Question about Video Game Consoles & Games
My Sega touring championship twin car arcade has no power going to it
There is no power going into the machines just blank screens have checked fuse in plug
  • 2692 Answers
SOURCE: Activision sega twin pack 2 will not install to my computer.
No fix. Not Written for Xp.
Wikipedia
In 2002, Sega Smash Pack: Twin Pack was released on PC, and it contained both of the above collections. However there are incompatibility issues as a result of playing the game on Windows XP. When a user plays Sega Smash Pack 1 under XP, Games suddenly quit without error after a certain amount of time.
Posted on Dec 27, 2008
DarkWolfBomb
  • 80 Answers
SOURCE: how do i set up my sega genesis
There should be regular av cables and wall adapter for it. Mine came with the wrong cords and that might of happened to you. So if you don't know the av cables go in the back of the tv and plug's in the back of the sega. and the wall adapter goes in the wall. If you don't have the cords than get them off line. Type in:
http://www.amazon.com/s/?ie=UTF8&keywords=sega+genesis+cords&tag=googhydr-20&index=aps&hvadid=2858659671&ref=pd_sl_8zrz6m8bxu_b
cut and paste it online and you can get them.
Posted on Jul 18, 2009
gamefixer
  • 6 Answers
SOURCE: My MsPacman/Galaga upright has power but screen is black(blank)
I'm assuming this game cabinet was built in the 80's. More than likely, the monitor is an Electrohome GO-7. If this is the case, replace capacitor C511 on the monitor board. It has baked open due to old age. Usually, capacitor kits can be purchased for around 10 bucks, so you might want to replace all the caps on the board at ths time. Worst case scenario would be that the Flyback transformer has smoked (usually you'll see a crack on the side of the transformer), causing the horizontal output transistor to cook and also the smaller of the two pigtail fuses to blow. In this case, you would have to replace the Flyback transformer, the horizontal output transistor, and the small pigtail fuse associated with it. Remember to always discharge the second anode( the suction cup thingy on the side of the tube). It will hold a substantial charge on it. Also, if the small pigtail fuse is blown, you will need to discharge the large cap on the monitor board, or else it will knock you on your rear-end when you try to replace the blown fuse. Hopefully, you'll will only have to replace one cap. C511. If your game does not have an electrohome monitor, I can still help, if you provide the manufacturers info, such as Well Gardner model 7204, or something like that. Good luck!
Posted on Aug 16, 2009
  • 5 Answers
SOURCE: I recently plugged in my Sega Genesis (MK-1601)
This is pretty common. The games just need a good Q-Tip cleaning, and then the weird clean pencil-eraser rubbing.
Get out a Q-Tip, and rub it inside the game, on the copper part (The part you stick down into the system.). Keep doing this with new Q-Tips if the old ones get soiled with black stuff. After the new Q-Tip comes out white, it should work.
Sometimes, that isn't enough. Use some Windex or any other rubbing alcohol, dip it onto a Q-Tip, and rub it onto the copper part. Then, use a dry Q-Tip to dry it off, and let it sit out of it's case and out of the system for about 20 minutes so that the alcohol dries.
If that doesn't work, use a pencil with a clean pink eraser at the tip. Rub it inside the game, and use a Q-Tip to get all of the eraser shavings out. This breaks the electro-static cling/friction made when the game is being read by the system.
And if none of that works, go on Amazon or Ebay or to the store Slackers and get new video and AC wires for the Genesis. Sometimes that's all it needs!
I really hope this helps!
Posted on Aug 10, 2010
guru_fixya
  • 944 Answers
SOURCE: I own the arcade version Sega Naomi 2 Initial D
The problem is with the board firmware not the network.It seems the board firmware is corrupted and you can't reinstall the firmware.You need a RC cable to reinstall the corrupted firmware.Call the
Sega technician and ask him to reinstall it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Feb 09, 2011
I own the arcade version Sega Naomi 2 Initial D Racers Model # STW-TOF-GPI. When it starts up it goes thru all the system checks and appears to download the game properly but it gets stuck at Checking...
you need to get into the Service mode and turn off the network connection, if you are not connecting 2 arcades you dont need it. Also I dont think the Sega Network is still up to save the data like it used to.
Feb 10, 2015 | Sega Video Game Consoles & Games
Car radio screen blank
1: no power, to radio, totally dead in all modes, no dial screen , alive?
is blown fuse. check the fused, read the operators guide in the glove box. its there.
if you lost the radio code (powers up and tells you that)
then that is a horse of diffr. color.
Nov 30, 2013 | 2011 Honda Pilot Touring
I have an old sega genesis and got new plugs to plug it into my 42'' HDMI Vizio. all the plugs are in and the light is on but the screen stays blank. I have tried blowing on the game and got the...
Did you say HDMI? I don't think there are HDMI plugs for Sega Genesis. You can plug in your Sega via composite video through RCA cables (yellow, red white) or via RF signal through coaxial cable. Check your TV's specs to make sure it can display standard definition content via composite or via RF.
You can double check to make sure your Sega Genesis is working properly by plugging it into an old-fashioned CRT (fat tube) television set.
Sep 02, 2011 | Sega Genesis Console
Dear Sirs, I require an original manual / technical documentation or copy for the SEGA Astro City arcade cabinet.
You can find a PDF file of the manual at arcadecontrols.com, I don't know much about arcade cabinets, but the documentation seemed pretty comprehensive. Good luck!
http://files.arcadecontrols.com/details.php?image_id=3564
May 09, 2011 | Sega Video Game Consoles & Games
I have a 2005 golden tee tournament edition, when i turn it on it powers up but the screen is blank, any suggestions???
First you will need to open your game arcade machine and check the Game Motherboard cables and connections, check all plugs, every connector, reconnect all of them..and try to turn it on again!
After doing this try to check your power supply and see if it is working well..
see if the board look´s like this:
Note that some versions has ide hdd interface.
to help you, i find the service manual with all the instructions in this link
There is a step by step guide to fix your Golden tee!
Good Luck!
Dec 07, 2010 | Arcade Golden Tee Unplugged Video Cabinet
How can i load toca touring car championship on xp?
hey there welcome to fixya
you should be able to play it put the cd in and install it let me know if it doesnt work
please remeber to rate this solution
regards
magical ink
Jun 19, 2010 | Codemasters Toca Touring Car Championship...
I get a blank black screen when i turn on my sega
Take the game out and put it back in SEVERAL times.. try blowing the cartrage or the reader...there may be dust..also make sure there is nothing on top of the sega or touching the cartrage...make sure the sega isnt moving and is on the floor or on a shelf
Jan 05, 2010 | Sega Genesis 2 Console
Wikipedia
Dec 27, 2008 | Computers & Internet
Video Game Consoles & Games Logo
254 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
