Question about Magnavox 32MF338B 32 in. LCD HDTV
Unit will not turn on without be unplugged for several minutes. Even the red indicator light goes off as if it has no power.
Once unplugged for several minutes, it will turn back on. This happens daily for the last week or so.
    Top Expert:
  • Magnavox Master
  • 74,232 Answers
Sounds like main power regulator board [SMPS] fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Mar 21, 2014
Sharp Aquos LC45GX6U & TU-GD10U. The unit doesn't power up, and has a red blinking light from the moment you plug it in. The unit works fine in service mode.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 27, 2015 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
What is the red light next to the green power light? It appears to look like a temperature light. My unit won't run.
In most cases it means the shredder is full or something is jammed. Empty the shredding container. If the machine has a "reverse" position on its switch, try running it backwards to get whatever is jamming the teeth to come back out.
Nov 03, 2014 | Ativa MD1250 12-Sheet Cross-Cut Shredder -...
Tascam DP-01FX/CD wont turn on
Refer to your manual (1st) It appears that "maybe" your unit may be
locked - until you get through the menus - and type/press EXIT.
If you don't have a red indicator light - lit. Turn off power switch (rear)
and unplug unit for 1 minute. Plug in - then turn on switch (rear)....if
still no red indicator light....you'll need either Tascam or Samsung
tech to service your unit. Good Luck.
Feb 28, 2014 | Tascam Digital Portastudio Dp-01fx/cd
DVD Player will not power on. Indicator light flashes repeatedly.
Since the players of this kind are not repaired because of the low cost of new, just replace it.
Jul 06, 2017 | Televison & Video
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
My toshiba satellite L300 has no power
Please follow these steps VERY CAREFULLY:
1) Unplug the notebook from the ac adapter (charger power cord)
2) Take off the battery pack on the notebook
3) Once the ac adapter and battery is off the notebook, hold down the power button for 15 seconds
4) After 15 seconds, let go of the power button
5) Now plug in the AC ADAPTER (OR CHARGER POWER CORD) ONLY (DO NOT PUT BACK THE BATTERY PACK)
6) Now press the power button once.
7) If the unit boots, the unit suffered a slight surge
8) If the unit does not boot and remains dead, the unit suffered a severe surge and may be burned out and needs replacing
I hope this helps and let me know how it goes afterwards
May 03, 2010 | Toshiba Satellite Pro L300 Notebook
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Red power indicator light is blinking
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to jah2mil@hotmail.com
May 26, 2009 | Akai LCT2701TD Television
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Lamp
red light indicates lamp is expired. even though you get temporary light, the lamp is shot. Try BULBMAN.COM for a new lamp.
Sep 25, 2007 | Toshiba TDP-S20U Multimedia Projector
Magnavox 32MF338B 32 in. LCD HDTV Logo
47 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
