Question about Bronica ETR-Si Medium Format Camera
Which 120 backs & lenses for my ETRSi do I buy?
I believe I'm supposed to find EI backs but will the ETR backs work just as well?
Also - I have a Zenzanon MC 150mm, which other kinds of lenses can I buy besides MC? What is best?
I've had this camera for at least 3 years but am just getting into it...
  • 37 Answers
All ETR backs work with all ETR cameras except the ETR-C, which only uses the inserts. The early backs have a single latch and a winding key. The middle ones have double latches and a winding thumb wheel. The Ei backs have double latches and a winding crank like a 35mm has. The Ei backs also have a locking dark slide to prevent accidental film exposure wnen the back is off the camera. All inserts work with all the back frames. I the used market you will find them in any combination (frame, insert & darkslide).
I am aware of three series of lenses: MC, EII and PE. They all work fine with any body.
Posted on Jun 23, 2009
How can I adapt the connection from my asko washer that is supposed to plug into the dryer to the outlet in the wall?
I believe the washer works on 120 Volts. All you need to do is replace the plug with a standard 120 V plug. Home Depot has plenty of them.
May 20, 2011 | Washing Machines
Hi, I have a set of
Sorry Sam, but there isn't one. I just shoot on transparencies (Fuji Velvia 100) and then scan them to obtain digital images.
Transparency film isn't cheap, and even less so with wasted shots, but it's still cheaper than the
Sep 21, 2010 | Bronica ETR-Si Medium Format Camera
Wanting to purchase Focus screen for Zenza Bronica
Keep an eye on ebay as they appear on there occasionally. However, you can't always get exactly what you want and it took me a while before I could find a split image version. All you have to do then is win it!
May 06, 2010 | Bronica ETR-Si Medium Format Camera
Had camera in damp basement. Mold got between lens
the best thing to do it drop this camara into a shop for them to fully service it you will never get all the mold spors out of it now
Mar 29, 2010 | Bronica ETR-Si Medium Format Camera
ETR film counter resets mid roll when shutter is depressed.
Hello. 35mm cameras back in the day used to suffer from this irritating problem. There is a small button that is pressed by the door edge when you close the back. Due to age(flexing and slop) that occurs with normal wear, the metal edge becomes ever-so-slightly bent, resulting in a less-than-needed pressure on this button. The button, when held properly by the back, captures a little internal gear mounted on the film counter dial--preventing its spring-loaded return. When you remove the back to re-load film, the counter immediately jumps back to "start". As the film advances, the roll increases in size and pressure against the door, causing the symptom. Go to a camera store with knowledgeable sales people and you might find one who knows how to re-work the back just-so to fix it. To be absolutely sure, however, you'll need to buy another back.
On some medium-format cams, there is a little raised "bump" on the edge of the door that precisely matches up to the position of the button. If this is the case, and you are careful, it can be gently but firmly squeezed to make it stick out more, increasing the pressure on the counter button.---Rick
Sep 16, 2009 | Bronica ETR-Si Medium Format Camera
Bronica AE II E Finder Owners Manual
Since I never use a TTL flash with my Bronica's, I'll give you my suggestion for a great solution. Using your TTL Metz flash, (make sure you've connected the TTL cord for Bronica ETRsi) take 8 shots at different apertures on A (Automatic), then take 8 shots at different apertures on M (Manual). I realize this will waste one 120 roll of film, but one negative will stand out as your perfect exposure. Yes, whenever you reduce the ISO in half, your basically overexposing the film by one f/stop. Just remember that this overexposes everything your shooting from foreground to background. With flash, this may cause your highlights to wash out, but any good lab could print for the highlights and make the background go darker. I used to shoot Vericolor at ISO 125 instead of it's rated ISO of 160.
Fotobean
Jan 21, 2009 | Bronica ETR-Si Medium Format Camera
Scratched 360 Disks
Have you tried using a lense cleaning siak? The scratches are from the lense acutally hitting the disk from trying to focus.. A good lense cleaning disk may help beyond that it may have to be serviced. I know its not he answer you want to hear but a lense cleaner is the cheaper option and its worth a shot, buy one that works on dvd lenses i wouldnt spend less than 15 bucks on one, as the cheaper ones are worthless except for cd players. The higher end ones actually have a cleaning pad on them.
Dec 12, 2008 | Microsoft Xbox 360 Console
Battery problem with ETRS
On the AEII Finder, there are four contacts on each side of the finder and also the ETRsi body. Clean the contacts on both sides and see if this helps. Another test to see if it's getting voltage from the battery is on the body contacts(on top of the body where the viewfinder slides on). Take a multimeter (any multimeter) and touch the ground (black) probe to any place on the body except the contacts and touch the positive (red) probe to each contact on the body and see if there is battery voltage anywhere. If you get voltage that's close to the 3 volts from the battery, then it's good. If not, there is a circuit break between battery & body and this requires a repair shop because the camera would need to be stripped down to locate the problem. Be aware that the body battery supplies voltage to the Seiko Electronic shutter and the AEII prism. Hope this helps.
Jul 17, 2008 | Bronica ETR-Si Medium Format Camera
120 film backs
skip frames or overlapping(multiple)exposure is caused by the film advancing mechanism. if you treasure your camera y back. send it for service.
pc-cook
Oct 10, 2007 | Bronica ETR-Si Medium Format Camera
Bronica ETR-Si Medium Format Camera Logo
199 people viewed this question
Top Bronica Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Bronica Photography Expert? Answer questions, earn points and help others
