Question about Flotec 3-Wire Submersible Pump - Fp3332-09 1Hp 3W Dp Well Pump
Pentax water pump
PUMP not start in plc, its start manually
    Genius:
  • 1,114 Answers
If the pump runs manually as you state, then the problem probably has to do with the control for the pump. It could be a bad capacitor in the control , but I'm not sure there are replacement parts for these control units. Possibly you need a new control unit.
Posted on Apr 07, 2014
Where can i get a manual forthe pentax water pump cam 50
Although it has a manufacturer's name of Pentax, I don't think this is a camera. Industrial Machinery may be a better option.
May 06, 2017 | Pentax Cameras
Pentax smart head
Check the pressure switch. Be sure you have enough water available. Check for a leak. What are you pumping. Is it pumping. I am not familiar with this pump so I am just listing some points to check. If it is a submersible well pump it can develop a lot of pressure.
Nov 29, 2013 | Plumbing
What causes a pentax smart head to cut off and on during use of water
There's not enough water running into the pump this is why its cutting out , hope this helps
Oct 09, 2013 | Plumbing
Pentax water pump
A few more details would help such as model number, is it plugged in etc.
Aug 03, 2013 | Plumbing
Adjusting my Pentax hydromatic H1 water pump
we need wiring diagram for achromatic 1. the power supply is 240 v 50 hz
Nov 26, 2012 | Cars & Trucks
Pentax water pump 1/2 hp when pump starts works well but pump does not cut out when all taps in the house are closed
it sounds like the switch is faulty take it back to the shop and tell them ok
Mar 28, 2011 | Vacuums
Pentax smart head loosing presure system has no leaks continuosly switcing on and off ,also not switcing on when washing maching starts its rins cycle ,have to press reset button to start pump again.
hi i have a pentax water pump the smart head, it works very good .one day the pump did not come on when i turn the pipe on so i take off the switch i put it back on the pump came on water was flowing as normal when time to turn the pipe off the pump will not cut off so i switch it back off and call an electrician he check it and he said i need to change the circuit board in the pump so he did now the started to work only on the lower pipe but it takeing long to come on and cut off.the upper pipe when turn on the pump not coming on i open all the union to bleed make sure on air in the line but still having the same problem can this be the head it self need changing?
Jan 16, 2011 | Plumbing
I got an used Pentax CAM 100 water pump but need some help: Does anyone has manual where I can read the specs and installation guide? Seems it works with split-phase 220V 60Hz. It is possible to run...
Look on the pump itself for wiring instructions. Usually if a pump can be wired to multiple voltages there is a diagram either on the side of the pump or under the wiring cover. I tried to locate a manual online with no success. If it can be wired 110 volts, you will get the same performance but your amperage will be double the 220 volt amperage.
Dec 07, 2010 | Plumbing
Flotec 3-Wire Submersible Pump - Fp3332-09 1Hp 3W Dp Well Pump Logo
255 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
