Question about Sony Cell Phones
The phone is not getting started
When the phone starts i will be like sony appears and it dissapears and repeat again
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 55 Answers
Unplug battery
Posted on May 04, 2014
Screen dissapears after activating call
possibly solution
1.hard reset your device
2.otherwise it maybe hardware issue (touch screen problem)
for : hard reset on the start screen tap -> button then tap setting then about phone, then tap reset your phone and tap yes.
touch screen issue : you need to take to some technician to disassembly to touch screen and reassembly again if with this not solved you will need to change the touch screen. i think this will help you.
Jun 20, 2012 | Nokia Lumia 710
My phone sony ericsson W705 always search for network and hang, then restart after sometime.This process repeating and I can't do anything.This is happening since the day before yesterday.Please help.
Try to start your phone without sim card then if it get started the switch off it & reinsert sim start it it get started if Not then Visit your nearest Sony Ericsson Service center or Visit any local Mobile Service center they will provide you the solustion.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 19, 2011 | Sony Ericsson Walkman W705 Cell Phone
Region free Samsung Blue Ray player BDC5500
this is already a regional (plays all 6) free (at least this model is suppose to) player.
you can also update your players firmware from the link below.
  • http://www.samsung.com/us/function/search/espsearchResult.do?keywords=Samsung+BDC5500+Player&input_keyword=Samsung+BDC5500+Player
Jul 26, 2010 | Samsung BDC5500 Player
How do I change the Baud rate on a canon f80 fax
To set the receive speed
Change RX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (RX or send) speed if this message appears frequently on the LCD.
  1. On the operator panel, press <Menu>.
  2. Press the left '<' or right '>' arrow repeatedly until [USER DATA] appears.
  3. Press [Set].
  4. Press the right arrow repeatedly until [FAX SETTINGS] appears.
  5. Press [Set].
  6. Press the right arrow repeatedly until [RX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [RX START SPEED] appears.
  9. Press [Set].
    1. The factory default RX (send) Speed is 33600 bps.
    2. You can select from the following RX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable RX Speed.
  11. Press <Set>.
  12. Press <Stop> to return to standby mode.
To Set the Send Speed
Change TX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (TX or send) speed if this message appears frequently on the LCD.
  3. Press [Set].
  5. Press [Set].
  6. Press the right arrow repeatedly until [TX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [TX START SPEED] appears.
  9. Press [Set].
    1. The factory default TX (send) Speed is 33600 bps.
    2. You can select from the following TX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable TX Speed.
You can download a copy of the user manual for the F80 at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=7175
Please make sure to rate this solution. Thanks.
  1. Press <Set>.
Apr 29, 2010 | Canon MultiPASS F80 All-In-One InkJet...
The home key and the start key are sticking and when playing games the menu of the game appears and dissapears every second
blow it out with compressed air.
make sure your hands are clean before you play with it and you don't use it around food.
Aug 31, 2009 | Sony PlayStation Portable (PSP) Slim...
Messages dissapear ona sony ericsson W810 i
Check if any setting is enabled, which would display only unread messages.
Aug 04, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Handmade guitar amp, when i plugin the guitar i start playing, but then signal gets lost, the sound dissapears, and then it appears again, and after minute or two it dissapears. i've tried to put full...
have you got valves fitted to the amp as they can cause fading if old >damaged >not fittted properly also check the speaker connects and try playing half volume the output should be steady.. you say its handmade if you made it pull out the amp board and check your soldering joints look to see fi there is any that need resoldering as they may be getting hot and causing a resistor to fade..
Aug 02, 2009 | Orange Crush 30R Reverb Guitar Amplifier
My nokia E63 can't boot?
1.remove the battery..
2.leave it for 1 minute..
3.place the battery again..
start your phone..
if its not starting or a long blank screen appears repeat step 1,2 & 3
before starting your phone press button 3+*+power button simulatenously..
this will boot/hard reset your phone back to its original factory setting.
Make sure you back up all data before trying these steps!
Jun 16, 2009 | Nokia E63 Cell Phone
Software problem
contact your dealer or a local phone shop where the phone can be fully reset.
Mar 18, 2008 | Sony Ericsson K310i Cellular Phone
Cell Phones Logo
15 people viewed this question
Top Sony Cell Phones Experts
Gil Shultz
Andrew Taylor
Andrew Taylor
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
