | 1996 Chevrolet K1500
I have a 2003 Impala Base 3400 V6...And my AC is making a sound. I was told its the clucth when you turn on the ac. Is that fixable at home or take it back in to the shop.
wuold suggest you replace complete assy clutch and comp this will be more expensive but will be better in the long run if a clutch goes bad usually form to much strain from compressure pressures if you do this at home you will still need to see a shop for vacume on the system before recharge
Feb 05, 2011 | 2003 Chevrolet Impala
My Car temprature goes up when I am stopped on Triffic Light. The AC stops working at that point too. AC starts working after I drive without stopping. The temperature goes down too. I checked the Radiator...
Good day!
electrical radiator fans typically have 2 speeds a high and a low. you may be having an issue with the high speed of the fan, that is why when you are not moving the temperature goes up!
Aug 24, 2010 | 2001 Nissan Sentra
My computer fan speeds up whenever I'm on the
Nothing ... probably ... your fan speeds up when the processor temp goes up ... the more you are doing, the more cooling you need. The processor is calling for more cooling so the fan runs faster.
If this is a concern for you, you may wish to consider adding another fan to your case. In any event, make sure your power supply fan is clean. Use a vacuum or canned air to clean.
Mar 14, 2010 | Dell OptiPlex GX270 PC Desktop
COMPRESOR GETS REALY HOT IS IT THE SWITCH BAD OR THE COMPRESSOR
Reasons for a hot compressor are:
  1. It is just hot and is not a problem.
  2. Lack of ventilation to compressor.
  3. System is short of refrigerant which prevents the return refrigerant from the cooler being cold enough to cool the comp.
  4. If system is short this could make comp run continuosly trying to reach temperature
  5. If the thermostat is stuck on the inside cooler will probably freeze up, so that shouldn't be it.
  6. Compressor could be "letting by", meaning hot gas goes into the cold side of comp, if that is if it will stop working eventuallly.
Hope that helps.
Aug 03, 2009 | Roper Refrigerators
Haier window airconditioner cooling is not effective
there is a temperature sensor bulb in front of the evaporator. check if it is too near to the coil. move iit away about an inch.
Apr 30, 2009 | Haier HWR12XCB Air conditioner
Open Questions:
Air Tools & Compressors Logo
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
