I have six ps2 and six toshiba 24" regza T V . Can i connect a lan connection ?
I want to setup a lAN connection
Junoon007
  • 1011 Answers
SOURCE: low lan connectivity or limited lan connectivity
Hello Sir,
all computers on the same physical subnet need to have ip addresses in common
meaning the first three numbers in aaa.bbb.ccc.ddd are the same and are different only in the ddd portion.
In addition, the subnet mask must be alike or ensure that some ip addresses are not excluded
Typical subnet mask is 255.255.255.0 or sometime 255.255.254.0
Usually, there's a gatway address; a target which is used to send packets out
of this machine and hopefully towards the other machine.
For all machines, use the Run->cmd and enteripconfig /allYou should have similar results on all machines, so look for major differences eg: gateway on one is 0.0.0.0 or not shown while other have non-zeros,
or ip address on one start 169.254 another starts with 192.168
The 169.254.y.z addresses are pecuilar
ms article comments on auto-config:
example : IP-address assigned via Auto-IP-Configuration :
Windows IP Configuration
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Autoconfiguration IP Address.. . . : 169.254.4.69
Subnet Mask . . . . . . . . . . . . . .: 255.255.0.0
Default Gateway . . . . . . . . . . . . :
Thanks
Cheers!!!!!!
Good luck
Posted on Feb 29, 2008
SOURCE: which lead do i need
i just did this last night (compaq to 52" regza). you need a SVGA monitor cable male/male..(14.95 at ***-mart). plug her in and your good to go...
Posted on Dec 25, 2008
Bat1956
  • 585 Answers
SOURCE: setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Dec 28, 2008
  • 45 Answers
SOURCE: My Toshiba Satellite PSL30A-00100E wont pick up wireless LAN
there is a switch on the front of the laptop on (just under the mouse) on its "face", it just says on off
Posted on Dec 29, 2008
  • 36 Answers
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
Notebook won't connect wifi
Hi, assuming your laptop is switched on.
Above the keyboard on the right side are the three 'Easy buttons'. The one on the left is for the wireless function.
Push this button to activate or deactivate the Wireless LAN. When you activate the wireless LAN function, it will search for a wireless LAN signal automatically (assuming you have the wireless LAN driver installed). Just below the screen on the right side is the Status LED Panel, which show six icons, each with its own LED. The first one on the left indicates Wireless LAN status. When the LED is displaying a green light, it indicates that the system is accessing data from, or retrieving data by wireless LAN. So whenever you press the Easy button, you should see the green status light come on or go off. To repeat, if the light is not on, you need to press the Wireless LAN 'Easy Button'. NOTE! If you can't get the button to come on, you will need to re-install the Wireless LAN driver.
Jan 16, 2014 | Averatec 5110H Notebook
I am trying to connect my toshiba a15-5129 in my house it will not connect to broadband
Hi, we have two ways to connect to broadband, via wired or wireless, at the device manager please do check if the LAN drivers are enabled, if enabled, via wired connection, simply put the RJ45 jack from LAN port of your router to LAN port of your notebook, if configuration is already set in your Router LAN, it will just automatically connect. If connecting via wireless press wifi button to activate wifi connection then windows will pop for your access credentials. simply put the password for your connection once the name of the site displayed.
Jun 20, 2011 | Toshiba Satellite A15-S129 Notebook
Lan connection not working on Toshiba satellite laptop
Try setting up a new Broadband internet connection. Input all the appropriate Login info and you ought to be good to go via the LAN port. Everything else is aimed towards Wireless.
Sep 19, 2009 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Toshiba NB 205 connects to router but not internet
The wireless configuration is set differently on routers, eg the SSID, and encryption. You need to configure the wireless LAN card in the laptop to connect/communicate with the different routers.
Some wireless LAN card allow you to setup different profiles/settings for different wireless routers. Eg one setting for the office and one for home, which allows easy connection to the Internet by selecting the appropriate profile/setting.
Aug 17, 2009 | Toshiba Computers & Internet
Not getting connected to the Broadband internet
Right click on the wireless LAN and then click Repair. Do this in the Control Panel - Network Connections. This will force the wireless LAN card to get a new TCP/IP address from your wireless router.
When you get this Limited connectivity message do a repair - this is a common problem - the wireless connection icon is also on your Task Bar, you can right click in it to do a repair.
Mar 24, 2009 | Toshiba Satellite L355D-S7809 Notebook
How do i get connection 24 on my wii?
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.....
Mar 09, 2009 | Nintendo Wii Console
LAN cannot work
You need to connect a LAN cable to it which is connect to another computer, network, router, and or hub. Then you need to setup the LAN network itself. Here are a few links that might help.
http://performit.co.uk/network/
http://www.firingsquad.com/guides/lan/default.asp
http://www.tweak3d.net/articles/network/
Jan 27, 2009 | Abit NF8-V2 Motherboard
Lan card toshiba wireless no working
Check this Tip for an overview
  1. Connect your PC to your router using LAN Cable: be sure you can browse internet
  2. If you cannot browse check router config with your ISP
  3. Connect to your router using IP address you find for gateway in Network status
  4. Configure your router wireless section to match with your PC card
  5. Start removing security, broadcast radio signal, create a simple SSID as network name
  6. Check if router network is seen by your PC card (when you disconnect the LAN cable and activate the wireless card)
  7. If connection is established ( near the router) try different location
  8. Reconnect cable and reconfig adding security protocol (WPA-PSK recommended) use parameters compatible with your lan card
Jan 15, 2009 | Toshiba Satellite 5105-S501 Notebook
Lan internet
the easiest way to setup internet on the laptop, is to go to control panel, and launch the network setup wizard. this will enable you to setup a new network, and scan for a local area network connection. this will also give you access to the troubleshooter. to solve any connection problems or issues, should there be any. If your using a wireless method. Your PC must also be able to transmit/receive wireless Signals. If hardwired you,ll have to use the network setup wizard, as this will auto determine I.P And any other DNS settings et,c.
Hope this Helps Mike @ compurepair.
Jan 14, 2009 | Toshiba Satellite Pro L300 Notebook
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
