Question about Dometic Rooftop RV Air Conditioner
I have a dur-therm unit my rv the unit is hard to start all ways say low voltage i supect starting J Lane
  • 4 Answers
I will try a Kick Start that will help with your low voltage problem.
Posted on Jun 20, 2009
Duo therm mod. 57915 air conditioner seems to work good , runs for 4-5 minutes then kicks breaker , was kicking 30 amp breaker at camp ground , i've been working on connections to make sure its...
Unit may pull as much as 17-18amps when compressor starts up, but level out to 12-15 amps when up and running. Keeping in mind that is all relative to proper 120v incoming voltage, heavy enough wire to run the application etc. If your AC unit needs cleaning , it may draw an extra amp or 2 . With that said, when your at the park, first thing I'd question is their incoming voltage to RV, and try running fridge etc and anything else on propane if possible. The AC alone should not cause 30amp at source breaker to trip, before 15 0r 20 amp breaker in RV that is connected to AC trips. If it doesn't trip your breaker at home, and all is connected same at park, then I certainly would suspect bad breaker or voltage/wiring at park is the cause. P.S. I noticed you said you have 12 gauge wire (rated at 20 amps) connected to a 20amp breaker at panel, but RV is plugged in to a 15amp receptacle, I will assume with a 15 amp adapter from 30 amp plug. Do you see any hazard regarding 15 amp rating on receptacle? ( just a little advice.)
Aug 15, 2011 | Dometic Rooftop RV Air Conditioner
AC compressor won't start
hi,you might need a new compressor...you will need need to go back were you bought capacitor...buy a hard start capacitor too..this might crank the compressor...hope this helps.if you buy it..call an ill tell you how to wire it...if it dont ,you need new compressor...call michael..doctor airr..appl.repair...843-384-8474...
Mar 27, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm Penguin model 610115.311 AC unit no-power
Actually you should have fried you converter. What is the voltage reading you get for the air conitioner? supply? One should run off the generator and the other on shore powerIs it set up that way?.
Sep 28, 2009 | Heating & Cooling
Hard start compressor
Could be the capacitor..
If not - I do believe a hard start kit may be added..
Sep 09, 2009 | Danby DFF8803W 8.8 Cu Ft Frost Free...
My Duo therm fan come on but when try with cool it's shut off the fuse and if turn the fuse back on would come on for a little while and then off again what shuld I do?
First thing to check is incoming voltage. If problem with incoming hydro, either from improper cord attached, or whatever that would cause low voltage to unit, that could be the cause, so if you have a meter, try to check that voltage to your RV is up to spec. Let me know
Jul 19, 2009 | Dometic Rooftop RV Air Conditioner
My dur therm air conditioner fan turns on but compresor does not
it could be the (LP) low pressure switch which would shut the unit down
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Unit turns on but condensor dont kick in
Need to pull the cover off and see if the compressor is comming on.If not have someone with electical experience check the contacter.Sometimes bugs will get under the contacts durring wenter.If it is running the freon is low
Jun 27, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
105 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
