Question about Kenmore 24032\24036 Top Load Washer
The washer fills up with water and then stops completely - no washing or rinsing occurring. I was able to jumpstart the machine to get it into gear and start the cycle but that seems to not work now! Please help
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer stop in middle of rinse cycle
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Frig. Gallery washer and it will fill up and drain but not spin. What could be wrong and how can I fix it??
Dec 02, 2009 | Frigidaire Affinity ATF7000E Front Load...
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore HE4T washer won't rinse. Valves open to
An HF Code is a Water Inlet Problem- No or Insufficient Water Supply.
Press Pause/Cancel twice to cancel the cycle. Then, unplug the washer.
Run down the list again:
Make sure faucets are completely turned on.
Make sure the fill vavles (screens where water enter machine) aren't clogged.
Make sure the hoses aren't kinked, etc.
Plug the machine back in. Try another cycle. If the problem still occurs, You may need to replace your Water Fill Valve. Let me know if you need any further assistance.
Feb 23, 2009 | Kenmore Elite 45986 Front Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag Washer Not Completely Rinsing
If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
Just a suggestion.
Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
The washer stops after it fills with water?
You need a new SWITCH, LID 8318084 the bad lid switch is keeping your washer from sorking.. let me know if you want to repair it yourself.. let me know?
Aug 25, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
139 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
