Question about Samsung SC-D372 Camcorder
Power cord HELP
I have lost my cord that plugs into the wall to the camcorder, I have spent hours looking for it on the net for a new one, but no luck. Can you help me
Re: power cord HELP
Power cord is almost impossible to find! However, you can purchase a charger for the lithium battery itself!! Good luck
Posted on Mar 29, 2009
0 characters
3 Points
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Mar 24, 2015 | Video Cameras
I'm trying to find a charging cable for my JVC camcorder model # GZ-E300WU.
Check the specs in the manual to determine the voltage/polarity (may also be next to the plug input on the camera) is the same and you may be able to use a generic adapter like those you'll find on Amazon for JVC GZ camcorders like this:
2A AC Wall Power Charger Adapter Cord for JVC Everio GZ E306 AU GZ E306 BU
Dec 29, 2014 | JVC Video Cameras
ZR100 will not trun on
How long have let the camcorder sit still before using again? It seems that you were using it then the battery was out of charge, then you tried to charge it, but nothing happend. Is that your problem?
Jul 25, 2010 | Canon ZR100 Mini DV Digital Camcorder
My Canon FS200 DVC isn't transferring files
Hi mate, I had same problem as you, took the cam into store and teh guy helped me out.
Make sure you get the recharger for the camcorder, then plug it into teh camcorder and also to the wall power when you are uploading the files. It can needs an extra power boost to get the files onto your computer.
- so plug in your camcorder to computer
- also plug in the battery recharger cord to the camcorder
Should work fine!!
Jul 13, 2009 | Canon FS100 Flash Media Camcorder
Hi !! Please help !!! I lost my little black cord that hooks to my panasonic camcorder !! It plugs into the back, where the battery goes & plugs in to the charging base.... I can't get video off my...
Hi. That little black cable is a DV cable. It's also called FireWire. You have to get that at your local electronics store, or you can get one off the web.
Mar 05, 2009 | Panasonic Video Cameras
I am trying to load my video recording to my PC
I experienced the same thing. The compact power adapter is simply the power cord used also to recharge the camcorder. Plug it into the wall at the same time as you have the USB plugged into the computer and it should be able to download.
Jan 27, 2009 | Canon FS100 Flash Media Camcorder
Sharp view cam
This style camcorder has an adapter that feeds off of the battery charger...the charger plugs into the wall on top of the charger you place the battery and if you look on the front of the charger you will/should have an outlet that looks like two holes. This charger should have come with an adapter that looks like the battery only it is attached to a cord. You should than be able to open the battery compartment and insert the corded (battery) and presto it works...if you do not have one you can contact
May 29, 2008 | Video Cameras
Lost power cord
See the links below for the part you are looking for.
A/C Adapter (plugs into camera)
Battery Charger (charges battery without camera)
Mar 05, 2008 | JVC GR-D250 Mini DV Digital Camcorder
How do i recharge the batteries?
the camcorder should come with a cord to plug into a power point, it will charge once plugged in. Normally they take 3 hours to charge with a main power supply.
Dec 23, 2007 | Sony Handycam CCD-TRV37 Camcorder
Samsung SC-D372 Camcorder Logo
Top Samsung Video Cameras Experts
Pieter Vleeshouwers
Chris Hunt
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
