The power supply in My dvd soken DV-744 got burnt and the ic is burnt beyond regonision
Soken DV-744
  • 20 Answers
U have to replace the board, search ebay, ioffer for an equivalent
Posted on Jun 18, 2014
3 Suggested Answers
trintek
  • 111 Answers
SOURCE: Time and Date
you will most likely need to add a title in your video editor to display this, the time and date id are usually overlayed on your camera and can be disabled if need be. the camera uses it's internal clock to imprint the video, this seldom if ever transfers to dvd unless the application you are using supports it and you enable it.
hope this helps,
trin
Posted on Nov 16, 2007
SOURCE: A 8 pin Ic power supply(AK41-00846A)is burnt so i
I do not have a solution but, I guess I too have the same problem. How did you check the power IC, do you have a manual for the player?
Posted on Jan 15, 2010
My Panasonic DVD recorder won't turn on after a power out. Another user says that this is common, it may be a burnt diode or a damaged power supply. WOULD TURNING THE POWER STRIP OFF RIGHT AFTER THE POWER...
If the power supply has already suffered the brunt of the surge, it could be an expensive repair, possibly not economical.
Of course, you can submit this recorder to a service centre, and obtain a quote on any repairs/board replacement required, then make a decision afterwards on that basis - yes or no - it's up to you what you do.
Sorry to say the power surge has quite likely destroyed several components in your DVD recorder's PSU beyond economical repair; it would not just be a 'burnt diode'.
However, in the future, if you are worried about likely surges occurring again, you can always switch units off at the power point when you aren't using them (example, overnight when you go to bed or when you go out for more than an hour at a time). This may help prevent expensive damage to other appliances.
Surge protection on your household power (or a surge protected powerboard/strip if that's cheaper and easier to get) is recommended.
Mar 02, 2011 | Panasonic DMR-ES10 DVD Recorder
My subwoofer IC got burned because i accidentally plug it to a 220v power supply, mine is only 110v i want to know the IC# subwoofer.
Most likely what got burnt is the bridge rectifier in the power supply section of the electronic circuit. This usually takes the shape of either a single 4-legged IC, or a group of 4 rectifying diodes connected in a bridge configuration. If you disassemble the unit to which the power cord is attached & trace the circuit starting from the terminals of the power chord, you can easily identify it. You will need to replace the 4-legged IC or the 4 rectifying diodes.
You will also need to replace the fuse, since it is usually likely that it gets burnt if the unit is attached to 220V instead of 110V.
Nov 24, 2009 | Altec Lansing FX4021 Computer Speakers
Error 95-744 on DSR1500 AP sony
Main code 95 : Digital signal process system error and communication error with ICs
7 : STANDBY-OFF mode
4 : Capstan motor/FG
4 : FG cannot be detected.
Nov 07, 2009 | Sony DSR-1500 Mini DV VCR
A 8 pin Ic power supply(AK41-00846A)is burnt so i didnt get its number, so can i get it from you please. Also a resistor(rpf2 on board number)is burnt too.
Sep 19, 2009 | Samsung DVD-H1080 DVD Player
No power at all on dvd players
check if the fuse is burnt, if burnt check the following
bridge diodes,
semi conductors- transistor or ic at power supply
zener diodes,
resistors
all this are at the supply
Apr 17, 2009 | Televison & Video
Dsc-363 displays code " oc err 1 "
It's output power amplifier ic problem. change ur output ic
Mar 08, 2009 | Pioneer DV-363 DVD Player
HTS3300 Home theater system
It cant be know like that way! you need it to be repaired at service station only so they can trace it out!
Dec 08, 2007 | Audio Players & Recorders
No Power
ok! make sure ur IC regulator is good. like the 7805 or 7812 or 7809 u make sure that the following ICs are correct in voltage! 7805 is for 5V. 7812 is for 12V. 7809 is for 9V MAKE SURE THAT IS EXACTLY IN VOLTAGE!
Jun 17, 2007 | Pioneer DV-575A DVD Player
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
Electro Med Services...
