Question about Epson Stylus R265 InkJet Photo Printer
Ink tanks on my Epson R265
I have changed all the ink tanks on my R265 but the printer is still saying they all need to be replaced
  • 51 Answers
Did you refill them or buy refilled cartridges? Epsons all have a chip on the ink tank. once that chip registers a certain count it renders the cartridge dead. If it gets refilled it has to be reset, which 99% of the refill places don't do. It's also possible that the contacts on the carriage have worn down or been punctured. Also look in the back of the carrier and make sure you don't see any small holes in the white ribbon cable.
Posted on Jun 14, 2009
My Epson R265 is sending a message saying that it
If the lights are flashing alternately and slowly (with the power light off), then the waste ink absorbers are full.
The pads are near the bottom of the printer and can either be replaced (call the service department for the parts) or rinsed clean under running water. The hard part is usually extracting them (you need to disassemble the printer most of the time). Then (if reusing the pads, wait until they are dry) reinstall them and reset the waste ink counter. The reset requires a program such as the one available here: http://inkjetprinterhelp.us/epsonSSC.html . Do not run this utility until the pads are replaced, the ink will smear everywhere. Epson used to have a link for their own reset tool but I do not see it for this printer.
However, the printer is designed that under normally usage, the waste ink absorber will be full at the expected end of life of the printer. Thus additional failures may be coming.
I hope this helps.
May 04, 2010 | Epson Stylus R265 InkJet Photo Printer
2 RED LIGHTS FLASHING CARRAIGE WILL NOT MOVE
On the Epson printer two flashing red lights mean that your printers waste ink tank is full and Epson has locked your printer you need to replace the waste ink pads and then reset your printer using the reset utilities
Mar 08, 2010 | Epson Stylus R265 InkJet Photo Printer
My Epson Stylus Photo R265 is not allowing IJT Direct compatible ink cassettes to be used - they load into the printer OK. What can I do to make them work?
The compatable inks you use will depend on how old your printer is
Epson change their printer every few months changing the chips so if you have a very early printer you need the earlier chipped compatables
Feb 21, 2010 | Epson Stylus R265 InkJet Photo Printer
Iwant to clean out or change waste ink pad on epson r265 printer. have just used cotten buds to soak up waste ink to fix flashing lights. but i think only a temp. solution
Photo walk through here shows how to access waste pads
http://www.inkrepublic.com/KnowledgeBase/R260WasteInk.asp?C=0
Also shows how to replace with a bottle to collect waste ink
Feb 08, 2010 | Epson Stylus R265 InkJet Photo Printer
My printer says service is required is there epson r265
If you are getting the message printer neeeds a service I suggest you get your ink pads cleaned straight away before your printer locks on you Two alternating flashing lights
You need a service utility for the R265 to reset it. you can find one of these on the net free of charge some people are selling them for a fiver but why buy what you can get free if you have problems or need
more info contact me at drummerboy36uk@yahoo.com or MSN using thedrummerboy53@hotmail.com
Jan 25, 2010 | Epson Stylus R265 InkJet Photo Printer
Hi, I have just changed the yellow cartridge on my R265 with proper epson ink cartridge and it is saying that it is incompatible. Can you help please?
Hi If you are using compatable inks try taking the ink cartridge out and put it back in again try this three or four times to see if it will accept it if not try a different cartridge you can sometimes get a duff one The earlier models have a different cartridge than the later models epson altered them and changed the chip
Oct 25, 2009 | Epson Stylus R265 InkJet Photo Printer
Epson r265 needs service
If the error says, parts inside your printer are at the end of their service life, the ink pad on your printer needs to be replaced. Then log on to epson.com/ipr to get the ink pad reset utility software. The software runs on win xp and win vista.
May 01, 2009 | Epson Stylus R265 InkJet Photo Printer
Service required
A "Service required" error means that the waste ink pads (sort of a diaper/nappy) in the base of the printer are considered full by the printer and it wants you to get it serviced to change them.
You, can take or send the printer to a service centre but it's likely to cost as much as the printer did originally and also it will require a change in the future.
More cost effective is to reset the counter using a reset utility and install an external waste ink tank.
The R265 utility is available here
(ALWAYS scan the file for any virus or malware infection!)
Once you've sorted that you then need an external waste tank... You can either make one yourself or buy a pre-built kit with all the info you need...
Google "epson waste ink kit" for a few options there.
Hope that helps.
Mar 13, 2009 | Epson Stylus R265 InkJet Photo Printer
Epson R265
Both redlights are flashing, and I need to change the waste ink any one help please
Apr 24, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson r265
download and install latest driver from Epson. Status monitor is in the driver. Check you have monitor ink setting active within driver.
Feb 18, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus R265 InkJet Photo Printer Logo
287 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
