Computers & Internet Logo
Johnathan Christie Posted on Mar 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dvd recorder hard drive not recognized when used as an external
LG DVD recorder not burning to disk. Took hitachi hard drive out and set it up as an external hard drive, The computer acknowledges it but wont recognize it in MY COMPUTER. Tried assigning a drive letter/number. Wont allow that. Wont even show what the file system is (FAT32 etc)
  • Johnathan Christie
    Johnathan Christie Mar 21, 2014
    Cant format the drive as I need the info on it. I have been advised that it may not be a file system recognized by windows. Is there a program I can install to overcome this?
Mike M
Level 3:
  • Hitachi Master 3,349 Answers
  • Posted on Mar 23, 2014
 Mike M
Hitachi Master
Level 3:
Answers
3349
Questions
0
Helped
685863
Points
16707
Open Start menu
Click the right mouse button on Computer
On the pop out menu click on Manage
In the left hand menu click on Disk Manage
Your drive should show here if it is plugged in.
Delete all partitions
Now create a partition, format it how you want.
5 Related Answers
Anonymous
  • 32281 Answers
  • Posted on Sep 13, 2009
SOURCE: Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Anonymous
  • 40 Answers
  • Posted on Aug 07, 2009
SOURCE: External HDD wont show up in My Computer
you need to install driver for it on your pc
Anonymous
  • 71 Answers
  • Posted on Aug 25, 2009
SOURCE: My compure wont recognize my external hard drive.
check if your external hdd connect to the pc.. cables is important..
Anonymous
  • 183 Answers
  • Posted on Oct 09, 2009
SOURCE: External Hard Drive not showing on My Computer? [URGENT]
Hello there Mansoor.
First, I have to commend you on how clear and extremely well articulated your problem is presented. You give every detail necessary to grasp your current situation. Good job! I can also clearly see you're at least a fairly proficient user. I only wish I'd reviewed your question before now, so I could have replied sooner. That notwithstanding, here's my GEEK-steer ...
Good job testing the drive against other "known good" systems. Because (as you probably already know) based on that, it's a virtual certainty it's the drive itself that's the source of the problem (UNLESS you used the same USB cable in all tests ... rule that out by using a "known good" cable). Its trouble could be caused by any number things [e.g., deleted partition, virus related, "sector" (file/folder structure related) errors, etc.]. At this point you've utilized all the tools that Windows avails you to work this problem (e.g., you obviously can't perform a Windows "chkdsk" on it unless there's an assigned and known driver letter, "Disk Managment" was no help, etc.). We therefore need additional software tools in order to proceed further.
Per the manufacturer's webpage, "Acomdata does not have any Windows XP, Windows Vista or Mac OS drivers because all products use the built-in driver support already supplied by the associated Operating System". Therefore, they design all their devices to be supported by Windows' database of generic drivers. However, here's their offered driver package for "All Platforms". It's a long-shot, but it couldn't hurt to start by giving this driver a try (you can always "Roll back driver" from within "Device Manager" if necessary).
== CAPTURE AN IMAGE BACKUP ==
If, as you state, data recovery is of the utmost importance, then I would strongly advise your very first objective to be (if at all possible) creating an image of the problem drive, then backup that image onto another drive. I would do that FIRST to lock in it's current state as an insurance policy, BEFORE I ran any testing/diagnostics, or attempted any alternate means of data recovery. Keep that image intact throughout this process until resolution. There are several disk image "Backup Tools" (e.g., "DriveImageXML", "Acronis True Image", etc.) in "Hiren's Boot CD" you can use to accomplish this.
== BREAK OUT THE TOOLBOX ==
Refer here for complete list of its available tools. There are far too many to cover in any detail here. Particularly when the nature of your problem is yet known, as each may, or may not be THE one for the job. However, you can simply Google each to obtain background and usage instructions. Also, tools reside in either the DOS or mini-Windows boot portions of the CD, as some are DOS executable and some Windows. You may have to venture into both until you find the tool that works for you. I know there's a lot in that puppy, but that is intentional because it's a good thing ... affords wide range of choices/options.
== HOW-TO CREATE 'HIREN'S BOOT CD' ==
  1. Download "Hiren's Boot CD".
  2. Extract/unpack/unzip/decompress (<-choose your term, they all mean the same thing) the .ISO disk image file ("Hiren's.BootCD.#.ISO") located within the downloaded "Hirens.BootCD.#.zip" archive file (where # = version of Hiren's).
  3. Burn the disk image to a CD using whichever capable disk image burning software (e.g., Nero, Roxio, etc.) you may have. Don't have one? Then download and install the very capable, yet lightweight FREEWARE "imgBurn"
Burn the extracted .ISO image file ("Hiren's.BootCD.#.ISO") to CD using imgBurn:
  1. Insert a blank disk (R/RW) into your disk burning capable CD/DVD drive.
  2. Launch "imgBurn", then select "Write image file to disc".
  3. Browse for and select the "Source" .ISO file above.
  4. Ensure the applicable disk burner drive is selected as "Destination" (you may have more than one).
  5. Click the burn icon.
  6. When burning completes, close "imgBurn".
== RECOVER THE DATA ==
Next I would attempt recovering the data using any number of Hiren's "Recovery Tools" category of tools (e.g., "ProSoft Media Tools", "GetDataBack for NTFS", "TestDisk", "Ontrack Easy Recovery", etc.). Many of these include diagnostics/repair facilities you can use in the course of your recovery efforts.
== RECOVER/FIX THE DRIVE ==
Then once/if you've successfully recovered the drive's data, you can (if applicable) use any number of Hiren's (hard-drive related) "Testing Tools" and "Hard Disk Tools" categories of items in order to fully test/diagnose and hopefully recover the drive to working order.
TIPS:.
  • Be aware that you MAY discover you'll HAVE to perform testing/diagnostics/maintentance related actions on the drive first, just in order to get it into recognizable shape for any of the drive image and/or data recovery related tools to perform. That's OK, 'cause "you gotta do, what you gotta do".
  • "Partition Find and Mount" might be particularly helpful in recognizing, then mounting the drive
I apologize in advance for any logic-sequence or grammatical errors this reply may contain. I culled together a few differing draft stage portions of some "Tips & Tricks" I'm intending to post in the near future.
Good luck, and please do post back to ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Lee
  • 393 Answers
  • Posted on Mar 03, 2010
SOURCE: Hard drive clicks several times when turned on,
I have to say from the sounds you describe the Hard Drive is totally destroyed, the noises you can hear are the mechanical parts inside grinding and clanking together. If the information is critical it may be recovered by a specialist data recovery company, but we are talking £100's even £1000's to do the job, so otherwise I would suggest taking case apart and buying a new hard drive for it.
Sorry its not what you want to hear but it sounds very terminal to me.
The reason the PC can detect a device is that it can see the Interface card that sits between the USB port and the Hard Drive.
Testimonial: "Thanks for a quick reply! "
How can I transfer recordings to a hard drive?
Any external USB hard drive that uses a 3.5" hard drive (the larger drives they use in desktops) will work. These all come with an external power adapter you must plug into the wall.
The external hard drive units that use the smaller 2.5" hard drives are the ones they use in laptops. These require much less power, and can be powered by the PC's USB port although some do come with an optional power adapter. However the Dish receiver does not send enough power to its USB port to power the hard drive, which is why the tech told you to get one that has an external power supply.
Even then the DVR uses a drive format that your computer may not recognize. I don't know if there are tools out there that will let you connect a hard drive from a DVR, read and convert the TV shows stored there.
Another option is to buy a DVD recorder. This is like a VCR, only it uses a DVD disc and not a video tape. Connect the DVD recorder to the outputs on the DVR, and then set the DVD recorder so it will record from its input. (on my DVD recorder this is "IN2")
Put a blank DVD into the DVD recorder, start playing a show on the DVR, and hit record on the DVD recorder. When the show is finished, hit stop on the DVD recorder to stop recording. The advantage here is you can then play this DVD on any DVD drive. The disadvantage is DVD recorders only record in non-HD. You can still play a show in HD, but the recording you get won't be in HD. Also, the show has to record in real time. So if it's a 60 minute episode, it will take 60 minutes to record.
You can also check this steps:
Tryed to burn cd,But the external is not being recognized.Drive does show u in Utility window.
Normally in the settings of your burning programme it asks if you would like to finalise the CD/DVD.
That needs to be ticked to suit your burning needs
I personally use Nero and have never been let down plus it has some great features
Hope this helps
Backup hdd to external hd
DVD recorders are usually not the first selection for backup of data files. you may be better off with a 1 Tbyte external drive, which is suited for that purpose. Even though the DVD drive has the capacity, there are usually formatting issues with data files being burned to a DVD recorder.
2answers
When i connected my 250gb hitachi hard drive my laptop don't recognize it
Hello macklinalfre, Do the following to have the "External Hard Drive" recognized. "To install, and Update Hardware, click to open "Computer" from the "Desktop", check to see if there is a DVD-RW Drive (D :), for external different (E or F:).
I. Look in the "Device with Removable Storage area," see if the device is present, if so? Do the following: to "setup" the ('player') for "Installation."
II. Right click on (DVD) "Media Player" select ("Install") follow all instructions thereafter.
III. If the area is (Blank?), "go to," and 'click' on the "Start button" click all "Programs" scroll for a "Media Disk Player", open, and do the ("same as above") for the installation. *Note: "Do the same for "Setup" (above) "Install."
"I hope this information is helpful? Thanks for using FixYa, paul7of9"
2answers
Can the lg dvd rewriter gsa-e10n be used as an external info store as well? if so how many gb? thank you!
No dear. External Hard disks, pendrives etc does it for you. A CD/DVDRW plays only CDs & DVDs + burns CDs & DVDs. Please send me your feedback & vote to motivate us & to help us help you.
How do I change burn speed settings on an LG external GE20 super multi-dvd rewriter?
Settings are available in the software you use for burning the disk. Please check the burning options.
Hi my dvd burner doesn't recognize my virgin disks
Sound like your cable that connects your burner to the motherboard. Try another cable, if you want to try another trouble shoot item, try connecting it behind the hard drive. Before you do set the jumper setting to slave on the burner and hook it up. That will help you to elimate a channel.
1helpful
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
How to burn a dvd from a JVC Hard disk drive recorder
Make sure you plug your camcorder into the in on the dvd recorder. Make sure the dvd recorder is set to that input. you may need to hook it up to a tv and make sure you see your camera on the tv going through the dvd recorded to make sure you have it on the right setting. Make sure you camera has playback out turned on.
Top Hitachi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
