Question about Elandpower Uci Usb Cable Connects For Mercedes Benz Media Interface Select Usb Sticks Or Media Players With A Usb Port
A 2010 media port, i want a single cable to connect both usb and audio out aux. is it possible
I have a dab radio which is powered by usb and has aux out audio. need single cable
Can this be connected to the aux port of a car radio? how via USB or ear bud jsck?
Usually If the car has an existing audio jack port you should be able to use an audio cord that has a male audio jack on both ends and it should work. Just make sure your on the right output selection on the car stereo. (Such as aux, cd, tuner,)
Apr 01, 2015 | Mach Speed Trio Clip MP3 Player
I have a 64 reg renault master fitted with a dab radio which has usb and however I do not have any operating instructions, can you help?
Although I cannot comment on the exact specific operating instructions for this van, the ALMOST universal instructions are as follows - Plug in your USB device and make sure it's powered on. Put the radio into auxiliary mode (aux) and the radio should automatically find all audio files on your device that the radio is capable of playing, and you should be able to navigate through those audio files by the controls on the radio.
Feb 04, 2015 | Renault Cars & Trucks
Where is the AUX connection on the radio
There is no port. There should be a ten wire bundle (5 pair) coming out of the back (next to the power port). One pair of wires should be labeled aux in.
Jan 31, 2015 | Panasonic CQ-DF602U CD Player
My HTC aria phone wont play music off my radio, when connected it says error 19?
HTC and other Android phones doesn't have the USB support for your HU. Only way to get signal from the phone to the HU is to use AUX 3mm cable from the phone to the aux port on the deck, assuming there is one. Other wise you will continue to get errors. USB is for Iphone and Ipod only!!!
Mar 17, 2011 | Pioneer DEH-P4200UB Car CD / USB/ MP3...
Can I use the Aux port to play USB in Ford audio/CD MP3 player
hi, you may use the aux port by using the right type of usb, hope this helps
Feb 12, 2010 | Car Audio & Video
Connecting ipod to AUX in car stereo
you need an AUX cable from radio shake. Does your deck have a port in front or in back?
Aug 10, 2009 | 2005 Honda Pilot
Audio problems
To use the integrated speakers on this monitor you will need the audio cable. Most monitors with built in speakers has a single cable with a green jack on both ends. It would plug into the audio jack on the back of your monitor and connect the monitor to your soundcard jack on the back of your pc. Cable should be able to be purchased at any electronics/computer store. Hope this helps.
Jul 08, 2009 | AOpen F75PS 17" Flat Panel LCD Monitor
No idea how to connect an iPod!
You need to buy an extra cable that connects to the back of the radio, it is ipod ready but you need buy the cable. The front USB port is just for mp3 or mp4 players that you can connect via a USB port.
Jun 11, 2009 | iLO XM-MP3-CD Car Stereo
Which audio cable?
Yes yuo can, you need a double ended earphone jack. most computer stores have them, walmart might have on ein the electronics department. Plug one end into the laptops earphone port and the other into the AUX jack on the radio. your good to go, turn on your music and turn up the volume on the laptop and then adjust it on the radio.
Let me know if you have any other questions
Dec 03, 2008 | IBM ThinkPad T21 2647 Notebook
Elandpower Uci Usb Cable Connects For Mercedes Benz Media Interface Select Usb Sticks Or Media Players With A Usb Port Logo
23 people viewed this question
Top Elandpower Car Audio & Video Experts
xxxxxx xxx
Are you an Elandpower Car Audio and Video Expert? Answer questions, earn points and help others
