Question about Lands Phones
Automatic pickup of all calls
An automatic pickup of all calls occures
  • Grigoris Klokanas
    Grigoris Klokanas Mar 23, 2014
    PANASONIC TES TES 824 Allthough never programmed, an automatic pickup of all calls is on.
Tone changes in pearly gates pick up
What you describe sounds like pickups fighting against each other meaning, does this occur when using pickups individually or together? This is normal when using more than one pickup together, if it occurs in single mode, something is wired wrong. Another thing is, If using single, are you splitting coils? Individual coils wired wrong can do this, a bad pickup selector switch can also. A loose wire or fiber touching the tone pot capacitor or ground could also. A dead coil on a humbucker can as well. I'm guessing that you are using these in combo meaning a possible pickup selector switch may not be switching properly. The player's level of experience is also in my mind since, all of my guitars do the exact same ONLY when I use more than one pickup. I hardly ever use more than one at a time unless I'm playing a strat.
Mar 28, 2014 | Seymour Duncan ShPg1 Pearly Gates Pickup...
1997 Nissan D21 hardbody pickup distributor problem
Hello
The engine and automatic transmission in this vehicles drive train are fully electronically controlled by a computer called the PCM (Power Train Control Module). Whenever a problem like this occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM
Aug 09, 2012 | 1997 Nissan Pickup
Pickup starts great, goes into all gears but won't move. It's like it is still in nutural.
Assuming the pickup is an automatic, check the transmission fluid. The #1 cause for transmission slippage is lack of Automatic Transmission Fluid.
If the pickup is a standard shift, the pin that connects the shift to the transmission has likely broken. You would still be able to shift from the inside but the gears won't engage. A bad clutch is also a possibility but you would have noticed a burning smell prior to the clutch giving out.
Dec 20, 2011 | Cars & Trucks
How do i find out what has been recalled on the 2007 charger sxt
Recall date: 10-02-2006 Units potentially affected: 2,333 NHTSA campaign number: 06V341000 Defective part or component: POWER TRAIN:AUTOMATIC TRANSMISSION
Description: On certain passenger and sport utility vehicles and pickup trucks equipped with automatic transmissions, the software programmed into the powertrain control module can cause a momentary lock up of the drive wheels if the vehicle is traveling over 40 mph and the operator shifts from drive to neutral and back to drive. If the drive wheels locked up, loss of vehicle control could occur increasing the risk of a crash. Dealers will reprogram the powertrain control module free of charge. The recall began on October 2, 2006. Owners may contact DaimlerChrysler at 1-800-853-1403.
Feb 08, 2011 | 2006 Dodge Charger
I want to shut off answering machine
Use the Reception Mode button to set appropriate answering mode - press it repeatedly until a small arrow on the display will point to the desired option:
"TAD" - is the one you are using now, when the answering machine picks up the calls.
"TEL" - is the setting when no automatic pickup occurs, you always have to pick up the call and either talk (if there's a person on the other side), or press START to receive a fax (when you hear the fax beeps on the other side).
"FAX" - is the setting when after four rings the fax will pick the call up automatically (no answering machine). If you pick up the call manually after 1-2-3 rings (before the automatic pickup) you can either talk or START fax reception.
It's good to check from time to time if the reception mode is as you want it, it's easy to change it by mistake.
Good luck and come back with a testimonial if helped :)
Jan 31, 2010 | Sharp UX 460 Plain Paper Thermal transfer...
Not picking up calls, not sure if my son has pressed something or there is a fault with the machine.
Look at the display. On the right there is a 3-character mode indicator. It can be:
MAN - manual pickup
FAX - automatic pickup, only fax will try to "speak" to the other side
F/T - automatic pickup, device will signal if there's no fax signal on the other side, only someone trying to speak
TAD - Telephone Answering Device
Press the "MODE" button several times and see how the display cycles through these options; just press it repeatedly until the one you want to use appears.
If however the device is set to something else than MAN and still doesn't pick up calls, then it indeed might be faulty.
Oct 28, 2009 | Brother FAX 930 All-In-One Thermal Printer
Cisco 7970 ip phone, can't pickup call
Make sure you have both phones in the same call pickup group. I have never used the group pickup button. The regular pickup button is what I use.
Just to be clear the procedure is..once phone A rings you hit the pickup button on any other phone that is in the same group as phone A. After you hit the pickup button the call will be drawn to the phone that you hit the pickup button on. Once the call is on that set hit the answer button to answer the call.
Jul 10, 2009 | Cisco Computers & Internet
I have one line with three numbers attached to it... one of them is a fax. I have set up distinctive ring, but the fax machine won't pick up on it's specific ring. I have tried them all. I can manually...
Hello Tiffany,
As far as I'm concerned, HP does not make Fax machines that work off of distinctive ring systems. They only work off of the number of rings before automatic pickup.
My recommendation is that you set the fax number to a dedicated line.
If you need more assistance for automatic pickup, I can guide you through setup, if you can give me the model of your fax machine.
Feb 27, 2009 | HP Photosmart C7280 Laser Printer
Lands Phones Logo
22 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
