Question about Brother International Brother MFC-J435W Inkjet All-in-One
Wireless connection cant get my printer to work with my wireless laptop
  • Norwich Repairs
    Norwich Repairs Mar 21, 2014
    Hi Suzanne Thomann, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Such as, at what stage you have a problem connecting.
My printers keeps losing its connection to my laptop and Ipad and I have to keep reinstalling every time I want to use them together.
It may be losing its IP address. Check the DHCP address affectation of your router. And leave your printer constantly connected to the router. You should also let your printer get the IP address automatically upon booting.
Nov 07, 2013 | Canon PIXMA MX712 Wireless Inkjet Office...
Dell Latitude E6410 does not connect to wireless printer
connect it by cable to your pc first to install it then remove the cable
Feb 11, 2012 | Dell Latitude E6410 Laptop
Can we use MF6550 for wireless network?
If you use a wireless USB print server like this . Keep in mind that you may not get all functions such as scanning to work but it will allow for printing for sure. If the scanning works consider it a bonus.
Jun 11, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
Connecting wireless laptop to wireless printer epsontx600fx using
go to your setup button on the printer (not the computer) and select wireless connection. The SSID should appear automatically. Choose the enter WEP option and enter the WEP for your particular modem. That's it
Jan 16, 2010 | Epson LX-300 Matrix Printer
Laptops not connecting to the internet when the hp c4599 is on
Perhaps the printer is conflicting with the laptop by taking its "address" on the network...Do you know how to give your printer a diifferent IP address? Or your laptop? Its a bit complicated to explain but if you can make sure the laptops and the printer are all set to use "DHCP" then they should all each get an adress on your home network and work together.
In Windows Vista, click Start, Control Panel, Network & Internet, View Network Status and Tasks. Then view the status of your Wireless Network Connection and click details, if it says "DHCP Enabled" in there then your laptops are not the problem and should be sharing addresses.
You should be able to see in the printers control panel or by printing a self test page how its setup on the network, maybe it needs to be reconfigured while the laptops are turned on as well.
May 17, 2009 | Office Equipment & Supplies
Cant connect printer to wireless laptop.
have you setup the wireless connection in between the printer and the laptop...
your laptop is working wirelessly with the internet but for making the printer to use it wirelessly the printer should be also a wireless printer.
and if the printer is a wireless printer then you have to setup the connection in between the printer & laptop to work wirelessly.
Apr 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
Lexmark N2050 wireless adapter for X3500-4500 series printer
i cant tell you too much because i dnt know too much about your situation but try completely resseting everything and try sending something again
if its allwireless c if you can pick up the wireless points if you cant there's your problem
Dec 29, 2008 | Lexmark N2050 for X3350 (14T0300) Wireless...
Cant connect to wireless router
Make sure the wireless adapter is enabled on the elonex laptop and its properly installed.
Connect wirelessly on the elonex one laptop using the same SSID and security key that you used on your main laptop.
Aug 07, 2008 | Belkin (F5D7230-4) Router (587009)
Problem in wireless connection.
ok First Didnt say what operating systems you were running 2Have you updated from windows SP2 let me Know ttech
Aug 01, 2007 | HP Photosmart C6100 All-In-One Printer
Brother International Brother MFC-J435W Inkjet All-in-One Logo
15 people viewed this question
Top Brother International Office Equipment & Supplies Experts
Gil Shultz
Ron Baird
 Andrew Henderson
Andrew Henderson
Are you a Brother International Office Equipment and Supply Expert? Answer questions, earn points and help others
