To clean the filters
How to maintain
    New Friend:
  • 4 Answers
Regular maintenance of Aircon is important. It keeps your aircon in a good condition for a long time. You can refer professionals for general air conditioning service. They can give you the best maintenance services.
Some of the common processes include in normal aircon services are:
  • Checking, deodorizing and purifying filter
  • Cleaning & checking indoor drainage tray
  • Vacuuming of the drainage system.
  • Cleaning and checking the air filter.
  • Checking fan bearing and lubrication (if necessary)
  • Checking compressor suction and discharge pressure
  • Cleaning and checking indoor evaporator coil
Posted on Jul 12, 2017
    Habit-Forming:
    New Friend:
  • 29 Answers
Instructions on how to clean the filters are in any air conditioners user guide, a scheduled maintenance section. Just choose the necessary one according to your air conditioner make and model, download it and find the needed information Air conditioner hvac user manuals
Posted on Mar 21, 2014
How do I clean filter for whirlpool disher model number du890dwgq1
It will be in the bottom of the dishwasher Usually unscrews.
Oct 02, 2014 | Whirlpool Dishwashers
My portable water filter is not pumping well anymore. Is it broken?
Most likely you filter is clogged. When you filter water, you are trapping live organisms which remain there until you clean the filter. I recommend checking the manufacturer's instructions on cleaning and maintaining the product.
Aug 26, 2012 | Brita Camping, Backpacking & Hiking
D e pool filter
It depends on the manufacturer, but generally, you backwash and recharge as necessary during normal use. I recommend to tear the filter down twice a year and thoroughly clean and inspect the grids. Replace the damaged grids as necessary. After it has been charged with DE and is running, record the filter pressure and backwash it when the the pressure is 10 psi above the clean pressure. Hope this helps. -DC
Feb 14, 2012 | Pool & Spa
Where can I get a replacement filter for bap4010?
According to their website:
PERMAtech Permanent HEPA Type filter traps 99 % of all allergens and dust down to 1.0 micron.
PERMAtech Permanent Filter Never Needs Replacement!
Simply vacuum the filter every three months to maintain performance.
Requires less cleaning and maintenance than other permanent filter systems.
Built-in Ionizer assists in cleaning the air from dust and allergens.
Oct 10, 2011 | Bionaire PERMAtech BAP4010-U Air Purifier
How do i get to the filer on top of the motor
Hi there, The filter above the motor does not need to be maintained - attempting to wash or clean it will cause damage. However, the pre-motor filter needs to be washed at least once every 3-6 months. Use cold water, and allow up to 24 hours for the filter to dry completely before replacing it. If you have any further questions about using or maintaining your Dyson cleaner, please get in touch with us directly - you can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to provide further assistance. Kind regards, Jack Dyson Online Customer Support
Sep 15, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dryer does maintain heat
I need a little help here. Your post.... "Dryer does maintain heat"
With the comment: "igniter glows and flame goes on after rest"
So far everything your desribed is most likely normal operation.
Are you saying that the "Dryer does NOT maintain heat properly?" AND that the flame cycles on and off way too often?
I will send this as a solution however.... if you need more help just reply to this post.
-- If you disconnect the dryer vent ducting and it works normally the ducting is clogged up.
--If it still operates the same with the vent disconnected then the dryer air passages are clogged up with lint. Use a crevice tool and something like a folded over metal coat hanger to clean up the air passages
--This can include the lint filter itself if you use dryer sheets. The filter will appear clean but will not allow airflow due to the dryer fabric sheet particulate build up on the filter. Wash it with vinegar and water then soap and water. Make sure to clean the air passages around the lint filter.
--If after all of the above the dryer is still doing the same thing check the airflow out of the back of the dryer. It should gently push a relaxed hand and wrist away from the vent outlet hole. If it does not and your sure all of the air passages are clean then there is a good possibility that the blower wheel has failed and is spinning on the motor shaft vs being driven at full speed.
Also if you respond and need more help please include all of your model number or confirm that MDE7400AY is the correct model number.
Thanks for choosing FixYa.
Kelly
Jul 15, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Filter cleaning
use an air gun from a air compressor, that is what i use with mine-Lance
Oct 20, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Oil filter maintainance
advisable to change the filter when you change the oil milage depends on the driving conditions but is better done at least every 12 months or 2/3 k miles
Oct 17, 2009 | 2005 Yamaha Ybr 125
Poor suction
This page has useful tips for unclogging a central vac. https://www.centralvacuumstores.com/cvs/trouble_help.php
Feb 01, 2009 | M&S Systems FX-3000 Bagged Central System...
Bosch WFL 2860 Stops Part Way through Its Cycle
When a machine stops during its rinse period, it is normally a block in your outlet filter. And you say it has not been maintained in any way for 5 years; at least you shd be doing the minimum maintainance like clearing your outlet filter.
Front bottom right, is where access to the filter normally is; get to it and clean out, plug off the wall first. The large plastic is to be turned anti-clockwise to remove, refit carefully after cleaning.
Nov 25, 2007 | Washing Machines
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
